[FAQ] Atten 858d problem S-E (or 5-E) or stuck in 498'C.
    • 30979
    Re: [FAQ] Atten 858d problem S-E (or 5-E) or stuck in 498'C.
    you have 4 wires,
    2 are the element that is exposed.
    the other 2 are the sensor.
    • redwire
      • Dec 2010
      • 3906
      Thermocouple (+) is the skinny red wire, it is unique because a magnet will stick to it- it's iron. You will also get continuity to the thermocouple tip at the end.
      • clearchris
        • Dec 2013
        • 687
        These machines are really hit or miss. I'm looking at getting a T12 soldering iron station, it seems that kgser is the original hakko copier and seem to have the best ones. Eruntop looks like they make their hot air stations, but I'm not vouching for either. I got my hot air station off ebay some time ago, it has been ok, with some notable issues (fuse on neutral)...
        • sepica
          • Sep 2021
          • 1
          have too one atten 852+ which has worked ok for several years
          now has decided to not going sleep anymore
          it heated properly and cooling down when put on rest
          but display jumps from temp to temp and not going a sleep
          maybe someone faced same?
          br
            • 30979
            check the cable for breaks if it's old - i'v seen that lots of times on soldering irons.
              • Jul 2011
              • 6033
              Originally posted by senndogg
              Its only a week i have been working with my new Atten 858D+ heating station and i have experienced a problem. The station showed S-E in the digital display, the blower fan was ok but it was NOT heating. Searching the web showed that the heating element was gone, this was an error code, but it was not true. Measuring it showed 70 Ohms. Also the mosfet which drives it was not shorted. The station was also stuck in 498'C sometimes, again no heat.
              Browsing again and saw some unresolved topics, there is one at a well-known polish forum. Mine is in warranty too but i was not thinking about shipping it ti China.
              After close inspection at the small circuit in the gun, i could distinguish a cold joint at the soldering of the thermocouple sensor. Bingo!
              Now the heating is working great again!
              Thanks for reading.
              First pic is the Atten 858D+. At the moment it is OK, SLP means "sleeping".
              Second pic is the culprit.
              If I were doing this repair I would resolder all of the joints on this board
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                #47
                today got an 858d that was not heating and after a while give error H-E or H-3 (cant remember if it was down facing). after resolder old solder, check resistor, thermocouple, try another termocouple i ordered the tric bat12 800b. after that i measured all wires (8 wire) to just be sure it was not a wire problem and guess what ? black wire not reading continuity.... now i have ordered 8x0,5mm cable 10meters for 17€ need also those arduino cable terminal to put them back properly
                edit: have to check cable thikness .. maybe 0,5mm are too small
                  • 30979
                  arduino?
                  you mean Dupont terminals?
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    #49
                    Originally posted by stj
                    arduino?
                    i mean the female wire terminal plug
                    • Crystaleyes
                      • Sep 2021
                      • 493
                      • Brazil
                      #50
                      I realise this thread is somewhat old, however I have had problems with an Atten 858D+ which stopped entering sleep mode, and found a solution which might help someone, someday?
                      The problem started after the unit was lent to a friend and the only way to get the heater to chill out was by holding the heater gun above where it was sitting naturally.
                      After failing to locate the reed switch, the situation was resolved by putting a thick band of tape onto the heater handle so the the gun sat about 20mm, or 3/4's of an inch, higher up in the saddle.
                      It's not pretty, but it was done about two years ago and it is still working fine.
                        • 30979
                        maybe the plastic moved on the metal bracket?
                        or the magnet got loose inside it.
                        • Prott
                          Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
                          by Prott
                          Hello fellow Badcappers,
                          I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
                          I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
                          Thank you!
                          03-01-2024, 08:23 AM
                        • stormanimal83
                          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                          by stormanimal83
                          Hey....
                          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                          01-18-2024, 02:15 PM
                        • ekozeko333
                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                          by ekozeko333
                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                          🔥 The Problem Started After Suspected ESD/PD Fault
                          I experienced a power issue or ESD event through a USB-C charger
                          After that, the NX20P5090 power switch was visibly burned and was replaced
                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                          🧠 What I’ve Done So Far
                          Flashed...
                          06-21-2025, 02:48 AM
                        • EasyGoing1
                          The best way to drive a heating element?
                          by EasyGoing1
                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                          This is the general setup that I have now.
                          This is what the...
                          01-25-2023, 11:29 AM
                        • dbuergi
                          Need assistance for reballing / replacing i5 CPU on a Macbook A1466
                          by dbuergi
                          i have some A1466 logicboards for gaining soldering and electronic experience. One board has a dead CPU and since i have several spares i want to change it. Unsoldering it was no problem but heat from the top showed that the CPU bent. I think too much heat was the problem.
                          So for unsoldering my spare parts and soldering back i would ask for some advises.
                          On most youtube videos you don't get any temperatures. Only helpfull video was one where the heat came from the bottom.
                          I have a small USB heating plate and a Atten ST-862D with several nozles.
                          06-27-2025, 02:59 AM
