Asus Q502L does not boot up properly
  • tibimakai
    • Jan 2012
    • 3680
    Re: Asus Q502L does not boot up properly
    Pretty cool this boardview software.
    It looks like, it is 0603 size, 120V/2A ferrite bead.
    • tibimakai
      • Jan 2012
      • 3680
      PL8100 and PL8101 are oscillating.
        • 21446
        PL8100 pin 1 goes to pin 8 of PU8100 . PL8101 goes to (amongst other parts) PU8100 pin 18,so they both have that in common, and pin 12 of PU8100 is connected to AC_BAT_SYS ,pin 1 L4510 the inductor ! . Heres a datasheet for PU8100 https://cdn.badcaps-static.com/pdfs/...bc7e0fa746.pdf
        • tibimakai
          • Jan 2012
          • 3680
          The display is not connected, though. I work only on the motherboard, everything else is disconnected, except for the little board that contains the power on switch and a separate board, that has the LEDs on it.
            • 21446
            You said 2 of the LVDS pins were bent,they could have been shorted and thats why L4510 got damaged, and it could have damaged PU8100. Check PU8100 voltage , pins 3,8,13,18
            • tibimakai
              • Jan 2012
              • 3680
              I have forgot that the battery it was still plugged in, and when I have removed the connector, I have seen a spark coming from the L4510.
              This is not the initial fault. This did not change anything. The laptop, it was doing the same thing, before as well.
              What I don't understand, why after the BIOS re-flash, the laptop is not doing what did before?
              It used to spin up the fan(RPM was changing up and down, than settled at high RPM, the power LED it was on, charging LED it was on, when it was plugged in, now it is different).
              I will take those measurements, later on.
                • 21446
                "RPM was changing up and down, than settled at high RPM" That can be the ME area of the bios. The new bios from @cacla has clean ME firmware . Don`t connect the LVDS cable until you replace L4510 and find out why PL8100,PL8101 are oscillating.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Sounds good.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    OK, I'm back.
                    Pin #3= 3 - 3.3V
                    Pin #8= 0.19V - 3.3V
                    Pin #13= 3.4V - 5V
                    Pin #18= 0.06V - 3.5V - 5V (stops at each voltage)
                    Later, I will investigate more, because I have felt something pretty hot in that area.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      PU8100 is the one, that gets very hot. Almost burned my finger.
                      I did the alcohol test, and PU8100 was the first part that dissipated first the alcohol.
                      I have measured the other parts around it, and none of them were shorted.
                      I should order a new one, right?
                        • 21446
                        Yes, order a new one .TPS51285BRUKR . also the ferrite bead. 0603 ,120 Ohms ,2A
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Placed the order already. Thanks
                          • santytk
                            • May 2016
                            • 2
                            • peru
                            #53
                            Originally posted by smdflea
                            are you using a clip to read the bios,or have you desoldered it. Is your tl866 software up to date, and what part number is the bios .
                            prueba esto
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Thanks for that.
                              The BIOS chip, it was removed and programmed with TL866A.
                              I have tried 209 and 206, with no difference.
                              I have voltage issues, the PWM IC is bad.
                              Right now, I'm fighting with this IC. I can't solder it to the board properly.
                              My smallest solder tip, is 1.2MM and won't reach into the corner, where the pins are.
                              Hot air station solders it, but I see some pins, that are still not soldered.
                              I have ordered a new tip from Digikey. I will try with that as well, when arrives.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                OK, I have soldered in the new IC, but still the same oscillating 3V & 5V. IC still gets hot. 19V is stable.
                                LEDs are not turning on anymore, either.
                                PC8106 shows 0.31 Ohm.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Anybody?
                                  • caspian
                                    • Oct 2015
                                    • 1591
                                    • Laptop
                                    #57
                                    Do not turn the laptop on in this situation, until the circuit gets fixed, to avoid PU8100 being burned.
                                    how did the fan behave the last time you turned the laptop on?
                                    how much resistance is on PL8100 and PL8101 relative to ground?
                                    turn the laptop on for a second and measure voltage on pin7 of PU8100 to see whether it goes high or not.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Initially, I have started with BIOS reflash.
                                      By replacing the BIOS, the behaviour of the laptop has changed.
                                      It used to turn on, with POWER LED on, if I have plugged in the charger, the CHARGING LED was on and the fan was spinning slow than fast, than slow and than fast again a couple of times. It would turn off and start all over again.
                                      It's like it was trying to start a couple of times, that it was shutting off.
                                      After the BIOS reflash, it seems dead.
                                      The POWER LED it was blinking, instead of the fan spinning. Like what the fan used to do, now the LED was doing it. Fan not spinning anymore.
                                      I have tried different BIOS and now it is all dead. PWM IC very hot, 3V and 5V coils are warm, capacitors next to them as well.
                                      1.8V is not present, initially it was present.
                                      As I mentioned before, in the beginning I have removed the LCD connector and one of the ferrite beads sparked(cracked) L4510. I have forgot, that the battery it was still connected.
                                      I'm not sure, how much affected the laptop. I may have caused more problems, than thought initially. Though the laptop, it was acting the same way as before. Like nothing happened.
                                      I will take those measurements later on.
                                      Thank you for trying to help. I appreciate it a lot.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        You may be wondering, why did I mess with the BIOS. I'm a beginner in laptop repair.
                                        I have measured some voltages and it seemed like, a lot of voltages were present(1V, 1.5V, 1.8V, 3V, 5V, 19V), so I assumed, that it could be a bad BIOS.
                                        • caspian
                                          • Oct 2015
                                          • 1591
                                          • Laptop
                                          #60
                                          since there are multiple problems in this laptop, it takes time to fix. however, I think the probability of a successful repair is high if you have some required ICs.
                                          • throwaway327
                                            Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                            by throwaway327
                                            ASUS ROG Ally X - (Handheld Gaming PC)
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                            I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                            06-18-2025, 05:52 PM
                                          • jrodefeld
                                            Asus laptop won't boot (no power) - possible bad caps?
                                            by jrodefeld
                                            I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                            The model:
                                            Asus Zenbook Pro Duo UX582L
                                            I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                            However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                            09-02-2024, 04:55 PM
                                          • acata
                                            Asus X450LC REV 2.2 can't boot to anything
                                            by acata
                                            I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                                            Power on normally. Boot to bios ok.
                                            But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                                            10-10-2023, 05:15 AM
                                          • lukkihapsi
                                            Asus Vivobook X515JA Weird Boot Issue
                                            by lukkihapsi
                                            Asus Vivobook X515JA Laptop
                                            Issue :
                                            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                            Tried :
                                            Cleaned inside for dust, applied fresh thermal paste. No Change!
                                            Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                            Removed Internal SSD. No Change!
                                            Updated BIOS to latest version. No Change!
                                            Removed battery and pressing power button for 1 minute. No Change!
                                            Weird Part :
                                            Upon turning laptop ON, screen lights up - stays black,
                                            I...
                                            07-07-2025, 12:07 PM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
