Master power switch for E-bike ideas
    • 31288
    Re: Master power switch for E-bike ideas
    just put a fucking 2pole switch on it and stop over-complicating things!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #42
      Naah - too basic
      Wattevah...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8711
        I don't think you really can "take off" with the resistor regardless. Worst case it'll run really slowly and the resistor will burn out... Put an appropriately sized 100 ohm resistor there, you can't even get one twentieth of a horsepower out of the motor - that's not going anywhere fast.
        Could stick a 120V incandescent bulb there instead of a resistor...still not going anywhere fast, and really cheap.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          #44
          This is actually a good idea and I thought of it myself a while ago, though the resistance would be all over the place. It's bulkier too, so space is a bit of an issue. Not sure what the "idle" power consumption would be (with the FET off), because the bulb would be in series with the controller box all the time, so long as the battery's connected, but the resistance is probably high enough the power consumption would also be negligible, even with a stone-cold filament.
          Wattevah...
            • 31288
            bulk? use a linear halogen tube - they are like a short pencil.
              • Jul 2011
              • 6070
              Yeah but I would use a 250 watt version not the 500 watt version
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #47
                Might work. Would still need a holder for it....or I could go ghetto and solder to it directly I already grabbed a 50w resistor from Ali for like 2 bucks which has lugs on the end already. Like I said: no rush, since it's going to be another 4-5 months until I can go for a ride on this thing
                Because 250w = higher resistance ?
                Wattevah...
                  • Jul 2011
                  • 6070
                  Yes and less current than 500 watt would be
                  If you have an old light fixture that uses this type of bulb then you just need to figure out how to use the holders together so it will work maybe make it on a 3 D printer
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    PLA and incandescent bulbs of any type do NOT mix.
                    And no, don't use those high wattage halogens, you want low wattage bulbs for their resistance, like a 4W night light bulb... or less. Enough to charge the capacitors, not enough to run the bike in any capacity. Unless the intent is to give a thief a false sense of hope?
                      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 05:30 AM
                    • stormanimal83
                      Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
                      by stormanimal83
                      i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
                      08-04-2024, 01:47 AM
                    • G0RIT
                      Reebok one GT40s treadmill lift motor runs at switch on
                      by G0RIT
                      Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                      06-23-2022, 05:57 PM
                    • Natob82
                      Micro Momentary Push Switch?
                      by Natob82
                      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                      12-21-2022, 05:22 AM
                    • grimacelord
                      NEC TurboExpress On/Off Power Switch Replacement Help
                      by grimacelord
                      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                      11-09-2023, 09:49 AM
