SPIM08HP 3.7V 16AH Battery which can handle 200 amp pluses Battery Hookup
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8710
    Re: SPIM08HP 3.7V 16AH Battery which can handle 200 amp pluses Battery Hookup
    Lead acid batteries need BMS too...
      • Jul 2011
      • 6070
      Your right about this but finding the right one is the issue and most of them are not designed right either they over charge over time or they do not charge enough and leave battery at 70% and not at 95 to 98% which would be better
        • Jul 2011
        • 6070
        Well Electronic Goldmine brought back these again and I bought four of them to try out on the battery stud welder
        Eaton PowerStor® XL60 3000 Farad 2.7V Supercapacitor XL60 a 1/3 cost of brand new one from Digikey
        https://www.goldmine-elec-products.c...?number=G24175
          • Jul 2011
          • 6070
          Well I just bought one of these battery packs because now I have a way to test this type of battery pack
          https://batteryhookup.com/products/2...v-power-module
          But I going to turn this in to two 20 volt battery packs instead of the setup that it is right now
          For the battery operated air compressor that I had bought several months ago
          One note they have sold out of them several times before
            • Jul 2011
            • 6070
            One note I decided not to test on the new battery tester because of the data code on the battery pack I decided to use the other battery testing machine instead for a more accurate testing results but once I get the batteries matching close to each other then I will put it on the other battery tester and run it at a 8 amp load and see what the results look like
            I have tested a few of these for this pack and they seem to have around 90% life left in them for batteries that have a date code of 2015 on them
            They are suppose to test at 8 amp hours but are testing at around 7.0** to 7.1**something amp hours
            The discharge curve looks good until it reaches the 3.45 volts and drops faster than I would expected it to be it should drop at lower voltage maybe closer to 3.0 would be a lot better
            This discharge curve looks pretty decent for it age still a lot of life in it I tested one for 5 minutes @8 amp load on the testing machine and the results were pretty good at 8 amp load
              • Jul 2011
              • 6070
              Testing has been suspend from 1-2-22 for the rest of the week because of work and having to work 13 days with no days off because of some special project that they want to do
                • Jul 2011
                • 6070
                Well I have tested about half of them and the results are as follows
                6800 to 7*** something these batteries are not quite as good as the signal double battery pack cells are but I can still use them but a little disappointed that they are as good and have found that some of the battery cells have a self discharge issue which is going to add to how I group these batteries to make a battery pack
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8710
                  hate cell variation, alas not much can be done about it ...
                    • Jul 2011
                    • 6070
                    Yeah I know all I can do is group them the best that I can and the ones that have a bad self discharge rate maybe use a couple of them for solar lighting around my shed and maybe in the font yard I have a few solar panels that I could use for this project
