Vizio M43-C1 No Backlights
  • howardc64
    • Jun 2017
    • 648
    Re: Vizio M43-C1 No Backlights
    As many heat gun BGA reflow experience have noted, it doesn't last. I've done it 2x and each time lasting a couple of months of light use. Early failure symptoms including 1/2 screen going grey+noisy (I think this is the upper BGA as its near the T-CON connection) and/or youtube app would get sluggish. Reflow done with the heat sink removed (much easier on later board designs) Ultra low viscosity (like alcohol) flux to flow under the BGAs. And applied new thermal paste. Just did a third time with a hot air station for better temp control. Anyhow, don't really expect it to last.
    As for fan mount, see attached pic for my 40x40x10mm 12V fan (this is a D50u-D1, M43-C1 should be very similar but I've not done mine yet). Fan is just zip tied to the vent holes in the back (zip head inside the chassis so its barely visible on the back) Tapped the switched 12V source at CN212. Quite loud so going to put a pot on it and dial it down (will reduce air flow of course). Previous 5V was very quite so somewhere 5-12V. Greater quiet flow rate is possible with bigger or multiple fans.
    • Nick's Tvs
      • Jan 2014
      • 621
      If done properly with the correct equipment, a reflow and or reball should last several years without the need for a fan modification.
      While these TV's do get very very hot and you most likely could cook an egg on that heatsink, the issue is not due to the high heat, but instead the heat cycles, the tv turning on getting hot, and turning off getting cold. When the TV gets hot, materials expand, and when the TV cools down, they contract back to their original shape and size. This happening again and again over time will cause the microsolder cracks which cause all the issues everyone is experiencing.
      A proper reflow or reball will go much further in ensuring a long lasting repair than installing larger heatsinks and cooling fans.
      2 things you can do to make sure you perform a good reflow
      #1 get good flux, don't get the cheap stuff
      #2 Thermal couple. Make sure you have an accurate measurment of how hot the board is getting so that you know if you are getting to reflow temp or to high and possibly damaging the board.
      • GeorgeT
        • Sep 2010
        • 11
        Hi Nick. Specifically what flux would you use for a BGA reflow? I have a Vizio D55u-D1 that does not power up. I will use my Master heat gun that has a temperature range of 500F to 750F to warm up the heat sink (as you mentioned in other threads) to see if the problem is with the BGA's. If the TV powers up, then I will want to remove the heat sink and try to reflow the chips properly. Thanks for any help.
        • nomoresonys
          • 12284
          • U.S.
          #44
          Fans help out in most situations: https://cdn.badcaps-static.com/pdfs/...9d3b50b881.pdf
          • GeorgeT
            • Sep 2010
            • 11
            I removed the back cover on the Vizio D55u-D1 and used a heat gun to heat up the heat sink. I keep it on for 45 seconds, moving it all around to heat it evenly. After 15 seconds, I plugged the TV in and turned it on. Still no picture. I tried this several times. I then removed the large heat sink and used the heat gun to heat up both BGA chips for around 6 seconds on each one. I let the board cool for a few minutes, then plugged it in. Still black screen. Maybe I'm not keeping the heat gun on the chip long enough. It's about 1/2 inch away from the chip and the gun is around 500F.
            My voltages are just like Macair1's from an earlier post...
            CN9101: DC voltages when TV is plugged in and is ON:
            Pin1 ON/OFF = 0.10
            Pin 2 DIM = 3.32
            Pin 3 3D_ON = 0.00
            Pin 4 PS_ON = 3.70
            Pin 5 GND = 0.00
            Pin 6 GND = 0.00
            Pin 7 GND = 0.00
            Pin 8 GND = 0.00
            Pin 9 +12VA = 19.10
            Pin 10 +12VA = 19.10
            Pin 11 +12V = 19.10
            Pin 12 +12V = 19.10
            Pin 13 +12V = 19.10
            Pin 14 +12V = 19.10
            Pin 15 +5V = 5.17
            Pin 16 +5V = 5.17
            Is is usually the main board?
            • neilc6
              • Nov 2015
              • 1550
              ON/OFF (BL-ON) signal not going high. Should be at same level as PS-ON. Signal comes directly from the processor.
              • GeorgeT
                • Sep 2010
                • 11
                Thanks for your reply Neilc6. I will stay focused on reflowing the processor on the main board then. What is a safe amount of time to keep the heat gun pointing at the processor? My heat gun is a Master heat gun hg-501a that goes from 500 Degrees to 750 Degrees F. It moves a lot of air at 23 cfm.
                • nomoresonys
                  • 12284
                  • U.S.
                  #48
                  Wonder if it's the eeprom, shopjimmy has some and there's several on ebay: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
                  Be advised that there are at least a couple different mainboards for this model tv.
                  • nomoresonys
                    • 12284
                    • U.S.
                    #49
                    Could try unplugging the cable at the wifi module and see if tv comes on, sometimes when that has a problem the tv won't work right, just something easy to try.
                    • GeorgeT
                      • Sep 2010
                      • 11
                      I just unplugged the wifi module, but no luck. Thanks for the suggestion.
                      • nomoresonys
                        • 12284
                        • U.S.
                        #51
                        Check youtube for those reflow procedures, not all of them know what they are doing but you will know when you hit a good one, they will describe it in every detail from the temp to use to how long, some gradually move the heat closer hit it for a while then gradually back off, it is pretty easy to cook them if they are overheated, under-heating won't hurt them, you just won't get any results.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #52
                          Get yourself one of these and stick the thermocouple near the processor. https://www.ebay.com/itm/TM902C-LCD-...L/262799900021
                          And try to follow this profile. https://en.wikipedia.org/wiki/Reflow...a_Profile1.svg
                          To reduce the chance of thermal shock and damage, pre heat the whole board in the oven to 100c for a few minutes before removing, adding flux and using your heat gun. Done right and a reflow will last a decent amount of time.
                          • GeorgeT
                            • Sep 2010
                            • 11
                            Thank you nomoresonys & diff for your great advice. I will definitely order one of those TM902c meters today. Without it, I am working in the blind. Also I will try to match that heat profile as close as possible. What would be a good, no clean flux to use that you have had good experience with?
                            • nomoresonys
                              • 12284
                              • U.S.
                              #54
                              I don't mess with it too often, last time I just grabbed a little bottle off ebay, used the no-clean, it was: http://stores.ebay.com/Dickies-Garage-Sale
                              • GeorgeT
                                • Sep 2010
                                • 11
                                I ordered the TM902C Temperature Meter and some fake Amtech flux from Banggood. I'll continue the testing when my package arrives. Thanks for all of your help.
                                TM902C Temperature Meter...
                                https://www.banggood.com/TM902C-LCD-...r_warehouse=CN
                                Fake Amtech flux...
                                https://www.banggood.com/2pcs-AMTECH...r_warehouse=CN
                                • howardc64
                                  • Jun 2017
                                  • 648
                                  These boards popcorn really easily with heat gun if don't bake it at 100C for a couple of hours in advance to get the moisture out.
                                  I have much better luck recently with 10min bake at 375C in a toaster oven. Fixed 2 of these boards (various Vizio TVs all with same basic board design) I did remove the heat sink, cleaned off thermal paste and removed all thermal rubber during the baking process.
                                  We'll see how long it last but so far batting better than my heat gun/hot air station repair that can easily popcorn these boards.
                                  BTW, took temp readings on the heat sink while TV is running. The 2 BGA chip area are about 120-125F and the whole board is between 90-110F since the large heat sink radiates all over. The thermal cycling is probably what is killing the 2 BGA's large 2D solder ball grid contracts.
                                  • johnboiles
                                    • Dec 2020
                                    • 10
                                    I just had success toaster-oven-ing my M50-C1's main board! Your post gave me the courage. I did 375F for ~8 minutes with the heatsink left on but the thermal rubber things on the back scraped off. @howardc64 did you really do 375C or did you mean 375F? I chickened out short of going the full 10 minutes when the board started putting out a good bit of smoke (probably just smoke from the old flux). But it's been working so far today. I'm not holding my breath for longevity but I'll report back when/if it fails again.
                                    As a data point, my issue first started with the right half of the screen becoming garbled (which seemed like a tcon issue). Then a day or two later the TV stopped coming on at all (no backlight). The white LED would blink 10 times a bit after coming on. Later it started blinking 15 times after coming on. I also had 19V on the 12V power supply line.
                                    • johnboiles
                                      • Dec 2020
                                      • 10
                                      Also, y'all's main boards this crusty on the back? I assume it's just dried flux, but seems like more than I would expect there to be. The crusty bits liquified into a kinda oily substance after toasting it. If I have to do this again, I'll probably go at it with some alcohol because why not.
                                      • howardc64
                                        • Jun 2017
                                        • 648
                                        Yikes, I meant 375F, wish I can correct the original post to not misinform someone. I'll message the admins.
                                        And great you fixed the board. Mine smoked minimally but maybe because I removed the heat sink and cleaned up the thermal paste underneath.
                                        As for oven, big convection oven is probably best for even temps. Didn't want to mess up wife's Viking. Convection toaster is probably next best and my cheapo freebie toaster oven the last resort. I did check the temps with laser thermometer (measured top and back wall) before use and was comfortable temp dial setting was close.
                                        Most people put the board up on stand offs (eg aluminum foil balls) on a metal sheet (or cardboard with aluminum foil on top, punch some holes to vent so foil don't inflate upwards toward the board). Leave the board alone after reflow (oven door open) so it can cool. Don't take it out while hot, I've heard of components falling off.
                                        BTW, my heatsink has a really thin plastic sheet (see attached) on top that lifted off when I removed that tape/aluminum foil on top. Not sure why the sheet is there, can't be good for thermal transfer? But I've given up trying to understand Vizio's design on this main board. The entire cooling solution is typical of modern TV main boards but perhaps the BGAs are on older semiconductor technology that put out too much heat for this thermal solution.
                                        The 3 Vizio TV I have all had his common problem with same basic board design.
                                        2015 M43-C1 (removed heatsink, popcorned the main board with heatgun, replaced with new board from ebay)
                                        2015 P502UI-B1E (no vizio logo, backlight on, no video. oven reflow and worked)
                                        2016 D50U-D1 (dead with blinking lights. Removed heat sink, heat gun reflow, worked few weeks of light use, 1/2 screen noise, oven reflow and worked)
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #60
                                          375F is 190C, lead free solder melts at 423F or 217C, it's not surprising your oven reflow isn't lasting.
                                          • bpcannan
                                            VIZIO M557-G0: Backlights or ???
                                            by bpcannan
                                            'Morning,
                                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                            10-29-2023, 06:36 AM
                                          • csmith
                                            Vizio-D50u-D1 Pulsating Backlights
                                            by csmith
                                            This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                            Am I looking at a defective strip? Thanks in advance.
                                            11-07-2024, 02:56 PM
                                          • x_orange90_x
                                            Replacing backlights in Vizio V755-J04
                                            by x_orange90_x
                                            I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                                            I have not replaced...
                                            12-03-2024, 07:03 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
