Cap Datasheet Depot
This is a sticky topic.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    #41
    Re: Cap Datasheet Depot
    Dang...Thanks!
    Follow the white rabbit.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      #42
      Originally posted by jazzie366
      I've attached the capacitor datasheets for the brand Elcon, after finding that others have had them fail and I couldn't find the DS for them. All datasheets for all currently made series as of 6/20/17.
      From my findings a few years back, Elcon and Samcon are either the same company or one owns the other and they have closely-related products. Elcon EEZ was used quite often on low-end XFX GeForce 9 series video cards and it burst the same way as Sacon FZ.
      Now, it gets even more interesting, because XFX used to often use Sacon FZ on their mid- and low-range GeForce 8 series of video cards. And before that, XFX used Evercon and GSC.
      So where I am going with this?
      GSC changed names to Evercon, which then became Sacon, because they were all utter garbage. Then Elcon came along and died the same way as Sacon... so I'm pretty certain Elcon is just another name for Sacon... and I also have a few screenshots of their website showing Elcon and Samcon factories on the same page.
      In short, most likely:
      GSC = Evercon = Sacon = Elcon = Samcon = ...GARBAGE
      So don't use them!
      I do appreciate you posting the datasheets, though. Might come in handy when needing to replace one of these. Although, the truth is I've seen Elcon EEZ series appear good and measure worse than general purpose 85C caps (that was on a GeForce 9400 GT video card). What I find even more amusing is that Panasonic FM and FR easily beat the crap out of both Sacon FZ and Elcon EEZ in terms of specs... and FZ/EEZ is supposed to be a "high ripple, low ESR" series.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #43
        Yup, this old thread needs updating it seems
        https://www.badcaps.net/forum/showthread.php?t=3369
          • 31283
          just say "the only good 'con' is a RUBYcon"
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #45
            What about NICHIcon? I wouldn't consider them bad. They just had a bad run of HM/HN/HZ for a few years, but they've fixed the issue since and until they finally stopped making them.
            Interesting read. I'll look for the screenshots I made that link Samcon with Elcon.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              #46
              Despite the mass KZG / KZJ failures, I also still consider Chemi-con to be a good brand. KZJ was discontinued a decade ago now. No idea if the issues with KZG were ever fixed before discontinuation, but "for what it's worth", I haven't seen a prematurely failed KZG with 2009 datecodes and newer, which says something considering the "bad" KZGs (made from 2001 to 2008) started failing around 2005 to 2011 after a few years of discontinuous use in moderate to high heat environments.
              I think Suncon (formerly Sanyo's electrolytic division) is good too, despite a couple bad series / runs from them. I've seen a couple datasheets for Sacon FZ (easily found on Google ). One claims them to be of ultra low-impedance grade like Nichicon HM. The other, closer to Nichicon HD. I wouldn't stake my life on either claim, however.
              • RukyCon
                A Fake Rubycon
                • Jan 2017
                • 816
                Here are some newer datasheets from the brand sunion/threecon.
                I made sure that only ones you don't have yet made it in.
                I'm not a expert, I'm just doing my best.
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  Here is a new one, TOPAZ.
                  One problem, they don't have PDF versions of any of their datasheets. You can only view them on their website.
                    • 31283
                    NOT TRUE.
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      Originally posted by stj
                      NOT TRUE.
                      It's still not a PDF.
                        • 31283
                        so what?
                        besides, you could convert them if it's that important.
                        • jazzie366
                          • May 2016
                          • 304
                          Alrighty, I did some digging and found the websites of some known shit cap makers. Only problem is they don't post the datasheets, but some post the specs. Also, a lot of it is broken website.
                          Broken Website/No Datasheet:
                          http://yzpsttech.com - Website has pictures of datasheets, nothing more, they are also extremely low resolution.
                          http://www.amazingcap.com - We've seen these caps numerous times before, usually in LED bulbs.
                          http://en.tfntc.com - Broke AF.
                          Working website/datasheets available:
                          http://www.guochang.com.cn/en - Datasheets attached, not seen this one before at all.
                          http://hxcapacitor.com/en - Not seen these either, datasheets attached.
                          http://www.jiaye.com.cn/html/en - Working website, datasheets on website in image form, I don't have a decent image to pdf converter, nor do I use office programs much so someone will need to convert these. We've seen this brand a lot.
                          Last edited by jazzie366; 09-21-2017, 10:11 PM. Reason: Forgot to attach all the things.
                          Popcorn.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            #53
                            NOT TRUE.
                            funny, I was going to take the raw pictures and use windows 10 PDF printer. But yeah JPGs are just as well
                            all uploaded, thanks everyone
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              Still waiting for ymin.
                              Here are all five files full of datasheets.
                              [I would have made it one if it would let me.]
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5045
                                • US
                                #55
                                Thank you. Sorry about that. When I got the new laptop I didn't have my old copy of WinSCP with the saved password.
                                i'm uploading it now
                                • jazzie366
                                  • May 2016
                                  • 304
                                  GRP updated there datasheets and added 1 new model of capacitor. Found they also have two websites, new datasheets and series were found there.
                                  Popcorn.
                                  • jazzie366
                                    • May 2016
                                    • 304
                                    Kingtronics upload. I've dealt with components from these guys before, never seen their caps though. Everything else they make is great as far as I know, I hope their caps are the same.
                                    Popcorn.
                                    • RukyCon
                                      A Fake Rubycon
                                      • Jan 2017
                                      • 816
                                      More datasheets, these ones are by a capacitor company named nantong sanxi AKA SAX.
                                      SAX does not have PDF versions of any of their datasheets just like Topaz so all of the datasheet are Jpegs.
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5045
                                        • US
                                        #59
                                        uploaded. Thank you. Wish they had bigger JPG's though
                                          master hoarder
                                          • May 2008
                                          • 12175
                                          • Bulgaria
                                          #60
                                          Here's one I don't see in the depot: Nichicon KA (audio-grade cap). Datasheet can be found here:
                                          • electomech-fixer
                                            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                            by electomech-fixer
                                            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                            09-15-2025, 01:42 AM
                                          • SoulFreeze
                                            Help finding datasheet for component marked G34662
                                            by SoulFreeze
                                            Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
                                            Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
                                            Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
                                            05-01-2025, 03:56 AM
                                          • Rainbow_Chameleon
                                            Searching Datasheet for AM113 IC by O2MICRO
                                            by Rainbow_Chameleon
                                            I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
                                            Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
                                            If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
                                            On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
                                            So if anyone has a datasheet or at least...
                                            01-23-2025, 12:03 PM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                          • evgental
                                            HP prodesk 400/600 G6 mini schematic/datasheet
                                            by evgental
                                            Hey everyone,
                                            I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
                                            Thanks a lot!
                                            08-04-2025, 04:58 PM
