Post help identifying capacitors here
This is a sticky topic.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    #41
    Re: Post help identifying capacitors here
    Originally posted by rattlesnake
    Beautiful, thanks again
    Welcome Friend ..
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      #42
      Originally posted by jiroy
      You always take the first value for Capacitance and the second for voltage , that's the standards .
      Depends. I've seen plenty of sleeve-less / SMD electrolytics capacitors labeled with the capacitance first and voltage second. Actually, most SMD polymers and electrolytics are labeled like that. Some won't even have a voltage on there, but rather a voltage code letter. So if there is any standard anymore, it surely doesn't seem to be followed very well.
      Thank you
      Does the "s" in "16s" mean volts? otherwise how can you tell what is what? I mean could there be a 10v 16uF cap? how would you tell them apart?
      The real teller here is the fact that 16 uF is not a standard capacitance value.
      Generally, the standard values for capacitance are 100, 120, 150, 180, 220, 270, 330, 470, 560, 680, and 820... multiplied or divided by any coefficient number of 10.
      So in the 10's range, you can have 10 uF, 12 uF (uncommon, but does exist), 15 uF, 18 uF (uncommon), 22 uF (very common!), 27 uF (uncommon), 33 uF, 47 uF (very common!) 56 uF, 68 uF, 82 uF... and a wrap again at 100 uF (10 uF x 10).
      In contrast, voltage ratings follow a slightly different set of values.
      For voltages below 10V, the common values are 2.5V, 4V, 6.3V, and 10V.
      Between 10V and 100V, it's 16V, 25V, 35V, 50V, 63V, 80V, and 100V...
      And for higher values, it's the same number multiplied by 10.... though there are a few additional values, like 200, 220, 315, 400, 420, and 450.
      • rattlesnake
        • Dec 2017
        • 78
        • Argentina
        #43
        I thought so! But I wasn't familiar with all the values you described. Thank you for taking the time to enumerate them all. I'm sure I'll come back to this post some day.
        • mach128x
          • Jan 2023
          • 3
          I need help identifying this manufacturer.
          On the logo the letter "m" is pretty obvious, with what could be the letter "L" attached under it (or just some hockey-stick looking graphical swoosh).
          I’ve search capacitor.web.fc2.com and spent hours in google image search, to no avail.
          Thanks in advance.
          It's a 220 uF 16V from the switch-mode power supply inside an M-audio studio monitor. I suspect a low-ESR...
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            #45
            If it's in a SMPS, it probably is (or should be) low ESR.
            But don't worry about identifying it or finding a datasheet for it. I stopped bothering to look up obscure manufacturers a long time ago. In all cases, I just use a low ESR capacitor from a known good Japanese brand (like Panasonic, Rubycon, Nichicon, and United Chemicon.) Never had issues replacing these obscure brands by such. In fact, these no-name garbage caps are so bad, that sometimes I've used very old Japanese general purpose capacitors for a repair or two, and even those have lasted longer than the cheapo caps.
            • mach128x
              • Jan 2023
              • 3
              I understand your point.
              True, my hope was to find the original ESR rating, to find something in the same ballpark.
              I was going to replace it with a good quality one in any case, for sure.
              The question then, however. What's a good "low" ESR ? I've been told there can be such a thing as "too low" depending on the application. This particular cap sits on the output side, btw. (maybe this isn't the right section of the forum to discuss these details)
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                #47
                Well, for the output of PSUs, generally you want to avoid the lowest ESR series... but even then it depends on the PSU, or rather its design.
                Discontinuous / flyback designs (you can distinguish those fairly easily, as they don't have an output toroid after the rectifier(s)) don't care about too low of an ESR. They may get a little more noisy (as in, audible noise and not necessarily electrical noise) with very low ESR caps. But apart from that, they would work fine.
                Continuous designs, on the other hand (these you can identify by a large output toroid inductor after the rectifier(s)) can be a little more picky. So with those, it's better to avoid the lowest ESR series, unless the PSU uses such already.
                Which brings us full circle back to your question: how would we know what kind of "low ESR" caps the PSU used if we can't identify them?
                - IME, I just haven't seen any of the no-name manufacturers to offer very low ESR caps. At best, they might have something that resembles United Chemicon KY or Nichicon HE or Rubycon YXG (which would be considered "mid-grade" low ESR more or less)... but almost never, really. More often than not, a cheap manufacturer's "low ESR" series will be barely a notch better than general purpose series from the Japanese manufacturers. The "better" ones might be comparable to entry-level low ESR series like Rubycon YXJ, Nichicon PS/PM/PW, UCC LXY/LXV, and Panasonic FC.
                So this is why I don't bother to look up obscure brands anymore. I just pick some caps anywhere between entry-level low ESR and "mid-grade" low ESR, and know that I will be pretty safe with that choice. If I feel experimental (or if it's a discontinuous/flyback design), I sometimes go with very low / ultra-low caps that I might have on hand... and even with those, I haven't had any issues. At worst, I've had one or two flyback-based PSUs just "whine" a little more when lightly-loaded or in standby mode.
                • kalemaroni
                  • Jun 2016
                  • 176
                  Can someone identify this cap for me please?
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    #49
                    It's 100 mF , 25 volts ...
                    • kalemaroni
                      • Jun 2016
                      • 176
                      Thanks - and the 7H bit doesn't matter? Will any package do the job?
                      • jiroy
                        • Jun 2016
                        • 2416
                        • Lebanon
                        #51
                        That a code for the manufacturer series . No , not any package , this is a SMD Capacitor and not TH one (through hole) .
                        • kalemaroni
                          • Jun 2016
                          • 176
                          Thank you very much
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            #53
                            Thank you very much
                            Welcome friend ; I left the choice of online order location to you as convenient . Otherwise , do tell .
                            • failuresuccess
                              • Feb 2023
                              • 3
                              Hello all, I'm in the process of trying to restore a motherboard for a 1993 IBM PS/1. I'm looking to recap and so far they all appear to be Nichicon electrolytic caps. I believe they are 68uf 16V, 22uf 50V, and 2.2uf 50V. However, I can't figure out the model number is to get their exact specs. Please see the attached image and any advice would be much appreciated.
                              • lti
                                • May 2011
                                • 2547
                                Those blue Nichicon caps are VX series, but I've never seen a datasheet for the radial version (only axial). They're just plain 85°C caps, so specs don't really matter (especially since they're 30 years old and probably still good unless they're leaking). There are places where ESR can be too low, but that isn't likely on a motherboard like that.
                                If an unknown series of a known brand counts for this thread, I found a power supply with G-Luxon LM series caps. I don't know if they're actually bad, but that computer had some weird cold boot problems. I'd lean toward these just being general purpose caps, and I really don't want to recap this thing anyway. It has a buttload of tiny caps, mostly 1uF in a mix of 16V and 50V for some reason.
                                • failuresuccess
                                  • Feb 2023
                                  • 3
                                  Hi Lti,
                                  Thanks for the insights! The reason I was considering replacing the caps is that the motherboard over the past year has gotten more and more flaky to the point of no longer POSTing. I pulled all the hardware and tried booting with different cpus and memory with no luck and the PSU checks out.
                                  That said do you have any concerns with the following caps?
                                  68uf
                                  https://www.mouser.com/ProductDetail/710-860010372005
                                  22uf
                                  https://www.mouser.com/ProductDetail/594-MAL203851229E3
                                  2.2uf
                                  https://www.mouser.com/ProductDetail...D225M050JA6AE3
                                  • lti
                                    • May 2011
                                    • 2547
                                    Those will work, but the last two are a little expensive.
                                    • failuresuccess
                                      • Feb 2023
                                      • 3
                                      Awesome, thank you so much for your guidance!
                                      • MrWizzard
                                        • Feb 2023
                                        • 6
                                        Hello, new user here. Trying to find what capacitor to replace a couple capacitors that went bad today, heard a double pop at power on and found 2 that are bulging and were hotter than others. New to all of this, trying to teach myself how to do this rather than buy a new used MOBO.
                                        The mobo is a Intel D845GEBV2. I tried searching the forum and only found 1 question about a different capacitor on this board.
                                        Here is a picture of them. I see the letters HD Z4 1000 16V and that is it. Does not have the writing on them that other capacitors have to identify them. Can someone help tell me what I should replace the bad ones with?
                                        • lti
                                          • May 2011
                                          • 2547
                                          Nichicon HD 1000uF 16V
                                          Nichicon decided to discontinue a lot of parts, so get then while you can. Nichicon's datasheet doesn't have that value marked as "not recommended for new designs," but Digikey does. Rubycon ZL looks like a decent alternative if they do disappear.
                                          • varkatope
                                            Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                                            by varkatope
                                            Hey there, retro fans.
                                            I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                                            12-15-2024, 09:48 AM
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                          • slybunda
                                            AA and AAA battery charger capacitors?
                                            by slybunda
                                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                            it has inside:
                                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                            2 x 470uf 16v LZ105c branded as G.Luxon
                                            not heard of these brands are they any good?
                                            iv attached photos of the charger and the board inside for an idea on the type of...
                                            12-24-2023, 04:41 AM
                                            Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                            by sam_sam_sam
                                            I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                            This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • Ady2017
                                            Are there any datasheets available for Elna RJG capacitors?
                                            by Ady2017
                                            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                            05-25-2025, 02:19 PM
