Gateway 80486-DX2/50 Revival
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Gateway 80486-DX2/50 Revival
    I don't think I've ever seen a 2.88MB floppy drive. I think I've seen a 2.88MB disk once with its weird ED logo, but not the drive.
    I think I've seen a superdisk (LS120) drive before, but no media...
    Both I think are pretty much unobtanium at least cheaply, nowadays.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I have a couple vintage IBM PS/2's with 2.88mb floppy drives in them and a couple of the disks floating around. LS120's used to be a dime a dozen, I haven't looked for them in a long time....I have a few in the pile somewhere and a bunch of disks for them.... I've always made due with 1.44mb.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        #63
        wtf, was firefox never supported on win95?
        What browsers were ever supported on win95? Oh no I have to go back to Netscape?
        firefox support for win98 was very sketchy also. the only version of firefox ever supported on win98 was firefox v2.0 or something.
        due to the CF card, it's so quiet I can't tell this thing is madly thrashing while trying to work with the installer...
        just look at the hd activity indicator led. it should work even with a cf card since the cf interface is pin compatible with ide but with a different sized connector, that is all.
        (and I still can't explain why it thinks it has no disk space left, it looks like it has plenty... perhaps the win98 msvcrt.dll has unintended side effects when running on win95...)
        the only thing i can think of is to just run scandisk to fix the free disk space count. sometimes the free disk space count on the drive can become focked for some reason. running scandisk fixes it.
        otherwise, yes it could be some sort of integer overflow error in the dll causing improper recognition of the free space available. one other thing u can try that i found using some of my google-fu is to try cleaning up the windows\temp folder. see if it fixes that problem.
        i also found a thread on bugzilla that shows this problem in the v2.0 branch of firefox.
        Bugzilla - 385333 - Insufficient disk space error when there is sufficient disk space
        so it seems to be some kind of a problem with the way the installation path is specified. try entering it manually without the trailing backslash at the end of the path.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          #64
          Yay was able to extract win95 from the failed CDRs and got a basic install on my 486dx4/75 on a 512M CF card. At 16MB RAM, don't think I'd want anything newer.
          Now need to find drivers...
          You know I havn't read all the way through this thread but you can get the windows 95 iso on the web for free
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            damn. no dice.
            "Disk" is only 512MB and well within sizes of that day and era, overflows not likely?
            Scandisk fixed nothing, was clean (but had some warnings).
            removing trailing backslash had no effect, it still reports disk doesn't have enough space.
            hmm..though windows\temp ... now this is a clue.... at least scandisk warned some stuff there...
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              Got the 428MB drive in, and things are looking good.
              Starting off with a followup to the battery corrosion. Got the corrosion neutralized with vinegar and mostly cleaned up. Looks much better.
              Replacement hard drive.
              Installed. Had to uninstall the PSU to get the drive cage out of the system.
              And here's the PSU.
              PSU manufactured April 24, 1992.
              SpinRite Level 5 time against the new hard drive.
              And here's how I deal with troublesome floppy diskettes:
              And if that doesn't fix them, then this certainly will
              I did a teardown of the failed hard drive. Coming up next.
              Permanently Retired Systems:
              Kooky and Kool Systems
              sigpic
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Tearing into the failed WD 850MB hard drive to find out what went wrong.
                I'd already gotten pretty deep into the drive by this point, but what the hey. Signs of a disaster present from the moment I popped the drive open. Platters aren't supposed to have a brushed finish to them.
                A closer look at the evidence.
                Here's a different angle. You can see the damage better.
                The covered side of the drive's PCB, seeing the light of day for the first time in more than 27 years.
                Protective foam that almost didn't want to come off.
                Head stack.
                Cause of death: Head Crash. This was lurking on the bottom side of the top platter.
                Bottom platter, top side.
                Bottom platter, bottom side. Notice the brushed finish to the platters on every single platter side.
                Removable spindle motor! Still looks good.
                The drive chassis, stripped bare.
                We now return to our regularly scheduled programming...
                SpinRite 6 found nothing wrong with the replacement drive.
                A fresh install of DOS and now for Windows 95.
                While Windows 95 didn't take too long to install, it definitely chugs on the hard drive with only 8MB of RAM to play around with. It also breaks the drivers for the Sound Blaster Vibra/16 card, and it doesn't play nice with the card's wave controller. I'm probably gonna roll it back to WfW3.11 or OS/2.
                The hard drive had some old DOS installations on it, as well as an old Windows 3.1 install. For now, I've filed it all away to some temp folders and I'll sort through all of that, pick out the interesting bits that I care about, and then format the drive and start with a fresh install of DOS.
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Looks like it's time for a shave!!
                  Team : 49813
                  Join in!!
                  Team Stats
                    • 31150
                    about your battery leak
                    the 8042 keyboard controller socket is totally fucked and the chip pins need severly cleaning.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Good catch....and 100% correct!
                      Team : 49813
                      Join in!!
                      Team Stats
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Well his keyboard is working... just need to know if he can get in/out of protected mode...
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          Yep...
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            I would still clean that rot off of there...
                            Team : 49813
                            Join in!!
                            Team Stats
                              • 31150
                              it doesnt sleep, it just acts very slowly
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                I just cleaned this trash up...it better stay that way or next time I'll just get rid of the thread.
                                Team : 49813
                                Join in!!
                                Team Stats
