RCUnlocker
  • zelenborg
    • Aug 2022
    • 4
    • Croatia
    #481
    Re: RCUnlocker
    I have HP Elitebook 850 G8, locked BIOS. Has anyone tried with this tool?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12322
      #482
      Re: RCUnlocker
      This tool doesn't work with 32MB file but you can post your bios and EC file here.
      • streft
        • Mar 2014
        • 9
        • Azerbaijan
        #483
        Re: RCUnlocker
        super hp probook 450 g7 unlock
          • 21852
          Re: RCUnlocker
          450 G7 thread -> https://www.badcaps.net/forum/showthread.php?t=91780
          • zelenborg
            • Aug 2022
            • 4
            • Croatia
            #485
            Re: RCUnlocker
            EC file?
            I will extract both bios chips if I find them
            Probably the one under keyboard is the one I need to flash, right?
            I will do it in few hours.
            edit:
            I found this youtube video: https://www.youtube.com/watch?v=OG_xNKi1QKU
            I think it might be working. Any comment on this?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12322
              #486
              Re: RCUnlocker
              EC file?
              edit:
              Yes, it is.
              • NTBservis
                • Jun 2016
                • 32
                • Czech
                #487
                Re: RCUnlocker
                Hi, I have a problem with RCUnlocker. Checksum is still the same even after unlocking.
                • zelenborg
                  • Aug 2022
                  • 4
                  • Croatia
                  #488
                  Re: RCUnlocker
                  Yes, it is.
                  I am not able to upload files.
                  I will send the link to it.
                  Can somebody help me with unlocking?
                  https://files.fm/u/kvbsfna3p
                  • zelenborg
                    • Aug 2022
                    • 4
                    • Croatia
                    #489
                    Re: RCUnlocker
                    I have tried flashing chip on back side with method from the video i linked 3 posts above. But it is still asking for bios admin password. Also when i turn on the laptop it is showing company logo, not HP, but company that used to own that LAPTOP. might that be the problem why flashing did nothing?
                    Any help is welcome.
                    • asigasm
                      • Aug 2022
                      • 7
                      • Perú
                      #490
                      Re: RCUnlocker
                      Hi, does ir works for HP SWAT LOCK?
                      • peste
                        • Dec 2016
                        • 13573
                        • ROMANIA
                        #491
                        Re: RCUnlocker
                        read post #1..
                        • Mr.Snakeman
                          • Aug 2022
                          • 6
                          • Sweden
                          #492
                          Re: RCUnlocker
                          HP EB 840 G8 BIOS locked. Is the chip needing reprogramming a Winbond 25Q256FV on the underside of the board and is it the only one needing such work?
                          • Mazorca
                            • Jan 2017
                            • 463
                            Re: RCUnlocker
                            Post your bin file, I'll do the unlocking for you. If in doubt, post both bins, I'll figure which is which.
                            • Mazorca
                              • Jan 2017
                              • 463
                              Re: RCUnlocker
                              Originally posted by AAAC
                              @ogre4273
                              I've been modifying only the 32MB chip.
                              Dump and save the file 3 times, then check all 3 files are identical (if you use a utility like WinRAR or similar, you can ZIP or RAR the files, then open the ZIP or RAR resulting file, on the far right there's a column with CRC32 values, if all they match all the files are exact copies).
                              Man, I learned something good today, thank you, it will save a few minutes and lots of headaches if not done properly.
                              • tommybanjo523
                                • Jul 2022
                                • 3
                                • United Stats
                                #495
                                Re: RCUnlocker
                                Can you publish the source code?
                                • peste
                                  • Dec 2016
                                  • 13573
                                  • ROMANIA
                                  #496
                                  Re: RCUnlocker
                                  what problems do you have ..give me more details..which source code??
                                  • Mr.Snakeman
                                    • Aug 2022
                                    • 6
                                    • Sweden
                                    #497
                                    Re: RCUnlocker
                                    Thanks, now all I have to do is figure out how to make those bin files. I`m an utter newbie to all of this, so please bear with me.
                                    • Mr.Snakeman
                                      • Aug 2022
                                      • 6
                                      • Sweden
                                      #498
                                      Re: RCUnlocker
                                      In an attempt to learn more I downloaded the RCUnlocker rar file and using Zipware I extracted it as an .exe fil to a desktop folder. when I open the ,exe file in the bunch of files in the folder all I get is a white rectangle with three different colour one liners texts and nothing more happens at all. WTF? What am I doing wrong?
                                      • tommybanjo523
                                        • Jul 2022
                                        • 3
                                        • United Stats
                                        #499
                                        Re: RCUnlocker
                                        Hey RethoricalCheese could you publish the source code for this tool?
                                        • Johnson
                                          • Jun 2017
                                          • 9
                                          • Nigeria
                                          #500
                                          Re: RCUnlocker
                                          It doesn't open in my PC don't know why
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
