lenovo 320-15iap
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    #41
    Re: lenovo 320-15iap
    Originally posted by peste
    try
    hi sir I tried your bios bin for DG424/DG524 NM-B301 Rev 1.0
    Is this compatibel to each other?
    • peste
      • Dec 2016
      • 13778
      • ROMANIA
      #42
      try post #4...
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        #43
        try post #4...
        After falshing it has no display
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          #44
          I replaced my bios chip from aliexpress, it program successfuly , based on expired can it be caused why I dont have display beacuse I used a replacement bios chip, Hope someone can Answer.
          • peste
            • Dec 2016
            • 13778
            • ROMANIA
            #45
            if the bios doesn't work, you might have another problem... check ram memory, video chipset, LVDS cable, display, check voltages, etc.
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              #46
              I already posted a new thread sir hope you aca cehck it out thanks
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                #47
                Originally posted by hoaca388
                Your serial number ?
                https://www.badcaps.net/forum/showth...21#post1217721
                Please help me sir post #5
                • alihomee
                  • Dec 2012
                  • 1596
                  • malaysia
                  #48
                  i tried files in this thread with no luck /////mine is using CPU AMD A5 ///ori file is attached////mobo code isG425/DG525/dg725 NM-B321
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    #49
                    Please alaywas provide a serial numebr of the laptop
                    • hardware1
                      • Sep 2021
                      • 2949
                      • N/A
                      #50
                      Write your Device Model and Serial Number.
                      all donations are welcome,
                      • alihomee
                        • Dec 2012
                        • 1596
                        • malaysia
                        #51
                        sorry for that as serial sticker was removed
                        • hardware1
                          • Sep 2021
                          • 2949
                          • N/A
                          #52
                          I don't know why did you choose this thread to post your request? It's for devices which contain Intel CPU not AMD.
                          You should create a New thread named with your Motherboard, and write your device details as you can, such as (CPU, Screen Inch or anything that can help someone to give you the correct BIOS).
                          Your dump file contains Serial Number, I can move it but I can't know it because it's encrypted. Maybe someone else can decrypted it (I don't know).
                          • djharold
                            • Aug 2015
                            • 247
                            • COLOMBIA
                            #53
                            thanks for help
                            • nForce400
                              • Oct 2023
                              • 6
                              • Romania
                              #54
                              Can you help me with identifying the password from this dump? I've read the WINBOND chip fully on programmer. Owner forgot the password that was set 4 years ago..
                              Lenovo ideapad 320-15IAP , Pentium N4200 CPU.
                              Thank you and best regards,
                              Robert
                            • nForce400
                              • Oct 2023
                              • 6
                              • Romania
                              #55
                              Robert
                              Sorry SMDFlea,
                              here is the SN: PF10J3Q7 .
                              Let me know if you need anything else.
                              Thank you,
                              Robert
                              • Blaze Tech
                                Learner
                                • 214
                                • Ghana
                                #56
                                Sorry SMDFlea,
                                Thank you,
                                Robert
                                Try
                                • nForce400
                                  • Oct 2023
                                  • 6
                                  • Romania
                                  #57
                                  Originally posted by Blaze Tech
                                  Try
                                  Thank you,
                                  Will test and report back. I guess it needs to be written on programmer, right?
                                  Best regards,
                                  Robert
                                  • peste
                                    • Dec 2016
                                    • 13778
                                    • ROMANIA
                                    #58
                                    Thank you,
                                    Best regards,
                                    Robert
                                    Yes with programmer
                                    • nForce400
                                      • Oct 2023
                                      • 6
                                      • Romania
                                      #59
                                      Okay, wrote the flash, all good and can enter the BIOS now, but I seem to have lost the motherboard serial number and Lenovo SN. Isn't there any option to clear the password without losing those?
                                      Best regards,
                                      Robert
                                        • 22135
                                        Best regards,
                                        Robert
                                        https://www.badcaps.net/forum/troubl...12#post1643312
