RCUnlocker
  • tg1
    • Nov 2022
    • 1
    Re: RCUnlocker
    Thanks for all the information
    • magictouch
      • Apr 2021
      • 108
      • united kingdom
      #602
      Re: RCUnlocker
      Can someone please unlock the bios for me, I tried hp Unlocker tool but the laptop is not displaying anything, its hp 850 G5 and bios file size is 32MB.
      I will really appreciate your help.
      Regards
      • hardware1
        • Sep 2021
        • 2943
        • N/A
        #603
        Re: RCUnlocker
        Regards
        Here's your unlocked file, try it and let me know. if it doesn't work, upload your other chip, it could be 16MB or 32MB (EC Chip).
        Note: Next time make your own thread.
        all donations are welcome,
        • fl0w3rs_4u
          • Nov 2022
          • 5
          • uk
          #604
          Re: RCUnlocker
          downloaded rcunlocker when used dumbed file give error runtimev140.dll missing
            • 21444
            Re: RCUnlocker
            https://www.badcaps.net/forum/showth...40#post1133112
            • Robien
              • Mar 2014
              • 25
              Re: RCUnlocker
              @RethoricalCheese
              HP Elitebook 745 G5 Security Device problem
              after i used rcunlocker to clear password from main bios i got this error
              i tried many bios but same problem , i put back the original but no change
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                #607
                Re: RCUnlocker
                Clear main bios VSS region and later add SN etc back in bios.
                • Robien
                  • Mar 2014
                  • 25
                  Re: RCUnlocker
                  thank you sir
                  problem solved after Clear main bios VSS region
                  mpm unlocked
                  write back data
                  • elfenne
                    • Mar 2016
                    • 46
                    • maroc
                    #609
                    Re: RCUnlocker
                    hi bro
                    i unlock 840 g6 but faced with hp endpoint security problem
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12090
                      #610
                      Re: RCUnlocker
                      Originally posted by elfenne
                      hi bro
                      Here
                      • REpairAT
                        • Nov 2020
                        • 143
                        • Austria
                        #611
                        Re: RCUnlocker
                        SW says unlocked, but after flashing back 16MB file, I still have admin pw set. Here's a dump of both original roms. 16MB and 32MB, it's a ProBook 650 G4. Would appreciate some help with that
                        Thanks!
                        • hardware1
                          • Sep 2021
                          • 2943
                          • N/A
                          #612
                          Re: RCUnlocker
                          Thanks!
                          Here's your Unlocked file. try to program the 16MB chip only and put your 32MB chip back. if the password still there, program the 32MB chip also.
                          In the first boot remember to go into bios menu to disable the whole security options.
                          • REpairAT
                            • Nov 2020
                            • 143
                            • Austria
                            #613
                            Re: RCUnlocker
                            Works after programming 32MB. Thanks a lot!
                            • gmorb
                              • Sep 2017
                              • 33
                              Re: RCUnlocker
                              hi, can somoene unlock this please? i get missing unlockable content message
                              • hardware1
                                • Sep 2021
                                • 2943
                                • N/A
                                #615
                                Re: RCUnlocker
                                Here's your Unlocked files, try and give me the results.
                                • gmorb
                                  • Sep 2017
                                  • 33
                                  Re: RCUnlocker
                                  hello again. i first only flashed the front bin and the laptop started ikt did seem to do some kind of reset because it took a minute to boot but it was still locked. then i went ahead and redid front flash but also did back flash and no i get no power. caps lock key flashes 7 times.
                                  Update: I managed to unlock it myself by just editing the back-EC bin using a bin i found unlocked on this site previously. there was no need to touch the front bin
                                  • gmorb
                                    • Sep 2017
                                    • 33
                                    Re: RCUnlocker
                                    I came across this after installing windows 11. Is this device locked or just the drive? And how can i remove this? I tried changing the serial number on both bios and ec but the laptop refused to boot this way. Any help appreciated.
                                    • hardware1
                                      • Sep 2021
                                      • 2943
                                      • N/A
                                      #618
                                      Re: RCUnlocker
                                      Try to program these files to the both chips in the same time, In the first boot go to the bios menu and disable all security options. Let me know what will happen.
                                      • elkhiyhie
                                        • Jun 2020
                                        • 35
                                        • philippines
                                        #619
                                        Re: RCUnlocker
                                        hi mate,. il tried the software to unlock my bios file, but the result is same ..
                                        do we have a updated software?
                                        can someone tried to unlock the chip? bios issue... thank you
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12090
                                          #620
                                          Re: RCUnlocker
                                          Find other SPI chip and unlock this chip via RCUnlocker.
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
