Hacking the Uni-T UT210E
  • bobale
    • Aug 2018
    • 14
    • Serbia
    #41
    Re: Hacking the Uni-T UT210E
    I haven't even gotten to oppening it, let alone hacking it. But it looks like it is going to stay without MIN/MAX function. For the price it is good anyway.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #42
      Originally posted by stj
      to use min/max on a meter you first need to enable manual ranging - not autoranging.
      maybe that's the issue?
      That seems to happen automatically on another Uni-T I've got that has MIN/MAX out of the box. I'm not sure the same happens if it's not meant to have the MIN/MAX feature and you're trying to patch the button in.
      Wattevah...
        • 31310
        if i had a spare meter with that chip i'd experiment with adding all the buttons, but i gave my spare aneng to a friend.
        • domix
          LG Air Conditioner AC unit bypass
          by domix
          i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
          Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
          how can i bypass this :/
          I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
          11-25-2025, 02:54 PM
        • chth96
          Is it possible to test small ceramic disc capacitor with analogue meter?
          by chth96
          I read EBOOK of Testing Electronic Component and found that
          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
          Is it really possible to test small ceramic disc capacitor with analogue...
          03-09-2024, 10:03 PM
        • ngml
          Repair of an LG split AC system indoor unit PCB
          by ngml
          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
          This indicates an error in the communication between the outdoor and the indoor unit.
          The outdoor unit is fine, so the problem is the indoor PCB.
          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
          Does anybody have the schematics of this board,...
          02-01-2025, 12:55 PM
          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
          by sam_sam_sam
          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
          12-31-2023, 06:04 AM
        • Ryan Wurtz
          Lenovo Yoga C740-15IML 5V on usb meter.
          by Ryan Wurtz
          Hello. So I searched and didn't find any posts on this specific problem.
          When plugged in USB power meter reads 5v
          Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
          Original mobo had a shorted cpu it seems.
          So I decided I need a new motherboard.
          Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
          5v on the meter. Still won't charge. Can still charge the battery...
          11-24-2025, 01:08 AM
