Lenovo Unlock Dxe Driver Bios Collection
	This topic is closed.
Re: Lenovo Unlock Dxe Driver Bios Collection
I have contacted them. They said there is no solution yet.Comment
I think you cand read and clear MEC 16xx chip. I want to test it, but I don't know the pinout and I don't want to desolder the BGA chip. I read on another subject on this forum that someone tried this and removed the password but also removed serial number, mac address and whatever info there is in the MEC Chip. But I think you can write it back with some lenovo utility. I have one that works on T420, I don't know about other Lenovo models.Comment
Also I've read on another page that if you swap the MEC1663 Chip with a brand new one, the BIOS Chip writes in it all the information required about SN, MAC, Model, etc. Again, haven't tested it. Also, as a fact, if you change the serial number on T4xx models, it screws with Computrace if it's activated and the laptop won't be remote locked.Comment
Success in T440s!Last edited by Andreasbest; 06-23-2020, 05:30 AM.Comment
I patched this W451 and worked on my laptop.
Feel free to try it on yours. First password prompt is 1234 after that leave the next one blank and space bar twice when asked.
Follow instruction on this thread.
It *MIGHT* also work on W540/T540p but I have not tested it.
Make sure you triple-back up your BIOS before attempting to flash this one and let me know if it helped.
Good luck.Attached FilesComment
Thanks to all in this forum for help.
Successfully patched SVP in Lenovo W540.
You need to flash only 32 Mb chip.
Good luckAttached FilesComment
Tested t450 pached file , and laptop unlock very good forum is thisComment
hi, i have 3 lenovo t450 i write pach unlock file and unlock done smoothly , but in one case when i write pach there was no display , so i put locked hdd , then i got unlock scrren then put key id 1st part done , now when i write original file then again no display so i put locked hdd and start but i am confuse when i see there is same unlock instruction ask on screen how its possible when i write original file it should be on normal screen
can any one light on this problemComment
Hi! I backup my T460s BIOS and wrote the T460s BIOS rom in the 1# post.
But when I power on my T460s (without batteries), it stops at the 'Lenove' login and no more response.
Attachment is the BIOS rom loaded from my laptop. Could you help to patch it?Last edited by RaidenFan; 07-24-2020, 11:31 AM.Comment
Reply myself.
Press F1 while Lenovo logo shows, and follow the steps, SVP is removed now.
Thanks!Comment
Hello
Can somebody with more deep knowledge here take this Original Bios and this Patched Bios for Lenovo Yoga X380, from Allservice so that you make a properly working unlocked version for all Lenovo X380 Yoga series?
It is 20LJ-SX380 model.
I have paid for this service somewhere and unlocked that laptop, but after some time the same laptop came to me again now with BIOS password. I think that some fuckers put a new password because it couldn't be relocked itself ? Can somebody clarify this ? If it can be relocked itself ?
Below are attached the original BIOS and the patched BIOS from allserviceComment
And below I attach also original locked BIOS and patched BIOS from allservice for Lenovo Yoga 370 if you can make a universally unlocked BIOS for that model also.
thanksComment
Dear MaxPower
Iam Emrullah Turkey in Ankara
Eaasis Computer Founder
I want to thank you very much. The T440p, which has been waiting for service for exactly 1 month, was saved thanks to you.
Do you have a similar solution for the X1 Carbon gen 2.Last edited by SMDFlea; 08-23-2020, 03:20 PM.Comment
Hi . i write your file . but still hang on LENOVO logoUnlock T460 Tested Ok
No keygen .
tested by myself on another T460
Thank's dani981
https://www.badcaps.net/forum/showpo...&postcount=224Comment
I patched a Lenovo T440P using the file in the first post and TPM was patched but when I restore the original bios there is no display, no beeps...just a green light on the power button. I left it for 30 minutes but still display doesn't come.
How do I fix this?Comment
I tested with x270 just now. It is working but it is asking for the right code, if I type anything it says invalid key. It took about 5 minute to display image the first time.Comment
			by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
 - External display (HDMI) shows
							Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
			by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
			by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
			by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
 - Loading...
 - No more items.
