the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: the gutless, bloated, and fried power supply hall of shame
    Interesting, the rated amperages are actually under what their rectifying diodes can do, but there is no way they add to 400W.
    Actually adds up to 269.7. I would imagine it would probably do that, but thats about it.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      #62
      Famous Brand (GT450W)
      seems this noname junker is sold everywhere.
      note the rectifiers.15a at the most?
      there is no rohm part by that number either.
      • c_hegge
        • Sep 2009
        • 5219
        no transient filtering!
        • 370forlife
          Large Marge
          • Aug 2008
          • 3113
          Tiger direct's famous brand special?
          Just a diablotek. Maybe made by RSY. No real identifying marks.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            epic fail brand?
            sigpic
            (Insert witty quote here)
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #66
              the ce,fcc marks are forged as usual.
              no way this thing would comply.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5097
                • New Zealand
                #67
                I hate it when I tell people this, and they just say "it's working fine, there's nothing wrong with it"
                You could strip all safety devices out of your car and it would still go down the motorway at 150Km/h....
                -David VanHorn
                • c_hegge
                  • Sep 2009
                  • 5219
                  epic fail brand?
                  Nah. HongKongFlyApart Company.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    http://en.wikipedia.org/wiki/CE_mark
                    scroll down to the China Export part..
                    • japlytic
                      • Oct 2005
                      • 2086
                      An HPW-1512B (12V 1.25A) AC plugpack had no current sensing circuit; the only protection is the 2A slow-blow mains fuse. If you're not unusually careful to prevent a short on the output, this fuse can blow, along with the primary side MOSFET (and possibly other components).
                      Inside was a 1000uF 16V CTC KM Series unit (bulged) before the output inductor and 220uF 25V after it. On the primary side was a 1uF 450V Teapo SEK before the input choke after the bridge rectifier with a 22uF 450V CTC KM Series after the input choke.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        EPIC WIN!
                        forgot about that one....
                        could be worse, it could be a youngyear, they are so cheap that the fans only have 2 screws stock! and guts? non=existant...
                        sigpic
                        • Badcappy
                          Banned
                          • Aug 2007
                          • 52
                          #72
                          http://www.rohm.com/products/discret...ery/rf2001t3d/
                          Good for 20A.
                          • bluto
                            • Oct 2007
                            • 560
                            #73
                            Is this PSU worth saving? I got in in a junk box and forgot about it until I needed the metal box for another project. I don't think it worked before I got it. Its a ATX PSU with the extra P4 mobo lead. Sadly I didn't write down the wattage values on the sticker before I peeled it off an trashed it.
                            Since I am trying to get more informed on the inner working of electronics, I am asking you if this one would be worth attempting to fix. It has two bloated 1000uf 16v caps. All of the caps are the "Don" brand - definitely good candidates for the bad cap list. The large IC (SBL304OPT)- i think is the schottky diode, is showing a short across the two outer pins. The PSU is also missing parts on the primary filtering side.
                            I have another dead PSU that I could scavenge to get the missing parts (coil, capacitor, transformer) for the primary side. So besides the bad caps and schottky, does this unit look like it is worth playing with?
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3113
                              Wintech, good for 300W.
                              The SBL304OPT is probably the schottky for the 5v rail. Wintech does correctly design their psu's, so even though this uses the funky 1 heatsink design, it will do 300W without blowing up. The 3.3v is simply taken from the 5v and regulated down to 3.3v, hence the lack of a third schottky.
                              http://capacitor.web.fc2.com/d.html#don
                              Don is a very small capacitor company, no surprise wintech is using them, they like the small factory outfits like topower.
                              • bluto
                                • Oct 2007
                                • 560
                                #75
                                Thanks for the reply. Would you agree that it would be beneficial to bump up the uF on the output side caps if i were going to refurb this one? Maybe take the 1000uF caps up to 2200uf?
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3113
                                  Yeah that would help
                                  Could you show a solder side shot?
                                  • bluto
                                    • Oct 2007
                                    • 560
                                    #77
                                    Also, what is supposed to go in the holes marked YC1 - YC4? Bleeder resistors maybe?
                                    • bluto
                                      • Oct 2007
                                      • 560
                                      #78
                                      Solder side pics
                                      • Scenic
                                        o.O
                                        • Sep 2007
                                        • 2642
                                        had a PSU with an almost identical layout. the heatsink was different, a few mods to the layout were made and a "WIN-35P" main transformer..
                                        was full of fuhjyyu and blew the primary side out.. quite literally..
                                        and that's what the primary side filtering is supposed to look like..
                                        left 2pin connector = power in
                                        2 red wires = voltage selector switch
                                        right 2 pin connector = passive PFC
                                        yours doesn't even have a bridge rectifier
                                        looks like they somehow squeezed 4 diodes in where a bridge rectifier was supposed to go.. lol
                                        if mine wasn't full of crapcaps (down to all the tiny ones.. ALL fuhjyyu) and sort of parted out i'd rebuild it.. but i can't really remember what parts i pulled and which one's weren't there when i got it.. so..
                                        Label shot... "slightly" overrated..
                                        • 370forlife
                                          Large Marge
                                          • Aug 2008
                                          • 3113
                                          Y capacitors. Blue ceramic type disks that connect from live to ground and neutral to ground.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • x_orange90_x
                                            Samsung UN65AU8000FF fried by water
                                            by x_orange90_x
                                            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                            10-16-2025, 08:40 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
