RCUnlocker
  • wildemo
    • Jul 2017
    • 2
    • Bulgaria
    #521
    Re: RCUnlocker
    Originally posted by Ghamidi
    Hi upload your EC backup
    Hey.Sorry im new in that is this EC?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12073
      #522
      Re: RCUnlocker
      In the first boot , you have to go into bios setting fo disable all the security options.
      • Udemzy
        • May 2017
        • 162
        • Guatemala
        #523
        Re: RCUnlocker
        Pls how can solve this issue,I've reinstalled the operating system, install a new vcruntime but I still get the same error message.
        • Ghamidi
          • Mar 2020
          • 303
          • France
          #524
          Re: RCUnlocker
          hi try dump of hoaca388
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #525
            Re: RCUnlocker
            Originally posted by Stefax2001
            I already reinstalled Microsoft Visual C++ 2015 Redistributable, nothing has changed.
            Originally posted by Vesko356
            Install both x32 and x64 files.
            Thanks, it worked.
            Become a Badcaps supporter
            Thanks to all supporters.
            • Udemzy
              • May 2017
              • 162
              • Guatemala
              #526
              Re: RCUnlocker
              Thanks, I'll try it.
              • sadenki
                • Feb 2018
                • 7
                • france
                #527
                Re: RCUnlocker
                Hi, need help with HP G7 430 with power-on authentication, RCUnlocker won't take 32mb and 16mb work in software but password still present when power on.
                Can someone give me a clue
                • peste
                  • Dec 2016
                  • 13159
                  • ROMANIA
                  #528
                  Re: RCUnlocker
                  use RCUnlocker only for the 16MB chip..the 32MB one remains the same..
                  • sadenki
                    • Feb 2018
                    • 7
                    • france
                    #529
                    Re: RCUnlocker
                    Thx for your help
                    Its not working, software take my 16MB dump, but when flash into IC laptop is still require password on power on :/
                    Here both version of 16MB dump (original and updated with RCUnlocker).
                    • ogre4273
                      • Mar 2022
                      • 57
                      • N/A
                      #530
                      Re: RCUnlocker
                      Hello, i've been trying to get a dump of my bios using wson8 pogo pin probe and ch341a. After sticking the probe to the bios chip, the lights from the laptop powered on for a split second. After I assembled the laptop, POST error appears (is it because I removed CMOS battery? not sure) but the laptop boots fine. Now, do i need to disconnect all the connections from the board before using wson8 pogo pin probe or should I continue knowing the first scenario about laptop lights and possibly might short something?
                      And another problem, after I connected the battery, the laptop automatically powers on, is it normal?
                      Also after I put the back case, the caps lock stayed on for a few seconds and can only be booted by plugging the laptop from charger. Hopefully I did not damage my laptop.
                      Thank you for your help.
                      • peste
                        • Dec 2016
                        • 13159
                        • ROMANIA
                        #531
                        Re: RCUnlocker
                        remove the bios chip from the motherboard before reading or writing the bios chip, don't use the probe otherwise you might have errors... if you don't have an adapter socket for bios chips stick the bios chip on the programmer, or wires between the chip and programmer.. the laptop starts without pressing the ON button because you removed the bios battery..
                        https://www.youtube.com/watch?v=DWWigscuQDY
                        • ogre4273
                          • Mar 2022
                          • 57
                          • N/A
                          #532
                          Re: RCUnlocker
                          thank you for your reply, now I can't boot my laptop. The charging led is blinking orange and white and the caps lock is blinking with long durations and whenever I put on the battery, it automatically turns on. What should I do now? any help please.
                          • sadenki
                            • Feb 2018
                            • 7
                            • france
                            #533
                            Re: RCUnlocker
                            So after some research, and as staded in my first post, the 32MB Main BIOS also need to be hex modify to be able to remove password on-power start.
                            I download couple of old and modify bit to understand what member modify, without succefully finding a method to remove it.
                            Can somebody lead me what should I modify to remove this dump "on-power password" that why customer don't set, and witch even HP with warrenty won't take it and ask ridiculous price to fix it ...
                            • sadenki
                              • Feb 2018
                              • 7
                              • france
                              #534
                              Re: RCUnlocker
                              You're welcome.
                              Yes, it is possible.
                              Hey do you know if it can also work to remove user password for "power on authentication" ?
                              Maybe I do thing wrong, but same as Smiler, tool work and say unlocked, but power-on authentication is still there, can't acces bios to reset, so still stuck
                              Same laptop as Smiler, G7 830
                              • DanielDacko
                                • Mar 2015
                                • 325
                                • Macedonia
                                #535
                                Re: RCUnlocker
                                Give this a try, flash only 32MB file, leave the 16MB untouched. And leave feedback if it worked.
                                I don't provide help for people using CH341A and a clip.
                                • sadenki
                                  • Feb 2018
                                  • 7
                                  • france
                                  #536
                                  Re: RCUnlocker
                                  First test, working fine, I don't want to reset security setting as I fear windows won't launch anymore, i gonna rebuild laptop and edit to tell if it boot into windows.
                                  Edit : No need to reset security setting, boot into windows just fine
                                  Thx a lot DanielDacko and RethoricalCheese for your awesome tool
                                  • DanielDacko
                                    • Mar 2015
                                    • 325
                                    • Macedonia
                                    #537
                                    Re: RCUnlocker
                                    Glad to hear that it works, not done by RCUnlocker as it doesn't support 32Mb files.
                                    • sadenki
                                      • Feb 2018
                                      • 7
                                      • france
                                      #538
                                      Re: RCUnlocker
                                      Big news, customers came in, try 3 times is windows password, couldn't find it, reboot twice, and TADAAA, power-on security kick in.
                                      So I gonna flash again with you modify bios, reset security and default setting, clean SSD, make a clean install and I should be fine
                                      • ogre4273
                                        • Mar 2022
                                        • 57
                                        • N/A
                                        #539
                                        Re: RCUnlocker
                                        Can I flash an older bios dump of the same laptop? because I updated the bios after saving and reading a dump.
                                        • peste
                                          • Dec 2016
                                          • 13159
                                          • ROMANIA
                                          #540
                                          Re: RCUnlocker
                                          yes.. you can write any bios version of the same laptop.. keep the original so you don't have problems.. and you can write it back when you want..
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
