RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #441
    Re: RCUnlocker
    16MB chip on the other side must be modified.
    • clrscr
      • Dec 2020
      • 186
      • sing
      #442
      Re: RCUnlocker
      yes, it work
      thanks!
      all donations are welcome,
      >>>>> click on this link to donate via PayPal. <<<<<
      • kersh
        • Jul 2022
        • 3
        Re: RCUnlocker
        Attempted on a HP Probook 6450b. (2009/2010)
        Able to read many exact checksum files from chip
        Chip: MX 25L3205D
        note about the error those are hardcoded paths not on my pc, is there an updated version of the tool or source I can compile from?
        Any help is greatly appreciated.
        Error dialog when running the unlocker:
        zip with both before and after bins attached
        • hoaca388
          Badcaps
          • Jan 2022
          • 12347
          #444
          Re: RCUnlocker
          Your bios file unlocked.
          ​https://www.badcaps.net/donate
          • kersh
            • Jul 2022
            • 3
            Re: RCUnlocker
            I rewrote the new file and it still has the password on it for me. I'm using a CH341A with 8pin SPI clip.
            • ryankou
              Ryan @niway
              • Oct 2016
              • 38
              • canada
              #446
              Re: RCUnlocker
              for chromebox unlock, changing the dev mode and enrollment set to 0 will not work. the only change is "requisition.remora.gbind. " to ".none.ubind.."
              tried on chromebox 2 and 3 ASUS. both works.
              • Andrjj
                • Nov 2017
                • 3
                • uk
                #447
                Re: RCUnlocker
                hi! HP EliteBook x360 1030 G3 writes that it does not support(" Wrong chip try reading and unlocking 16mb chip"), in previous posts it says that it supports(Unlocking HP - ProBook, EliteBook, ZBook (including 32MB models) and Usage: Drag and drop .bin file to .exe file). Help please!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12347
                  #448
                  Re: RCUnlocker
                  Maybe you have 2 SPI chips, usually it's on the other side of the motherboard, post both here.
                  • kersh
                    • Jul 2022
                    • 3
                    Re: RCUnlocker
                    It was user error. I was able to get it working after another erase/flash cycle. Thanks Cheese
                    • Andrjj
                      • Nov 2017
                      • 3
                      • uk
                      #450
                      Re: RCUnlocker
                      You are right, there are two SPI chips! The question is, is it possible to flash the firmware without full soldering? I understand, the program removes the bios password or something else? what are the capabilities of the program, what can it do? did not find information anywhere. Thanks!
                      I have two hp 1030. One has a password, the other has no password. Where there is no password, the program erases a certain area after analyzing before and after, the question is what did it erase if there was no password? ) Sorry for the large number of questions, I'm just learning)
                      • Raiderman
                        • Jun 2022
                        • 18
                        • U.S.A.
                        #451
                        Re: RCUnlocker
                        Anyone want to clue me in on how to use these probes I purchased from Ali Express?
                        • AAAC
                          • Jan 2020
                          • 459
                          • Mexico
                          #452
                          Re: RCUnlocker
                          @Raiderman
                          Please upload one or a few good picture(s) of the probes, as it seems like we all left our crystal balls at home.
                          • Raiderman
                            • Jun 2022
                            • 18
                            • U.S.A.
                            #453
                            Re: RCUnlocker
                            Originally posted by AAAC
                            @Raiderman
                            I will, its a page or two back that we discuss the using the probes for wson8 chips
                            • Raiderman
                              • Jun 2022
                              • 18
                              • U.S.A.
                              #454
                              Re: RCUnlocker
                              Originally posted by SMDFlea
                              Yes thats a WSON8 chip, don`t use the clip on that,you risk damaging the chip,shorting the surrounding components and cutting through traces.
                              Your options are to desolder it,use a WSON8 pogo pin adapter,or try to solder some thin wires to the protruding solder or traces caps and resistors
                              https://www.aliexpress.com/item/1005003313016522.html
                              These are the probes linked by SMDFlea that I purchased
                              • AAAC
                                • Jan 2020
                                • 459
                                • Mexico
                                #455
                                Re: RCUnlocker
                                @Raiderman
                                I suggest to take a look at YouTube, use these keywords "pogo pin WSON8", I do get a few results there showing how to use the probe. I don't include the links here as some videos have advertising.
                                • Raiderman
                                  • Jun 2022
                                  • 18
                                  • U.S.A.
                                  #456
                                  Re: RCUnlocker
                                  [QUOTE=AAAC;1149670]@Raiderman
                                  Thank you, I will try
                                  • ogre4273
                                    • Mar 2022
                                    • 57
                                    • N/A
                                    #457
                                    Re: RCUnlocker
                                    how to remove computrace for HP elitebook 840 G6?
                                    • AAAC
                                      • Jan 2020
                                      • 459
                                      • Mexico
                                      #458
                                      Re: RCUnlocker
                                      @ogre4273
                                      Use UEFITool NE version and check UEFI Variables, there's usually one named AbtState, that one contains information if Absolute Computrace is Active.
                                      Then use an hex-editor and search for AbtState, a few bytes before the string you will find the header AA553F(h), to invalidate that variable make it AA553C(h), save changes.
                                      • doa379
                                        • Aug 2021
                                        • 19
                                        • US
                                        #459
                                        Re: RCUnlocker
                                        A general question about flashing an image to the EC. Instead of patching the image in the ROM is it not sufficient to flash the ROM with the manufacturer's copy of the BIOS binary?
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #460
                                          Re: RCUnlocker
                                          HP doesn't offer EC. Only main and even that is without ME region.
                                          There is a way to make EC out of main but it needs some knowhow. I've succeeded a few times but would avoid it if possible.
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
