CH341a - Questions
  • Haris27
    • Mar 2023
    • 8
    • Pakistan
    #41
    Re: CH341a - Questions
    Just cut wires and I will solder it after a while. I also think that I discovered another problem. The LED on the power place seems to be missing like there is a visible difference between the Power and Run LED. I think that's the problem. like it got damaged or it was the production error not sure.
    now I can't even return it lol 😅.
      • 21986
      now I can't even return it lol ��.
      How did you manage to cremate those wires
      • Haris27
        • Mar 2023
        • 8
        • Pakistan
        #43
        I didn't solder these wires. i just burned a little bit of the wire so the metal part is exposed. now, as soon as i get a soldering iron i will solder them onto the gold pads.
        • harp
          • Jun 2022
          • 644
          • Planet Earth
          #44
          ... as soon as i get a soldering iron i will solder them onto the gold pads.
          Maybe before that you should practice a little bit on some irrelevant PCB...
          Just saying...
          • cheeky2
            • Dec 2012
            • 338
            • uk
            #45
            You aren't missing any parts from your pcb.
            As stated by another member here you will have to remove the flash ic from the board and read the data from it (without anything else attached to it).
            Then get the data from (the data dump) of the flash ic with the password removed. Then reprogram the flash ic with the corrected data.
            Then resolder the flash ic onto the laptop board and try.
            Any other option will not work
            Though I suspect you may not be capable of doing so considering you don't have a soldering iron or I guess a hot air station for removing the flash ic. Though you could use chip quik low melting solder to remove the flash ic.
            If your not sure of any terminology I have used I suggest using google and youtube to teach yourself.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
              How to add chip support to NeoProgrammer software for the CH341A Programmer
              by SMDFlea
              Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
              and once you do find them there`s a few crucial steps missing.
              Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
              Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
              After adding the chip save the xml file and copy it to the root directory of the...
              05-26-2024, 07:15 AM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • intelg
              HP Elitedesk 800 G6 lost BIOS admin password
              by intelg
              Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
              Here is the hardware identification specs:
              HP EliteDesk 800 G6 Desktop Mini PC
              Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
              BIOS ver S21 Ver. 02.05.01 01/05/2021
              Born on date: 07/26/2021
              SN MXL11841GN
              SKU 3X8V9UCHABA
              UUID 8116E79EF6FFE94DB0B98A3188270C5C
              SYSTEM BOARD ID 8710
              SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
              11-03-2023, 02:05 AM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
