Lenovo 300e Chromebook
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    #41
    Re: Lenovo 300e Chromebook
    Originally posted by Papanatas
    Up, in case anyone can help me to do that without a dedicated programmer machine.
    That's impossible, you need a programmer to get the source bios out the chip and burn it back after the repair.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      #42
      It's not possible to do with software?
      I see that in the almost all cases and for a big part of lenovo laptops it's possible.
      If your information is from year 2013, then yes, sure.
      • lili2022
        • Apr 2022
        • 1
        • romania
        #43
        Re: Lenovo 300e ChromeBook 2nd Gen BIOS LOCKED
        Originally posted by RethoricalCheese
        Well, I did come up with this solution and it has worked on hundreds of different chromebooks, including lenovo 300e. I have never had to install new chromeOS for it to work. But since it works for you and you are happy with it then its all OK.
        hello. I got a second hand lenovo 300e chromebook 2nd gen and I want to install linux and remove chromeos. when I try to get in developer mode it says "developer mode is disabled on this device by system policy". any chance I could bypass this by flashing the bios with your method? I mean are those "system policies" stored on the BIOS chip or on the memory card? and would I have to order a ch341 programmer kit? thanks
        • Japanac
          • Aug 2014
          • 95
          • Serbia
          #44
          Hello
          Help unlock the Lenovo 300e Chromebook
          • simpleprince49
            • Jun 2020
            • 11
            • The Gambia
            #45
            lenovo cromebook 300e bm5866 v1.3 unlock
            please can someone clean this dump thank you in advance
            • peste
              • Dec 2016
              • 13451
              • ROMANIA
              #46
              Re: lenovo cromebook bm5866 v1.3 unlock
              try RCUnlocker ... run what it says in the window after unlocking and see if it's ok ..
              • simpleprince49
                • Jun 2020
                • 11
                • The Gambia
                #47
                thank you il try it..God bless
                • simpleprince49
                  • Jun 2020
                  • 11
                  • The Gambia
                  #48
                  says unlocked finised but i still have developer mode is disabled by system policy maybe its newer security
                  • Mazorca
                    • Jan 2017
                    • 463
                    Simpleprince49, look at post #5.
                    • simpleprince49
                      • Jun 2020
                      • 11
                      • The Gambia
                      #50
                      Re: Unlock the Lenovo 300e Chromebook
                      Use this dump. Turn on laptop, boot to recovery mode (esc, refresh and power, hold esc + refresh until in recovery mode). Press ctrl + D, press enter. Press ctrl + D and press enter again. Don't remember the exact process but the idea is to try gp tp developer mode. It usually says that dev mode is disabled but that does not matter yet. Anyway, you just need to wait until laptop restarts. It should clear all data. Then just let it boot normally and log in with your gmail account. Then go to settings and powerwash. After you powerwash, dev mode should be unlocked and you should be able to use any gmail account.
                      i got no display when i try to use this bios tried deferent bios also but its the only original dump makes it to boot motherboard model is bm5866 v1.3
                      • simpleprince49
                        • Jun 2020
                        • 11
                        • The Gambia
                        #51
                        Originally posted by tinto
                        RethoricalCheese
                        Yessss your dump is OK
                        butttttt I tried 45min of your instruction...and every time when i try to LOG IN ,I have to connect it to the internet...after that, it locks again !!!
                        in the end I tried last chance:
                        on another chromebook i made a bootable usb with new chromeOS for this model(on motherboard is 300e/500e 2nd Gen)
                        i installed new chromeOS on Lenovo e300 and after Power On , i try POWER WASH (ctrl+alt+shift) and I succeeded
                        after the restart, I logged in normally, everything works ok
                        Thanks RethoricalCheese
                        this is the solution for the Lenovo e300
                        so after reading and reading this post for like about 10 times i tried to do it..so this whats happen to me..i put back the original bios dump unlocked by Rcunlocker (thanks to this tool by the way)and after i boot i pressed esc and refresh key and the crombook goes to recovery mode but when i press the ctrl + D it will not response its just stays in recovery mode..so i created recover os using windows 10 on crome browser and selected lenovo 300e/500e 2nd gen at the dropdown list in lenovo manufacturer and flash it..then i tried to boot it up tried to coonect it to wifi and wallah it did not ask for enrolment again..i did not know about this power wash so i just flash it and set it up..il try to observe this if the enrolment will comeback after a few hours that it is connected to internet and post result and oh also noe i can turn on developer mode..
                        • simpleprince49
                          • Jun 2020
                          • 11
                          • The Gambia
                          #52
                          update the costumer bring me another crombook same model and same problem so im asuming the 1st one is good
                          • mcfbcn
                            • Jun 2022
                            • 3
                            • spain
                            #53
                            hello, could you help me to clean my bios? lenovo 300e 2nd 81MB, thank's in advance
                            • Mazorca
                              • Jan 2017
                              • 463
                              You have three choices, 1, just use my BIN, 2, learn by comparing BIN I posted against your original or 3, use RCUnlocker and have it unlocked and best, keep that program for further BIOS unlocking. https://www.badcaps.net/forum/showth...ght=rcunlocker
                              • GVITSERVICES
                                • Sep 2019
                                • 5
                                • Romania
                                #55
                                Can Someone help me out with this bios? it is google locked from a lenovo with motherboard BM5688_v1.4_300e bios ic W25X20CL and the bios dump from the ic is the one uploaded. Thanks in advance
                                • GVITSERVICES
                                  • Sep 2019
                                  • 5
                                  • Romania
                                  #56
                                  actually this is the bios but i already flashed what you uploaded guys but still nothing.
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    Try it now. You must use your own original to unlock, any others will not work.
                                    • lallollas
                                      • Feb 2017
                                      • 58
                                      • españa
                                      #58
                                      lenovo 300e second gen please unlock gmail
                                      can someone please unlock gmail from my orignal bios lenovo 300e second gen
                                      SN/PF37LD2X
                                      • lallollas
                                        • Feb 2017
                                        • 58
                                        • españa
                                        #59
                                        Re: lenovo 300e second gen please unlock gmail
                                        please help
                                        • lallollas
                                          • Feb 2017
                                          • 58
                                          • españa
                                          #60
                                          please can someone unlock this
                                          Last edited by SMDFlea; 10-18-2022, 05:11 AM. Reason: bios removed,posted once already......
                                            Lenovo 300e Chromebook Specification for Upgrade or Repair
                                            This specification for the Lenovo 300e Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 300e boardview and 300e schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo 300e Chromebook...
                                            09-06-2024, 02:34 PM
                                            09-06-2024, 02:30 PM
                                            09-06-2024, 01:21 PM
