hp elitebook 8440p with a solution for the hardware whitelist?
    Re: HP EliteBook 8440p
    It's still the same error,machine is not in comitted state.
    Is it possible to copy the name, serial number and other data from old one.bin
    to new one.bin...
    Thank you,please answer !
      I have news.
      I fixed this error(picture below)
      But I failed to remove : Warning ! Machine is not in comitted state !
      Does anyone know how to remove this error ?
        try
          Thank you my friend.
          Everything is now working.
          I just had to unlock it, because your bin file was locked.
          Unlocked it with HPUnlocker.
          If you have time,please explain me what did you do.
          You can write here or in PM
            awesome
              Re: need bios elitebook 8440p kcl00 la-4902p
              ok thanks............ok
                i need bios bin for hp elitebook 8440p
                here is the readed bin......
                  Re: i need bios bin for hp elitebook 8440p
                  board number.....kcl00 la-4902p rev:1.0
                    What's your problem ?
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      need Bios for HP elitebook 8440p
                      KCL00 LA_4901p
                      2009-12-07
                      rev 1.0
                      the laptop sometimes work good and sometimes no power
                        Re: hp elitebook 8440p
                        Did you try the file at post #24?
                          Re: need Bios for HP elitebook 8440p
                          KCL00 LA_4901p
                          2009-12-07
                          rev 1.0
                          Find hardware issues.
                            Originally posted by SMDFlea View Post
                            Try this bios .
                            thanks
                              thanks
                                no display with this file
                                test this 4 bios files for 8440p. if even 1 of them works give reply post the working ones here.
                                  thank you bro
                                    Hello. Can someone delete BIOS password from my dump?
                                    HP Elitebook 8440p
                                    SN CZC0505QQD
                                      HP Elitebook 8440p
                                      SN CZC0505QQD
                                      try
                                        It works! Thanks a lot!
                                          Greetings all.. is there a custom bios for 8440p with a solution for the hardware whitelist?? I would like to use the WAN slot but it can“t be used with other devices if it is not in the whitelist for HP..
                                          Any clues??
