RCUnlocker
  • hoaca388
    Badcaps
    • Jan 2022
    • 11620
    #561
    Re: RCUnlocker
    Originally posted by Albo89
    someone can help me? thank you in advance
    In the rar file you posted there are 4 backup files and they are all different, where do these files come from? Which file is the file from your bios chip?
    • adycrs
      • Jan 2020
      • 2
      • Romania
      #562
      Re: RCUnlocker
      No comment... except many many many thanks! Just read the chip with CH341 live (no need for solder/desolder) with clips, use the unlocked bin to write back and bingo... Job done! Another HP 440 G7 unlocked!
      • Albo89
        • Nov 2019
        • 6
        • Italy
        #563
        Re: RCUnlocker
        all files attached, are images of the bios, copied many times, before erasing the chip near the ram slot
        • jayasakti
          • Oct 2014
          • 1
          • indonesia
          #564
          Re: RCUnlocker
          Pleas help me to unlock bios hp probook 1014 G1
          • hoaca388
            Badcaps
            • Jan 2022
            • 11620
            #565
            Re: RCUnlocker
            Here
            • jackx
              • May 2020
              • 208
              • casa1
              #566
              Re: RCUnlocker
              thank you goods tool
              • NaneName
                • Sep 2022
                • 13
                • Russia
                #567
                Re: RCUnlocker
                Hi! What does "live" mean? Need to remove SSD and DRAM? What to disconnect and what to connect: power supply, battery and CMOS battery?
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11620
                  #568
                  Re: RCUnlocker
                  Disconnect : power supply, battery, cmos battery.
                  • NaneName
                    • Sep 2022
                    • 13
                    • Russia
                    #569
                    Re: RCUnlocker
                    hoaca388, thank you. But, in here the developer writes "DO NOT disconnect charger". I want to clarify - how is it right?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11620
                      #570
                      Re: RCUnlocker
                      Do not connect any power when reading the chip, the power to the chip is now provided by the programmer ( pin 8 is Vcc , pin 4 is Ground)
                      • nikola07
                        • Sep 2018
                        • 36
                        • Ukraina
                        #571
                        Re: RCUnlocker
                        good den. please delete the bios password. thanks
                        • hardware1
                          • Sep 2021
                          • 2925
                          • N/A
                          #572
                          Re: RCUnlocker
                          Here your unlocked file.
                          all donations are welcome,
                          • sonsy
                            • Mar 2017
                            • 62
                            • Serbia
                            #573
                            Re: RCUnlocker
                            Originally posted by zelenborg
                            I have tried flashing chip on back side with method from the video i linked 3 posts above. But it is still asking for bios admin password. Also when i turn on the laptop it is showing company logo, not HP, but company that used to own that LAPTOP. might that be the problem why flashing did nothing?
                            Any help is welcome.
                            What is the name of that test clip you use on the picture? Thay can read flat bios chips on hp?
                            • Sportsterv90
                              • Oct 2022
                              • 2
                              • Ukraina
                              #574
                              Re: RCUnlocker
                              Hi! My HP 8470p has BIOS Password. How can I unlock it?
                              • peste
                                • Dec 2016
                                • 12601
                                • ROMANIA
                                #575
                                Re: RCUnlocker
                                use RCUnloker (see post #1)..you also need a SPI programmer..you need to read the bios chip, delete the password and rewrite the chip...see more videos on the net..
                                https://www.youtube.com/watch?v=DWWigscuQDY
                                • Sportsterv90
                                  • Oct 2022
                                  • 2
                                  • Ukraina
                                  #576
                                  Re: RCUnlocker
                                  @peste
                                  Thanks for answer!
                                  I know about hardware method, I thought I can use RCUnloker without desoldering BIOS chip. Anyway, ThankYou for answer!
                                  • peste
                                    • Dec 2016
                                    • 12601
                                    • ROMANIA
                                    #577
                                    Re: RCUnlocker
                                    @peste
                                    Thanks for answer!
                                    you can not remove the bios chip from the board, but you have to stick wires between the programmer and the chip.. because with the clip from the programmer if you don't have firm contacts you will have errors..
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1517
                                      • Estonia
                                      #578
                                      Re: RCUnlocker
                                      Usually the clip is not the issue. For me atleast. I'm using the blue ponoma clip.
                                      WITH MY PROGRAMMER (raspberry pi), I connect power on Elitebooks in a certain way. Otherwise there will be errors. On Probooks, I still do connect power in a certain way but remove it after connecting the clip.
                                      This will not be the same with other programmers.
                                      Thatswhy, if you are not familiar how your programmer behaves with certain machines, it's always best to unsolder chip.
                                      With Dell Latitude and Lenovo Thinkpad for example, I do not connect power at all most of the times.
                                      So again, if in doubt, unsolder chip.
                                      • nc3000
                                        • Oct 2022
                                        • 10
                                        • Portugal
                                        #579
                                        Re: RCUnlocker
                                        Hi, did this tool work in HP 430 G6?
                                        Thanks.
                                        • LordMayros
                                          • Aug 2022
                                          • 1
                                          • Türkiye
                                          #580
                                          Re: RCUnlocker
                                          hello everyone,
                                          I have HP X Pro 612 g2, bios locked
                                          Do you have a recommendation for a suitable chip reader and writer to unlock this device?
                                          Also, is it possible to read the chip without removing it from the motherboard?
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
