Lenovo 300e Chromebook
  • juhusu
    • Feb 2020
    • 1
    • Estados Unidos
    Re: Lenovo 300e ChromeBook 2nd Gen BIOS LOCKED
    Hello my friends. I have this same laptop but apparently the bios is corrupt, it gives me a red and a green light when I connect the type c charger and the power button light is blank.
    this sequence is repeated all the time while the charger is connected. Any recommendation? Thanks in advance..
    • tinto
      • Jul 2017
      • 74
      • serbia
      Try my bios dump from RethoricalCheese
      • digitalpc
        • Jun 2016
        • 305
        • .DLL
        Hi everyone I have Lenovo Laptop with Chromebook OS with gmail administrator password.
        I try Reinstall OS form USB, try PowerWash Method but Chromebook Administrator privileges stay here.
        Trying flash Bios Can fix this problem or anything else.
        I upload some images of laptop.
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Re: Lenovo 300e Chromebook
          Where's the bios dump file?
          • digitalpc
            • Jun 2016
            • 305
            • .DLL
            Here
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #26
              Flash this file. It will not be unlocked straight away. You need to enable devmode first. It will not let you go to devmode but that's okay. You need to let it reboot into normal mode, which clears the system. Then you will be able to log in and powerwash. After powerwashing, devmode is unlocked aswell.
              • digitalpc
                • Jun 2016
                • 305
                • .DLL
                #27
                Working Perfect, thank you.
                Can I use this dump for 6 laptops with same problem?
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #28
                  I don't know. It should change SN so I would say no. You would need to use a programmer anyway and modifying it is so easy so I don't see a reason to use the same dump.
                  Use hex editor to see differences. It's only 2x 1 bytes which are very easy to find.
                  • digitalpc
                    • Jun 2016
                    • 305
                    • .DLL
                    #29
                    Do you have Bios dump for
                    Lenovo N23 Yoga
                    And
                    Acer C738T with same problem like Lenovo 300e
                    I upload my orginals
                      • 21403
                      Lenovo N23 Yoga
                      And
                      Off topic .
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #31
                        If it's a chromebook and has enrollment, just use the same method. It pretty much doesn't depend on what model it is (maybe with the exception of newest models). Just compare your file to what I sent you and you will understand what to do on other models.
                        • digitalpc
                          • Jun 2016
                          • 305
                          • .DLL
                          #32
                          Thank you my friend I remove password in all laptops.
                          Thank you very much.
                          • LatinMcG
                            • Jun 2015
                            • 73
                            • USA/Puerto Rico
                            #33
                            the 300E .. write protect disable is removing main battery per mrchromebox CR50 method
                            • huynhdoluan
                              • Oct 2021
                              • 31
                              • VietNam
                              #34
                              please help me
                              • Papanatas
                                • Feb 2022
                                • 6
                                • Spain
                                #35
                                Hi, i have a 300e gen 2 with windows and I forgot my BIOS password.
                                I can access to Windows normally
                                I don't know how to extract my BIOS bin.
                                What can I do?
                                • Papanatas
                                  • Feb 2022
                                  • 6
                                  • Spain
                                  #36
                                  What can I do?
                                  Please, help. The Universal BIOS Toolkit 2.0 don't read my BIOS and fwtp64 give me error 200 and dont work.
                                  What software I can use?
                                  I Try:
                                  Innoextract: Error 1 when I try to extract BIOS from EXE package from Lenovo Website.
                                  Universal Extractor: Says to me that the file is a game file and give me some errors.
                                  Lenovo oficial tool: When I try to backup my BIOS, the program reboots the PC and install the lastest (WTF).
                                  I can't find anywhere the backup file.
                                  Phoenix STC extractor (winphlash): says me to specify a new BIOS file that I can't find anywhere because I can't extract from lenovo exe package.
                                  FPTW64: No BIOS found.
                                  Universal backup toolkit: no BIOS found.
                                  WTF is all that?
                                  • Papanatas
                                    • Feb 2022
                                    • 6
                                    • Spain
                                    #37
                                    I Try:
                                    WTF is all that?
                                    Please, can anybody help me? I tried all...
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12047
                                      #38
                                      You need a programmer device to dump your bios from bios chip on mainboard.
                                      However, i can't not find bios for this model on Lenovo home page.
                                      If there is a bios file on lenovo homepage, the bios file is also incomplete so always back up the original bios file before doing anything.
                                      • Papanatas
                                        • Feb 2022
                                        • 6
                                        • Spain
                                        #39
                                        It's not possible to do with software?
                                        I see that in the almost all cases and for a big part of lenovo laptops it's possible.
                                        • Papanatas
                                          • Feb 2022
                                          • 6
                                          • Spain
                                          #40
                                          Up, in case anyone can help me to do that without a dedicated programmer machine.
                                            Lenovo 300e Chromebook Specification for Upgrade or Repair
                                            This specification for the Lenovo 300e Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 300e boardview and 300e schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo 300e Chromebook...
                                            09-06-2024, 02:34 PM
                                            09-06-2024, 02:30 PM
                                            09-06-2024, 01:21 PM
