LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • Cunninghood
    • Jun 2020
    • 21
    • Singapore
    #41
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    This is the patched file using python27.
    Could you help me try patching it using your setup? T460.bin is the original file.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1220
      • France
      #42
      your file t460 patched 32 mo
      my ori t460 patched 16mo
      very weird
      I don't understand why your file is 32mb while mine of the same model (t460) is only 16mb
      • Cunninghood
        • Jun 2020
        • 21
        • Singapore
        #43
        Thank you so much. Yes this is weird, might need knucklegrumble to enlighten
        • Cunninghood
          • Jun 2020
          • 21
          • Singapore
          #44
          Oh wait, you mean you tried to patch my original file, but it is showing 32mb too right.
          Mmmmm.... I tried to patch using manual replacement of "lenovotranslate" and "bootoption", my machine can power on, but there is no display.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1220
            • France
            #45
            yes if I patch your file, it is 32mb.
            and if I take one of mine it is 16mb.
            you can try my patch file for your machine that should unlock the Password.
            there is something else to modify than boot and translate for this model.
            nvram must also be cleaned up
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1220
              • France
              #46
              read the original several times to be sure of your reading
              • Cunninghood
                • Jun 2020
                • 21
                • Singapore
                #47
                Thanks for enlightenment
                How do I go about clearing the nvram?
                • Cunninghood
                  • Jun 2020
                  • 21
                  • Singapore
                  #48
                  Also other than clearing the nvram, what else do I need to do?
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1220
                    • France
                    #49
                    you have to compare the files to find out how to patch them.
                    all the keys are in the patch
                    • Cunninghood
                      • Jun 2020
                      • 21
                      • Singapore
                      #50
                      If not too tough, can you guide me? If it is a cumbersome process then forget it. Appreciate ur reply
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1220
                        • France
                        #51
                        the explanation is in the discussion thread.
                        look at message # 19 and in other topics like Remove_SMM ... UEFI.
                        The best learning is to learn and understand on your own
                        read the topics and come back if you don't understand
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1220
                          • France
                          #52
                          Originally posted by earthoo7
                          same issue with t560 t570.
                          j'ai vu le probleme ,je vais regardé ca ,pourquoi ca fonctionne pas
                          I saw the problem, I'm going to look at it, why is it not working
                          • Knucklegrumble
                            • Jun 2020
                            • 78
                            • US
                            #53
                            Sorry guys I did not have time to look at your files. I'm going to test them and let you know what I come up with as soon as I can.
                            • Cunninghood
                              • Jun 2020
                              • 21
                              • Singapore
                              #54
                              thank you maxpower and knucklegrumble
                              • Knucklegrumble
                                • Jun 2020
                                • 78
                                • US
                                #55
                                OK... I found the reason why your file was doubling in size.
                                I rewrote the cleaning step of the script and modified the process. It should work as intended now.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1220
                                  • France
                                  #56
                                  good job thanks
                                  • Cunninghood
                                    • Jun 2020
                                    • 21
                                    • Singapore
                                    #57
                                    Thank you!
                                    • Bonzas
                                      • 469
                                      • Indonesia
                                      #58
                                      Tried your script with python 2 give me error, but ok using python 3. i use windows. first attempt with locked spv password X250 success, but i need to press small button on the buttom.
                                      • Cunninghood
                                        • Jun 2020
                                        • 21
                                        • Singapore
                                        #59
                                        Hi Knucklegrumble,
                                        It worked on the old laptop, but I tried on another laptop, also T460, and it couldnt work again
                                        I manually patched it already.
                                        However, if you are interested, I have attached the bios dump of the new laptop.
                                        That being said, really appreciate your automated file! It really saves alot of time and effort
                                        • Knucklegrumble
                                          • Jun 2020
                                          • 78
                                          • US
                                          #60
                                          If I could have the script press the button for you I would... There are limits to what technology can do for now...
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            Hi everyone,
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
