Old Gateway 2000 speakers out of sorts.
    Re: Old Gateway 2000 speakers out of sorts.
    Pin 2: Bootstrap 2 resistance between 2 and 3 is 219 meter set at 2000 ohms
    Pin 3: Output 2
    Pin 5: Output 1 resistance between 5 and 6 is 546 meter set at 2000 ohms
    Pin 6: Bootstrap 1
    Something is going on with Bootstrap 1, and may be that is why the Voltage reading is also bad as reported earlier: Pin 6: Bootstrap 1 reported as: 0.46.
    • nomoresonys
      • 12284
      • U.S.
      #62
      So it could be one of those caps? would be nice if I didn't have to get a new TA.
        Boot strap caps location.
        I do not think it is the cap problem, beside as reported that both channel output pins Voltages are showing only 0.5V instead of around 1/2 of the VCC Voltage, so you have more then one problem.
        Are you 100% sure that output pins DC V are 0.5V? Were the trace damaged and repaired as you reported earlier? I just cannot see that BOTH Amplifiers have bad DC Voltage.
        • nomoresonys
          • 12284
          • U.S.
          #64
          Just tested agian, ac adapter is putting out 17.2 volts, checked with my meter, both output pins reading .89 volts, why its up from the .5 volts measured before, I have no idea.
          • nomoresonys
            • 12284
            • U.S.
            #65
            Pad tried to lift a bit on the cap I replaced but I think it's ok, because it acted exactly the same after replacement of cap, the one I repaired was on the karmons of the other thread.
            • nomoresonys
              • 12284
              • U.S.
              #66
              Switched out c26 with one from a junk board, uf was ok, couldn't check esr, no meter, didn't seem to make any difference, was getting OL when testing uf on c25 in circuit so I switched it out too, tested ok out of circuit, replacement still getting OL in circuit but c26 gives me a uf reading in circuit?? I tested pin 3 output 2 and got like 14 volts once, tested again got the same .89 that I was getting, I have 14.6 volts on the main cap, is that kind of low?
                The TA can run from 9 ~ 20VDC per spec sheet so 14V is no problem.
                "I tested pin 3 output 2 and got like 14 volts once, tested again got the same .89 that I was getting," I wonder if the VCC on pin 8 (which is supplied through the switch on the headphone jack) is intermittent,if Voltage on pin 8 (ON/OFF) is not present, lots of Voltages will be reading low as if the IC is off.
                • nomoresonys
                  • 12284
                  • U.S.
                  #68
                  Well crap, I was messing with c16 and pulled the pads for sure this time, can I just run a solder bridge to the nearest joint on the trace/path to reinstall the cap?
                  • nomoresonys
                    • 12284
                    • U.S.
                    #69
                    They put a bunch of glue on the main cap and c16 and had about 4 resistors completely covered in it, removed most of it, wonder if it messed up the resistors?
                    • nomoresonys
                      • 12284
                      • U.S.
                      #70
                      The glue that is.
                      • nomoresonys
                        • 12284
                        • U.S.
                        #71
                        So the switch on headphone jack could be bad? any way to test it? Maybe that's why I get sound coming from speaker 2 when it's plugged into headphone jack?
                        • nomoresonys
                          • 12284
                          • U.S.
                          #72
                          Can't seem to figure it out, never have much luck with audio or printers.
                            The power switch on the headphone jack assembly is for supplying the Voltage to pin 8 of the IC to run t he TA IC when head phone is not plugged in, the main key point id that if you do have 14VDC at pin 4 and pin 8 of the TA IC, the output of both amplifier pins should then have about 7VDC but you only has 0.5V so that is not normal.
                            • nomoresonys
                              • 12284
                              • U.S.
                              #74
                              Ok, just checked the TA with headphones plugged in and every pin is 0 volts, is that as it should be? I guess I should replace the TA, can't figure out what else would make both output and one bootstrap so low in voltage?
                                See my post #51 showing the Voltage with and without headphone jack plugged in.
                                When headphone is plugged in then there will be no Voltage feeding pin 8 of TA so most Voltages will be 0V as you can see my list. For both output to have almost 0V it has to be something common to both amplifiers, I.E.missing Voltage on pin 8 (VCC2) of the IC, or on pin 9 (Ripple).
                                My post #51:
                                TA8248, TA8229. Notes: (***V) = Voltage with headphone plugged in. When headphone is plugged in the VCC2 from the switched headphone jack is cutoff so there will no VCC2 on pin 8 of the TA chip.
                                Pin 1: N.C.
                                Pin 2: Bootstrap 2 =18.20V (0.56V)
                                Pin 3: Output 2 = 9.42V (0.51V)
                                Pin 4: VCC1 = 18.47V (18.47V)
                                Pin 5: Output 1 = 9.03V (1.00V)
                                Pin 6: Bootstrap 1 = 18.16V (0.52V)
                                Pin 7: PWR-GND
                                Pin 8: VCC2 = 18.47 (0.05V)
                                Pin 9: Ripple filter = 9.63V (0.51V)
                                Pin 10: NF1 (Negative Feedback 1) = 0.60V (0.95V)
                                Pin 11: Input 1 = 0.06V (0V)
                                Pin 12: Input 2 = 0.02V (0V)
                                Pin 13: NF2 (Negative Feedback 2) = 0.60V (0.56V)
                                Pin 14: Pre-Gnd 1
                                Pin 15: Pre-Gnd 2
                                • nomoresonys
                                  • 12284
                                  • U.S.
                                  #76
                                  Ok, TA pin 8 is 14.75 v and pin 9 is 7.75 v, that's measured with headphones unplugged so looks like those 2 are alright if i understood correctly.
                                    Those readings are OK.
                                    So the only thing left is bad TA chip.
                                    • nomoresonys
                                      • 12284
                                      • U.S.
                                      #78
                                      Ok, Thanks Bud.
                                      • cazi1001
                                        Samsung Galaxy A22 - strange problem with sound / speaker
                                        by cazi1001
                                        I have a Samsung Galaxy A22 5G with a strange error image.
                                        If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
                                        If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
                                        If I listen music via Youtube, even the upper or lower speaker don't work.
                                        If I switch louder or quieter, the sign on the screen show me a headphone.
                                        If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
                                        Does anyone have any ideas, what the problem could be?​
                                        02-10-2024, 09:16 AM
                                      • Christos Tsiligiannis
                                        Marian Trace Alpha sound card repair help
                                        by Christos Tsiligiannis
                                        Hello to the forum.
                                        My name is Christos, I am new to the forum here and i am posting from Greece.
                                        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                        So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                        11-18-2024, 05:26 AM
                                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                        This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-12-2024, 02:30 PM
                                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                        HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
