Finally built the Bob Parker "Blue" ESR Meter
Re: Finally built the Bob Parker "Blue" ESR Meter
Those minor upgrades add up to ease of use!
The longer leads would keep me from dragging my Blue around so much!
Nice job on the holder!Comment
bcstedt,..
About your FA error code.
Lots of reading gives me this from Bob Parker. (Don't try out the self-diagnostic function unless you really need to. And don't use a 9V battery with the diagnostic function because it will report an 'F2' fault which probably doesn't exist. It must be powered by 5.5v to work properly.)
As far as errors and faults check here. http://www.bobparker.net.au/esr_meter/esrprob.htm
Lots of good Info on errors and problems with the Blue ESR Meter from Bob himself!Comment
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Comment
I should have printed it out at work on our $3000 copier instead of my monochrome $80 home laser printer. It looks good enough and I didn't use sticker paper either. I was just really careful with packing tape and used a razor to trim the excess.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
Looks Good Enough to do the job jayjr !
Everybody can use it if you want. Its not to fancy but it works!
I remember typing the omega / ohm symbol was a pain for me!
The colors just looked kinda cool. I saw similar on the net and they got added at the end.
I have two printers that i use. One HP Laser Jet P1006 for cheap black and white and
a HP Office Jet Pro 8210 for color printing.Comment
https://youtu.be/toq3msUeQ40?t=207--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
AnaTek worked with Bob Parker to get the Blue ESR Meter assembled for sale.
I would trust anything he says because he would know!
As for ESR getting better with charge cycles,... It could happen.
I have seen old caps that have just sat around in equipment unused get better
after some time back in service. Reform I guess.
You got me playing with battery's at my desk now!
New AA alkaline 1.5 volt reads .00 on the Blue while Old almost dead ones removed from my belt flashlight read 1.0 ohms. Same brand from the same package!
Interesting!
Another interesting thing is if you put one sharp tip test lead on the bottom of a cheap
AA battery you can touch the positive and negative through the plastic at the same time producing a red glow hot enough to make a small blister on your finger!
Never done that before! Ok,...I`m done testing stuff now. LOLComment
Some (good) battery blue ESR measurements:
AAA Panasonic alkaline, 0.11 ohms, 0.13 ohms
AAA Ikea alkaline, 0.07 ohms
AAA chinese alkaline [weak almost dead] 0.2 ohms
AAA Energizer lithium, 0.22ohms, 0.24 ohms
AAA Ikea Ladda NiMH 900mAh charged, 0.06 ohms. Discharged, 0.06 ohms
AAA Eneloop NiMH 750mAh charged, 0.17, 0.23
9V Energizer Industrial alkaline, 1.2 ohms
9V Duracell alkaline, 5.0 ohms I just want to take a leak?
12V 7.2Ah gel-cell good 3yrs on standby, 0.03 ohms
AA Ikea Ladda NiMH 2,450mAh new, 0.03 ohms
AA Eneloop Pro NiMH 2,450mAh used, 0.06 ohms
AA Ikea alkaline, 0.05 ohms
AA Duracell alkaline weak, 0.77 ohms I just want to take a leak
AA Duracell Procell alkaline weak, 0.70 ohms I just want to take a leak
AA Duracell Procell alkaline weak, 0.13 ohms
I think the main advantage to using ESR is it doesn't depend on state-of-charge, so dead or alive it checks the plate's active surface area and cell interconnects etc. which go downhill with corrosion.
But I really need to build a new blue ESR meter with an extra digit of resolution.Comment
Very interesting! No burnt fingers?
I found more reading material, The new blue ring tester is interesting as well!
Bob Parker's Electronic Stuff http://bobparker.net.au/index.html
Anatek Instruments https://muut.com/anatek-forum/#!/ana...ct-discussionsComment
bcstedt,..
Lots of good Info on errors and problems with the Blue ESR Meter from Bob himself!It is a good shrubbery. I like the laurels particularly...Comment
Thank`s for the info Bob!
It's never too late to learn something. Example = "Kombi vans" Lol
Thank`s for the clarification!Comment
In case anyone's wondering why it's necessary to power the Blue meter from an unusual voltage and short out R30 before invoking the diagnostic function, it's because the microcontroller's firmware was designed for the Dick Smith Mk2 ESR meter which has a different voltage regulator and there's no R30. I knew that if I changed the firmware to suit the Blue meter, there would be endless mix-ups between the different microcontroller versions.It is a good shrubbery. I like the laurels particularly...Comment
Interesting and Good call on keeping the same firmware.
I hope to never have to use the diagnostic function but my biggest fear is doing
something stupid someday and making my Blue meter a Blue brick!
Hopefully that will never happen. I can replace and repair everything but the Zilog!
Your Blue meter is so popular that I would find a replacement with no problem if needed.
You made yourself quite a good piece of test equipment! Thank`s for sharing your Meter with the world!Comment
I only designed the ESR meter to help with my own repairs. I submitted it to a local magazine as a construction project, and the editor gave me a look like "Why would anyone want to measure a capacitor attribute which no one has ever heard of?". But kit sales just exploded and have stayed high for 1/4 of a century.
I'm sure that Andy at Alltronics who makes the kits now would help out if anyone needed a replacement microcontroller IC. He's that kinda guy.It is a good shrubbery. I like the laurels particularly...Comment
I can check in a little bit for you. I currently use a 9v lithium which is just two lithium cells making it about 8.4v fully charged. Seems to work fine.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
According to Energizer's data, the 522 alkaline 9V battery has a capacity of around 600mAH at that level of discharge, so a 500mAH Li-Ion battery could be expected to last a similar amount of time.
Hope this helps...It is a good shrubbery. I like the laurels particularly...Comment
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
- No more items.
