best cheap/free scores 1.1
This is a sticky topic.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: best cheap/free scores 1.1
    Originally posted by Topcat
    Today's freebie was a Dell Precision T5400 w/ 2x 5450 CPU's @ 3GHz, 16gb FBDIMM's, 1tb HDD, with a quadro 310. Working condition. Tossed Mint 20.2 on it... For some reason Mint only sees half of the 16gb RAM, but windows sees it all....
    Of course this post from it..
    Fixed the RAM issue...it was the usual crudded contacts.... Weird that BIOS showed all 16gb, windows would show all 16gb, but only say 8gb available.... Mint only saw 8gb. After cleaning contacts on all modules and slots, all RAM is there.
    Researching reveals this system supports crossfire....hold my beer, I'm gonna try something!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      #5062
      This horror of a board came in yesterday, with a horror LC-200C PSU no less.
      PCChips M726MRT if anyone's asking. It doesn't POST, though I might like to revive it just to see if their ALI Aladdin chipset implementation for 370/Slot1 is anywhere near good. Surprisingly filled with Teapos.
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
        • 31218
        it dont look too bad - but it needs a speaker soldered in.
        i dont know why they started leaving them off the board - how the hell are you supposed to diagnose the beep codes with no beep!
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          • Romania
          #5064
          You've probably seen the crappy L&C PSU bundled in the PC in the gutless wonder thread. My best guess is the PC was probably the cheapest thing you could buy in Romania ~1999-2002 (2002 because the PSU datecodes point to 2002 mostly)
          As for the beeper, I honestly don't quite mind it. I would rather use an external one than a mounted speaker, for the sole reason that onboard beepers sound muffled, for some reason.
          On another note: scored a JNC case (sans PSU and some MSI H61 mobo w/ celeron) and some remanants of a AMD FX-4100 build.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Confirmed. The T5400 and the T3400 both support crossfire.
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Not sure if this counts, but I'll post it.
              Best offered down a Lenovo Thinkpad T440s... 8GB DDR3 (4GB soldered + 4gb SoDIMM). 2.1GHz Quad i7. 1080p screen with one pixel line intermittent (was stuck red when I fired it up, but started working soon after). Keyboard missing the X key and the trackpoint. No chargers. After tax and shipping I got it for $135... perfect for replacing/upgrading my T440 from earlier in this thread that took a steaming dump on me a couple weekends ago (died in the middle of a youtube video); I transferred the SSD and chargers. Only real bummer is that the T440's keyboard is different enough that while the key cap transferred, it didn't fit right (too thin and wide). Oh well, that's what eBay is for!
              sigpic
              (Insert witty quote here)
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Today's freebies from a telecom engineer are:
                Old HP sweep marker generator.
                An old tube-type variable 500v @ 300mA x2 channels regulated HV DC power supply:
                Another regulated variable 0~36v @ 2a DC power supply:
                Some old radios.
                An old LED programmable sign..... "Cybernetic Data Products model ADT 7405", nothing out there on this thing. Programs through a serial port....but couldn't find any software. It does power up/work though.....
                The pick of the litter; 70's vintage Sansui 4 channel receiver amplifier...working but needs the usual pots cleaned (crackling volume control)...
                Not too bad!
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  The sign might use a serial console interface. Like you'd use with PuTTY. But without the serial parameters you'd be SOL.
                  sigpic
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Indeed.... I'll dig around before I pronounce it scrap.
                    Now let's have some fun!!
                    The sign and the 36v DC power supply.... That's all the sign does, probably the default if no programming. The PSU powered up.
                    I didn't put a load on it, but seems accurate. Has a cooling fan in it that's scraping on the case, I'll have to fix that.
                    Now for this engineer slayer! This thing could kill you real dead real quick if not respectful of it. Especially this one. Output 1 is malfunctioning.
                    Output 1 isn't dead; IE, no/low output...it's putting out way too much! With the rheostat all the way down it's ~300v.
                    This is about 3/4 the way up, maxing out my VOM. Any higher, it just displays o/l. I measured it with my scope wide open; it's safe to 2kv through the 10x probe. It topped out at 1450vdc! I didn't snap a pic though.....but below....yea, that's over a 1kv on the old GW.
                    Now for output 2, which appears to be functioning as it should. Rolled all the way to max.
                    What's on the gauge on par with the meter.
                    100v cal check....
                    7 volts off.....but who's counting....
                    My scope concurs with the meter by a .4v margin.
                    Rolled all the way down. Lowest it would go is 12v.
                    Lights out to see some glowy tubes!! This thing created some heat and of course had that 'smell'.....that glorious smell old electronics have when hot!
                    Rudolf with your nose so bright.....
                    That concludes today's free fun!!
                    Team : 49813
                    Join in!!
                    Team Stats
                      • 31218
                      the led sign probably has a leaked nicad battery in it - i fixed one before with that issue.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #5071
                        Niiiice!
                        Be sure to check the caps in it, if they are bad you might burn out the tubes...
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          And if you do pronounce it, I claim dibs!
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            Niiiice!
                            For sure. I also need to figure out why output 1 puts out nearly 3x what it's supposed to!
                            If I can't figure it out, it's got your name on it.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #5074
                              Maybe it is correct, don't you get 500v from positive to the center tap and then -500v from the negative to the center tap? (Edit: no, I see it says "bias" and not "CT" as I first assumed).
                              Also take a peek inside the unit, maybe it will have a electrical schematic attached somewhere.
                              But if it will have his name on it then you will have figured it out!
                              • TechGeek
                                Computer Geek
                                • Jan 2015
                                • 2254
                                What are you gonna do with the LED sign?
                                Permanently Retired Systems:
                                Kooky and Kool Systems
                                sigpic
                                  • 31218
                                  best thing to do with the sign is desolder the microcontroller / pia chip and fit an ESP module - then you can control it via wifi
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Went to an estate sale on saturday and scored a lot of stuff... automotive tooling, stuff for my wife, and a grill. One item I will mention though... for $10, an OTC Pathfinder scan tool set (OBD 1 and 2). Very well option and fully functional... until I broke the bleeping pin 25 in the main unit's DB25 connector. I tore it down, discovered it's an oddball obsolete Amphenol with a nonstandard 0.5" backspacing (flange to solder anchor center). Nobody sells it...
                                    I did find a lot of 49 NOS connectors of what looks to be a close (enough) match... $28 later and they're in the mail. We shall see if that fixes it... for now I jammed a piece of solid telephone wire in the pin's socket which works if you cock the plug.
                                    For $10... that's the best non-free deal I've gotten all year! These are rare and just the software packs alone are worth $90 per (what I saw on eBay). For OBD1 these are very handy to have... OBDII not so much (I have torque pro on my phone, and an Autel OBDII/ABS/SRS too already for newer stuff). When I told the sellers what that tool was (they didn't know), they lost thier jaws... and they still cut my wife and I some killer deals on other stuff! RIP to the mechanic and HVAC tech whose tools I was buying from... I will see they get put to good use!
                                    If anybody knows what the connector in the last pic is for, let me know. I have two ford EEC connectors (only one worked on my 1984 F150), two GM ALDL's (and a couple adapters, including the one for the oddball 1995's with ALDL on an OBDII connector), one chrysler, and one primtive OBD2 cable.
                                    sigpic
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      Today was another interesting day. It started with a phone call at 9:30am from a guy that had a 70" 4K TV hit by lightning and needed it checked out for his insurance company. He said I can keep the TV, he just needs paperwork for his insurance claim....ok, no big deal, I do this all the time....but the free 70" 4k isn't the whole story....just keep reading!!
                                      It was wall mounted and he was older, so I went to his house to pick it up. I got it down, loaded into my truck. Of course being wall mounted, the feet are missing.... :-/
                                      Anyway....I'm not sure if the mainboard or the power supply (or both) are bad.... Has red standby light, press power, the STBY light flickers for a split second, and that's it. Never does power up.....I didn't dig into it that deep....but it looks to have been buzzed. The power supply is missing some voltages and the processor gets VERY hot. It's a 70UH6350.
                                      Here's where it starts to get interesting....he asks since I took the TV, would I be willing to take some computer stuff his grandson left in his garage when he left for college a couple weeks ago that's out of state, and told him to get rid of it......of course he tells me his grandson is a computer expert and knew more about tech than all the instructors in high school, and builds massive PC's for everything short of NORAD (yawn yawn, I hear that all the time)....so I'm skeptically optimistic that I'll find some kickass system out in the garage.....well, it's complete....but at no point was it ever 'kickass'.....complete HP P3 system including CRT monitor, tower, KB/Mouse, disks, some other flatpanel monitor, and a box with some empty boxes that hardware came in.
                                      I was just going to pitch the box full of empty boxes in the dumpster....there was the box for a wifi router, a box for a NVMe SSD, a box for a 32gb DDR4 RAM kit, all empty....and then a box for a RTX 3070ti....and it felt a little heavy to be empty.....
                                      Ok, those of you that got excited and thought there was indeed a RTX 3070ti in there, sorry to disappoint you.....but it wasn't a total loss....
                                      This is what was in the box:
                                      Ok, I'm thinking the same thing you are; this thing has to be bad....nobody just tosses a 1070ti...even though gramps is a doctor......the card has to be bad....
                                      Well hmmm.... It's POST'ing...
                                      Installed the driver, no problems.....and even a little quake.... I did some other testing as well, it never missed a beat! WTF!! Is this kid really this spoiled?
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        #5079
                                        It started with a phone call at 9:30am...
                                        Hey, so did mine yesterday!
                                        But it wasn't about anything interesting.
                                        so I'm skeptically optimistic that I'll find some kickass system out in the garage.....well, it's complete....but at no point was it ever 'kickass'.....complete HP P3 system including CRT monitor, tower, KB/Mouse, disks...
                                        That's actually a pretty kickass system too!
                                        After all, it is all period-specific stuff, including the matching MS and KB... and CRT!
                                        Clean it well and hold on to it (especially if it's in very good condition.) The slightly older beige Compaq Pentium I/II cases with blue/purple plastic fronts (imitating those of the iMac PowerPC G3's, I think) can sometimes sell for crazy amount of money. With time, I imagine this one would too. Though of course it may be worth looking into the mobo and seeing if you can upgrade anything here or there... possibly the entire mobo with something else. HP/Compaq wasn't known for putting great performance motherboards or with many expansion options. So a more "open" P3 mobo could be nice.
                                        https://www.badcaps.net/forum/attach...1&d=1632175081
                                        TBH though, I've seen that kind of thing fairly often when I used to work at Microcenter - hardware that's no more than 4-5 years old getting tossed with no questions ask. And more interestingly, it doesn't seem to have any correlation to a person's wealth. I've seen both rich and poor folks throw good, perfectly working stuff away - stuff that could have easily fetched them a few $100. Not sure if it's laziness or ignorance... but yeah, it's pretty common. I guess companies are becoming more and more successful in turning us into a consumer throwaway society. :\
                                        Nice find!
                                        That actually sounds very relieving - I mean, if they guy could see you from the skies, I'm sure he'd be happy too his stuff isn't going to waste... or at least I would if some other CRT nut was to get ahold of my CRT monitors if I died.
                                        Some old radios.
                                        I'd say the pick of the litter is that tube 500V DC bench PSU. Surely you won't need that kind of voltage that many times... but when you do, it's nice to have.
                                        Reminds me I need to get back on my HP 6291A linear adjustable PSU. I haven't touched it in years and just always figured a way around when I needed a variable DC PSU. But it would be nice to have, as it's capable of 5 Amps at 50V (and spec even says 6 Amps at 60V with 120V AC line, which I do have.) I managed to get it to power up a few times after replacing the primary-side TRIACs (or were they SCRs? - I don't remember anymore), but it was unstable when supplying anything more than 6-7V at 1-2 Amps and only worked in the 0-50V selector. I think I goofed a bunch of wires around, but it's really hard to trace them, so that's why I've been reluctant to work on it. It's a beast, though.
                                        I was actually thinking the same exact thing.
                                        • Dan81
                                          SNES-powered
                                          • Oct 2013
                                          • 1866
                                          • Romania
                                          #5080
                                          I got to the point where I found a mint Voodoo3 3000 (and the 16MB TVOUT flavour no less) in nothing else than a shoebox full of other GPUs (MX440, FX5500, 7300GS and a few others) for almost $11. Same card goes for nearly $70 on classifieds.
                                          Main rig:
                                          Gigabyte B75M-D3H
                                          16GB DDR3-1600
                                          Delux MG760 case
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
