RCUnlocker
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #541
    Re: RCUnlocker
    Originally posted by sadenki
    Big news, customers came in, try 3 times is windows password, couldn't find it, reboot twice, and TADAAA, power-on security kick in.
    So I gonna flash again with you modify bios, reset security and default setting, clean SSD, make a clean install and I should be fine
    I'm guessing it has something to do with windows autopilot. If it asks to log in to some company account after a fresh install and connecting to a network then it is so. Let's hope its not
    • ogre4273
      • Mar 2022
      • 57
      • N/A
      #542
      Re: RCUnlocker
      Originally posted by peste
      yes.. you can write any bios version of the same laptop.. keep the original so you don't have problems.. and you can write it back when you want..
      Does it work when I flash old dump on 32mb chip and keep the 16mb chip as it is?
      • peste
        • Dec 2016
        • 13759
        • ROMANIA
        #543
        Re: RCUnlocker
        what is your problem??? be more specific??? give more details..
        • ogre4273
          • Mar 2022
          • 57
          • N/A
          #544
          Re: RCUnlocker
          here is my problem in detailed explanation starting from post #29
          https://www.badcaps.net/forum/showth...ght=rcunlocker
          • farukCanada
            • Oct 2022
            • 5
            Re: RCUnlocker
            HP probook 450 g6 i5, s# 5CD8376KT0 , BIOS CHIP w25q128JVSQ - 1930/ Suddenly popup BIOS Password+ keyboardLayout /
            After BIOS write EZP3 program/ Power button not respond with battery or without battery/ Only orange light constant blinking/
            Is it keyboard issue?
            Or BIOS chip need to replace?
            Or Firmware file corrupted?
            Its my first time to ask help.
            My password blocked bios file is attached. RCUnlocker missing component to unlock. Anyone with big heart could you please check? I believe lots of people including me appreciated.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12420
              #546
              Re: RCUnlocker
              The backup file failed so RC unlocker can't work. Your file has been corrupted.
              • farukCanada
                • Oct 2022
                • 5
                Re: RCUnlocker
                Old_read1 for Password locked
                R71_012101 from HP website exe file extracted bin
                firmware from USB recovery disc.
                Could you please advise how to best use? Laptop not response with power button/ 2-3 pin shorted with Gound. Only deadly orange light blinking continues after battery/ charger plug-in.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12420
                  #548
                  Re: RCUnlocker
                  You have destroyed your own machine with your own hands. What to do now is to select a bios file here (https://www.badcaps.net/forum/showth...probook+450+g6) to get the machine working again.
                  • farukCanada
                    • Oct 2022
                    • 5
                    Re: RCUnlocker
                    is it possible to check bios file any virtual platform?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12420
                      #550
                      Re: RCUnlocker
                      Try this file
                      • farukCanada
                        • Oct 2022
                        • 5
                        Re: RCUnlocker
                        Bios chip Winbond 25Q128JV, is a complete analogue, compatible in all parameters with the MX25L12873F chip of another MXIC manufacturer.
                        The numbers "1930" on chip are the coded date of manufacture of the chip housing. 19th year, 30th week.
                        hoaca388 -- Huge Thanks. We can enjoy Long weekend. Machine boots normally.
                        • farukCanada
                          • Oct 2022
                          • 5
                          Re: RCUnlocker
                          Short 4 questions:
                          1.How can I collect RAW BIOS BIN file from running Laptop except remove/clamping BIOS.
                          2. How to test it in Virtual machine/plat form?
                          3. Is any editor/ compiler for BIOS file reading except hex( impossible to understand)?
                          4. How to add Logo spacial format? / Important message ??
                          • Albo89
                            • Nov 2019
                            • 6
                            • Italy
                            #553
                            Re: RCUnlocker
                            good evening at all
                            (Sorry for bad english)
                            I have a problem with a HP Probook 450 G4, board DAOX83MB6H0 REV H.
                            bios and power on with password.
                            i have do multiple bios dump, but NO work. i have do an image of varius data infos (attached).
                            Can someone help me?
                            thanks in advance
                            • peste
                              • Dec 2016
                              • 13759
                              • ROMANIA
                              #554
                              Re: RCUnlocker
                              Originally posted by Albo89
                              good evening at all
                              thanks in advance
                              all the bios posted are different..probably you wrote the bios chip with errors..remove the bios chip from the motherboard before writing or reading..do not empty the clip, it gives errors if the contact is not firm...what programmer are you using??
                              • Albo89
                                • Nov 2019
                                • 6
                                • Italy
                                #555
                                Re: RCUnlocker
                                the problem is that i empty the bios chip,
                                now, at powering the pc, the DC jack blink orange
                                • 1a1b1k
                                  • May 2022
                                  • 3
                                  need help for unlock hp zbook studio g8
                                  I have two 32mb flash on board .Both of them are winbond w25q256jv
                                  (both chip are same , no sign to recognize EC or main bIOS)
                                  I tried hp unlocker tool but failed to remove password .
                                  For RCUnlocker ,it can not support 32mb file .
                                  Could someon can help me?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12420
                                    #557
                                    Re: need help for unlock hp zbook studio g8
                                    In the first boot , you have to go into bios setting for disable all the security features.
                                    • 1a1b1k
                                      • May 2022
                                      • 3
                                      thanks ,I will test today
                                      • 1a1b1k
                                        • May 2022
                                        • 3
                                        Really thanks ,it works
                                        • Albo89
                                          • Nov 2019
                                          • 6
                                          • Italy
                                          #560
                                          Re: RCUnlocker
                                          someone can help me? thank you in advance
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
