ESR meter upgrades
This is a sticky topic.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: ESR meter upgrades
    Good to know. Thank you. I am happy with the project.
      • 31304
      i'm wondering if an adapter could be made for testing optocouplers.
      after one gave me some agrivation yesterday!
        • 31304
        update
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          That oughta be doable but I think you'd need a 4th test lead configured so you can flash the led side with two leads and check the conductivity of the phototrans side with two in order to preserve isolation. If you weren't concerned about complete isolation I think you could do a basic test with three leads using one common for both sides of the coupler.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            update
            Do you have the makefiles for these updates?
              • 31304
              obviously, i had to make them up.
              it's not just the makefile,
              the source is here:
              https://www.mikrocontroller.net/svnb...ster/Software/
              the files i'm changing are:
              the makefile,
              Transistortester.h < to change the version string,
              function_menu.c < to make the rotary encoder work better in the menu.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Well, I figured you did but what I mean is I want to know more about what you've changed because I'm more curious than can be satisfied with "something vague" as a change description.
                  • 31304
                  update
                  this one fixes a bug wih BJT transistors.
                  put the makefile in now
                    • 31304
                    on the makefile i had to change the lcd contrast, the battery sense voltdrop, the rotary & serial settings.
                    maybe the pullup resistors - cant remember - you can diff it now.
                    on the menu code, i just commented-out all the code that tried to interpret the button duration to do menu up/down so it just does "select" now.
                    **which is why i say not to use this on a unit without the rotary encoder - you wont be able to navigate the menu!
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Very cool, thanks much. I haven't updated since I got mine going, been dealing with other non-tech matters lately. I really appreciate the time and energy you put into this project. I know you dig doing it anyway but you've certainly got my gratitude. Thanks buddy
                        • 31304
                        wow!
                        read this:
                        https://github.com/svn2github/transi...32dbf07841d6a8
                        time to upgrade the crystal from 8 to 16Mhz
                        and fresh from the compiler
                        8 and 16MHz versions
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          Trippy. This project goes on and on... cool. Any particular spec on the 16MHz xtal or will any do that fits?
                            • 31304
                            same size as the original
                              • 31304
                              new update.
                              cleaning up the new crystal tester function.
                              Last edited by Per Hansson; 02-10-2016, 07:29 AM. Reason: Removed rev632 due to post below
                                • 31304
                                dont download 632 - i made a slip wih the menu code!
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  Is there any advantage to using a 16MHz over the 8MHz other than for crystal/resonator testing?
                                    • 31304
                                    probably not, although it may increase the range of the frequency generator function.
                                    it will also flatten the battery a little faster.
                                      • 31304
                                      another update.
                                        • 31304
                                        quick warning, dont upgrade to a 16MHz crystal if you didnt already.
                                        i'm looking into if the atmel can be run as nature intended - at 20MHz
                                        • SteveNielsen
                                          Retired Tech
                                          • Jun 2012
                                          • 2327
                                          Ok. I'm not going for the xtal upgrade yet and I'm at SVN630 for now. I haven't had any need to test xtals or resonators but it'd be fun anyway I suppose.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
