WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
  • inflex
    • Aug 2012
    • 545
    Re: WANTED: Teboview / TVW file format specification to write OpenBoardview decoder
    The TeboView importer has begun its life...
    It'll take a few days probably before the first glimmers of an actual boardview will show up on the program but at least we're on a roll now.
    Many thanks to you all - didn't take as long as feared, at least not for the initial attempts
    Code:
    Switching to FlexBV logfile for further output
    19 bytes allocated for string
    Copying data to string
    Moving pointer ahead...Header 1: 'O95w-28ps49m 02v9o.'
    UKV 1: 1
    7 bytes allocated for string
    Moving pointer ahead...Header 2: 'G34vS4z'
    UKV 2: 0
    13 bytes allocated for string
    Moving pointer ahead...Header 3: 'Eksq dh, beeh'
    layer count : 22
    ukv 3: 2
    ukv 4: 2
    ukv 5: 16
    ukv 6: 0
    Layer start 3 2 1...
    14 bytes allocated for string
    Moving pointer ahead...Layer Name: SILKSCREEN_TOP
    Moving pointer ahead...Layer Name2: SILKSCREEN_TOP
    78 bytes allocated for string
    Moving pointer ahead...Layer Filename: E:\DFT\2016NPI\DG710\SVT\NSA912R10\NSA912R10-0329-FAB\cds2f_NSA912R10-0329.cad
    Layer ukv1 = 7
    Layer line colour: ffcbfecc
    Layer pad colour: ffcbfecc
    Layer ukv2 = 12
    Layer ukv3 = 1
    Layer ukv4 = 100
    Layer ukv5 = 100
    Layer contains 28 items
    Layer ukv6 = 0
    item start = -1
    id = 10
     x = 44164
     y = -59901
     x2 = 44164
     y2 = -79601
    item start = -1
    id = 10
     x = 44164
     y = -79601
     x2 = 63864
     y2 = -79601
    item start = -1
    id = 10
     x = 63864
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • mmu
      • Aug 2019
      • 28
      • France
      #42
      So yeah, with the current python code:
      cds2f_NSA911R0-0329.tvw seems to decode (but the next thing is unknown, so maybe…)
      NSB241R10.tvw decodes but it only has one surface on the first layer.
      cds2f_NSA912R10-0329.tvw fails to decode at the second Surface because there's an extra 4 bytes before the net ID:
      Code:
      == 2 surfaces
      ?    0x2
      Surface[0]:
      Net: -1
      === 13 edges d
      [[43307, -110945], [65945, -110945], [65945, -137795], [47244, -137795], [47244, -137794], [46225, -137660], [45275, -137267], [44460, -136641], [43834, -135825], [43441, -134876], [43307, -133857], [43307, -133858], [43307, -110945]]
      ???   0 0
      === 1 voids
      ?    0x1
      void(0):    26 edges
      (56103, -130895)
      (54577, -130694)
      (53155, -130105)
      (51934, -129168)
      (50997, -127947)
      (50408, -126525)
      (50207, -124999)
      (50408, -123473)
      (50997, -122051)
      (51934, -120830)
      (53155, -119893)
      (54577, -119304)
      (56103, -119103)
      (57629, -119304)
      (59051, -119893)
      (60272, -120830)
      (61209, -122051)
      (61798, -123473)
      (61999, -124999)
      (61798, -126525)
      (61209, -127947)
      (60272, -129168)
      (59051, -130105)
      (57629, -130694)
      (56103, -130895)
      (56103, -130896)
      [(56103, -130895), (54577, -130694), (53155, -130105), (51934, -129168), (50997, -127947), (50408, -126525), (50207, -124999), (50408, -123473), (50997, -122051), (51934, -120830), (53155, -119893), (54577, -119304), (56103, -119103), (57629, -119304), (59051, -119893), (60272, -120830), (61209, -122051), (61798, -123473), (61999, -124999), (61798, -126525), (61209, -127947), (60272, -129168), (59051, -130105), (57629, -130694), (56103, -130895), (56103, -130896)]
      Surface[1]:
      Net: 0
      === 4294967295 edges ffffffff
      • mmu
        • Aug 2019
        • 28
        • France
        #43
        \o/
        • mmu
          • Aug 2019
          • 28
          • France
          #44
          Ok, took some time to write up what I came up with from the python script and opened a PR.
          Do you want a PR for the script as well?
          • mmu
            • Aug 2019
            • 28
            • France
            #45
            Looking at the OBV build.sh… oh gee, why use so unportable things like /proc/cpuinfo? :-D
            • inflex
              • Aug 2012
              • 545
              Thanks for the PR. I've already pushed in some small changes too (the 3-2-1 sequence appears to be a header/lead-in as opposed to a suffix).
              All scrappy at the moment but it's definitely workable now for generating the source code.
              As for OBV, the build.sh is meant for linux and macOS, we don't really build on windows any more because it was making the development cycle too slow and we ran in to show-stopper incompatibilities when working with gcc as well as VS that just made everything a nightmare. Subsequently the build for windows is just done on linux with mingw64; makes everything vastly easier when it comes to cross-platform development.
              As for why the /proc/cpuinfo ... not sure what it's for, probably to determine the flags for the build within CMake.
              • mmu
                • Aug 2019
                • 28
                • France
                #47
                Great, let me know if you need more.
                Yeah, mingw works not too bad, I recall building VLC with it (quite slow though).
                I think most of build.sh can probably be done right in CMake though.
                Yes, it's a classic idom to detect the number of cores to do parallel builds, except it's very Linux-specific while there's a much simpler and portable method. I fixed this in MuseScore some years ago. I already proposed a patch in my Haiku PR. :-)
                • inflex
                  • Aug 2012
                  • 545
                  Many thanks. I'll PM you in a bit after this.
                  Likely so - for me, it's a case of "It still works, I'm not going to break it"
                  I saw that come through this morning - it'll likely be piernov who handles that as I am very much hands-off with OBV now. Put the years in to get it to a level and did the promotional work with/via Louis Rossmann, but after that is about when I forked off with FlexBV. I still push back things like file formats and bug fixes but aside from that I keep a fair distance now.
                  • inflex
                    • Aug 2012
                    • 545
                    I made the THREAD change on my own build.sh, so at least that's one file fixed
                    • inflex
                      • Aug 2012
                      • 545
                      I present to you... the very first image for TeboView decoder for FlexBV.
                      This is actually a board outline for the Lenovo X240 Yoga board.
                      • inflex
                        • Aug 2012
                        • 545
                        Interestingly, our sample file had a more complicated outline routing system. There's some segments that are prefixed with 0x08 instead of 0x0A, and with those you read only 2 int32's after the tool int32, and there's no trailing 0-value uint32.
                        I'll add that in to the documentation later.
                        I'm sure there's other little traps like that out there but we'll find them in due time.
                        • mmu
                          • Aug 2019
                          • 28
                          • France
                          #52
                          Yay!
                          • inflex
                            • Aug 2012
                            • 545
                            HeLP - Need MOAR Teboview files. Gotten to the point now that I need more files of different sources so I can cross-check/differentiate various flags/bytes.
                            Big or small - you can email them to me if you prefer, pldaniels@gmail.com
                            • inflex
                              • Aug 2012
                              • 545
                              Found something interesting, well, two things;
                              1) the loose 1-byte 0-value in the header sandwiched between two other strings is actually, as it should have been expected, an empty string. One of the new files I tried broke my parser and it was because there was a 3rd string in there.
                              2) Some TVW files are password protected when used in the official Teboview program, but the contents are not in any way encrypted that I can tell; it's akin to stopping people from getting in to an open space by placing a doorway in their face. Very interesting.
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                #55
                                There are different teboview programs. The ones which are password protected in one, are not in the other one.
                                Which of the files had the password? I think I can send you the right program, which doesnt ask for password.
                                • inflex
                                  • Aug 2012
                                  • 545
                                  Boardviewer doesn't let the password stop it, but the official Teboview v4 does.
                                  Lenovo\ Legion\ Y540-15IRH\ -\ NM-C221\ REV0.1\ Boardview\ /NS-C222.tvw
                                  It's just more amusing that it's not really doing any real protection, and in honest though, I'm *glad* it's not.
                                  On the upside, I've already worked out a few more of the header fields because of those new files, thanks.
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    #57
                                    Yeah, looks like these files were meant to be opened by boardviewer, not teboviewer.
                                    • DerekChen65535
                                      • Feb 2021
                                      • 3
                                      • inflex
                                        • Aug 2012
                                        • 545
                                        Originally posted by DerekChen65535
                                        Thanks for that - at least the outline renders on that one
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #60
                                          https://www.badcaps.net/forum/showpo...&postcount=354
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            Hi everyone,
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • testaccgta
                                            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                            by testaccgta
                                            Hi, everyone!
                                            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                            09-01-2024, 08:24 PM
                                          • Forest79
                                            Lenovo ThinkStation P520 BIOS file needed
                                            by Forest79
                                            I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
                                            The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
