Has anyone had issues with Rayovac Alkaline batteries leaking
    • 31214
    Re: Has anyone had issues with Rayovac Alkaline batteries leaking
    you can use NiMH on xbox controllers - thats what is in the rechargeable packs.
      • Jul 2011
      • 6069
      Yes I know but back then when he play all the time the batteries would go dead quickly and he complained about it so I looked for something different for him to try and he had like the first set of them I had bought but he did not like second set that I had bought for him he complained about the fact that he had put them on charge all time
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I had some NiZn batteries and they quickly died, they were not balanced.
        Not sure about those li-ion cells with internal buck/boost circuitry...
        I would think the leak-in-blister pack is rare with good quality cells and you should simply remove the cells if you're not using the device. If you're using the device frequently, promptly replace the cells when dead, or use good rechargeable cells if you're draining them down fast...
        Perhaps another method is add in a leak wick that would wick away any leakage from the contacts to minimize damage. Still dicey but probably helps a little.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          In my experience, I don't think this battery leakage problem is unique to Rayovac or any other brand anymore. I find pretty much all alkaline battery brands nowadays to leak like crazy for whatever reason. Not sure what's changed, but 10 years ago, it was just Duracell that started doing this first... and subsequently Ikea and Costo Kirkland alkalines a little later. Related? -Possibly. In any case, at least the other brands were generally OK. But now - it seems every brand is affected.
          For this reason, I have started to avoid alkaline batteries whenever possible.
          For smoke detectors, remote controllers, and other applications with low drain, I've rediscovered / switched back to the good old Carbon Zinc ("Heavy Duty" / "Super Heavy Duty") chemistry. And from those, Panasonic and Toshiba are still the best, IMO - no leaks, and they will last for years and years without issue. On that note, the original C-Zn Panasonic batteries that came with my parents' DVD/home theater system are close to 15 years old now! Not only have they not leaked, but they are still holding up and used in the remote for that DVD player. (And yes, that DVD/home theater does see a lot of use, because it's used every time the TV is On.)
          Originally posted by retiredcaps
          Start using low self discharge nimh cells (AA and AAA) in your expensive equipment. Sanyo/Panasonic Eneloops are the gold standard, but it's rumored that Ikea Ladda Made in Japan nimh are made in the same factory and specs as Eneloops, but are much cheaper.
          +1
          My sister switched to Ikea LADDA rechargeable batteries for her son's toys and... going 4-6 years now without any issues. Some of the toys he doesn't use very often, so it's a good thing these LADDA batteries have low self-discharge. On the other hand, they can also provide a high current easily when it's needed. So they are pretty good quality.
          i have had fucking duracell's leak while still sealed in the bubble-pack!!
          i wouldnt guarantee them for 10 months!
          And you're right about that!
          My mother bought an 8-pack of the Duraleaks (AAA "Optimum") because she needed one for an old MP3 player that she uses very infrequently. Luckily, I remembered to check on her MP3 player after I saw the packet. The single Duraleak inside it was just starting to form droplets on the edges of its bottom, though they hadn't quite reached the battery terminal springs of the MP3 player. And this was after not even 6 months of storage (!) after the very occasional use that the MP3 player saw. I checked the rest of the AAA's in that pack, and another one was starting to have droplet formations.
          So I pulled the two AAA's with the droplets and set them aside. But I didn't throw them away - I'll be damned if Duraleak can make a fool of me like this. Instead, I wiped the moisture from these two cells and started using them in my headphones (need 1x AAA battery for NC), since I use those almost daily and typically for several hours. Of course, I'd remove the Duraleak after each session. But because of my high usage, I'll drain a regular AAA alkaline with these headphones in about 3-4 weeks max. This allowed me to get the first Duraleak completely used up before it totally pissed its pants. I'm now onto the 2nd leaking one... and waiting for it to die any day now. After this, I'll be back to my regular NiMH rechargeables... unless there are more Duraleaks from that 8-pack that need draining (I suspect there will be.)
          you buy cheap $ store alk's because anything beats durasell and keep an eye on them.
          Sad but true, unfortunately.
          The "Rocket" alkaline batteries that came in my parents' Samsung TV's remote just started leaking last year - that is a good 9 or so years after the TV was purchased. You will not find a modern Duracell battery last that long, or even a small fraction of that time. The only Duracell alkaline batteries that I have that haven't leaked yet are really old stuff from the early 2000's. I don't know what Duracell did differently back then, but their batteries actually lasted damn well and rarely ever leaked. But now... half a year on the shelf, tops, before they start going. Same goes for Ikea and Costco's Kirkland brand alkaline batteries.
          On that note, I'm curious to try Harbor Freight's alkaline batteries. Unfortunately, I don't use batteries that often anymore. So it's rare when I have to purchase any... and that's usually 9V ones for the smoke detectors inside the house (whose old batteries I transfer to use in my cheap multimeters afterwards.)
            • 31214
            there is a huge europe-wide chain called "Lidl"
            do you have them in the u.s.??
            they have the best alks - proven in tests.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              Yeah, they just recently started popping up on the East Coast here... or at least where I am. In fact, one just opened this summer only a few miles away from me. So thanks for the tip, I'll check out their alkaline batts if I need any (probably some 9V soon for a few smoke detectors - there is always at least one that starts beeping on me right around fall-winter time when the temperatures start dropping.)
              Otherwise... I've been to Lidl before. They aren't great when it comes to fresh fruit and vegetables, but there are other stores for that stuff. On the other hand, Lidl does have some items (snacks, meat, baking stuff, and condiments) that no other store can beat in price. Heck, the first one that opened here was right next to a Wallmart. Just imagine the nerve to do that.
              • lti
                • May 2011
                • 2557
                I still have some old Walgreens "heavy duty" batteries that are close to 10 years old.
                Those are the ones I mentioned that came in a cardboard box that hid the leaks. I don't remember all of the battery names.
                I do that too, except I have a huge pile now.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Anyone had experience with Duracell's Procell (all black duracell instead of copper top), are these any better?
                  I have a feeling that a lot of the non blister pack Duracell could be fakes. Not sure, for those people living in the USA there's a store "Big Lots" that I have a suspicion that they sell fake or self-packaged Duracells to get a better price (which isn't that much better)... I haven't seen any leaking on the shelf but these seem to all be in that paperboard under container and shrink wrapped on top. Not sure if these are fake or not but very strange packaging IMHO.
                  IMHO those carbon zinc batteries, they tend to "leak" into the air (as in they dry up instead of leaking liquid into your $EXPENSIVE$EQUIPMENT)... little/no equipment damage, but does damage the pocket book if you don't watch how much you pay. Plus their ESR is pitiful.
                    • 31214
                    procell were marketed in europe for company use to deter theft by workers.
                    i doubt they are different internally.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Theoretically they are identical.
                      Question is if they are better because they probably aren't counterfeit!
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8331
                        those batteries, big clive did a teardown of the Jugee branded ones - very interesting products!
                        there are also NiZN batteries - i think thats the chemicals anyway - they run at 1.5v but not many chargers support them.
                        I thought these NiZN batteries are like 1.7 or even 1.8V?
                          • Jul 2011
                          • 6069
                          Yes they are at the 1.7 to 1.8 when new and as they age the voltage becomes lower when they reach about 1.5 volts they are pretty worn out and will not last long on a charge
                            • 31214
                            so if you pair them with NiMH you get 3v?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I tried a couple and they are fragile. Powergenix NiZn were terrible in cycle life, I don't think I even got 10 cycles before they dropped dead, even with their own charger.
                              Yeah, maybe 5 with doing this...
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8331
                                That may be fatal for something that does take 10 batteries. Lol
                                  • 31214
                                  that would be a textbook case for 18650's and a boost convertor
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Now that BMS boards are standard practice for Li-ion, why not have BMS for NiZn...
                                      • 31214
                                      it's my understanding that nizn are only a few hundred mA, and you dont charge them in packs anyway - atleast not with any retail charger
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Yeah the AA 14500 NiZn's I had were only like 900mAh. Total crap. They need to be in SMPS buck/boost with BMS. At 1.5Wh it's not way too bad though 2.4Wh NiMH is typical...
                                        The charger ("official") I had could individually charge. So charging isn't the problem...
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3581
                                          • USA, Unsure of Planet
                                          #40
                                          Had a bunch of leaking Duracells a couple of years ago, but not recently, touch wood.
                                          PeteS in CA
                                          • m1ch43lzm
                                            Replacing 2xAA / 2xAAA alkaline batteries with Li-Ion / LiPo battery?
                                            by m1ch43lzm
                                            Hi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
                                            I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
                                            I'm open to suggestions on whether i should use an LDO or another type of voltage...
                                            05-27-2025, 05:34 PM
                                          • howardc64
                                            Where do repair shops buy MB replacement batteries?
                                            by howardc64
                                            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                            07-25-2024, 10:42 AM
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
                                          • carrzkiss
                                            Cyberpower cps1500avr not charging batteries
                                            by carrzkiss
                                            Hello, all.
                                            Cyberpower Battery Backup Unit.
                                            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                            Checking the voltage, it was down to 22v.
                                            I quickly removed everything...
                                            06-15-2024, 02:10 PM
                                          • dbuergi
                                            DIY: Modified smart charger for all types of batteries
                                            by dbuergi
                                            sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                                            Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                                            My first work was to bring my Samsung watch battery back to life with was not recognized...
                                            07-18-2025, 03:17 AM
