Microsoft Surface Pro 7 NEED BIOS. HELP!
  • Tjaytony
    • Oct 2020
    • 114
    • Nigeria
    #61
    Re: Microsoft Surface Pro 7 NEED BIOS. HELP!
    Originally posted by AAAC
    @Tjaytony
    I've seen something similar before, it may be due to the SATA hard drive configuration in Setup/BIOS, it may be either "IDE Compatible mode", "AHCI mode" or other like "RAID mode" (have seen only the first two). So changing the SATA hdd mode may make a difference, but it's always better to work with the Original BIOS file.
    Give a try to your Original patched BIOS file.
    i mistakenly cut through the screen flex while trying to disassemble the screen, but from the little visible on the screen i can tell the bios password is gone and the device boots fine.
    so thank you
    • maraketh
      • Jul 2017
      • 17
      • Romania
      #62
      thanks! i will try it in a few minutes!
      • maraketh
        • Jul 2017
        • 17
        • Romania
        #63
        @maraketh
        Hi, this is your Original BIOS, patched to remove the password(s).
        Thanks very much. It works perfectly!
        • kalzabdul
          • Sep 2020
          • 28
          • Uganda
          #64
          surface pro 7
          Hi this is surface pro 7 and it's locked please unlock it for me.
          • volinakis
            • Jan 2021
            • 2798
            • N/A
            #65
            Originally posted by Sakaan
            I have tried my ch341 programmer on other chips. It immediately read and detected other chip first time. So there is some other problem. Can any one guide me how to add this chip to programmer software please?
            Use ASProgrammer and select 25Q128JW.
            • TheQuentincc
              • Mar 2017
              • 64
              • France
              #66
              Hi, I have a Surface Pro 7 with presumably dead SSD and a locked bios (password), can anyone remove the password ?
              Thanks you a lot
              • hoaca388
                Badcaps
                • Jan 2022
                • 12088
                #67
                Thanks you a lot
                Here
                • kalzabdul
                  • Sep 2020
                  • 28
                  • Uganda
                  #68
                  Originally posted by hoaca388
                  Here
                  Hi. Please unlock mines too
                  https://www.badcaps.net/forum/attach...3&d=1661490488
                  • Da_conrad
                    • Jul 2022
                    • 3
                    • germany
                    #69
                    Hi hoaca388,
                    i have a surface pro 7 with damaged Bios. Logo for 5 sec and off. Can you check my dump please?
                    Thank you.
                    • Da_conrad
                      • Jul 2022
                      • 3
                      • germany
                      #70
                      Originally posted by Da_conrad
                      Hi hoaca388,
                      Thank you.
                      History is:
                      power on, show just logo and power off after 5 seconds.
                      Board had failed SSD, so I replaced failed SSD on this board with new empty chip.
                      but still same result, power on, just show logo and power off after 5 seconds. no way to get boot menu or uefi settings.
                      • Mazi Kaleg
                        • Sep 2022
                        • 1
                        • Denmark
                        #71
                        Hi every one. I bought one surface pro 7 from eBay . I tried to reinstall windows from setting. in progress ,its comes issue . now its loop. just surface sign comes and restarting. I try to install windows with USB, but Can not reed usb and have password(Power with Volume down). I try to change setting in bios, but bios have password.Dosent Garanty.I open LCD and Remove Battery,but its same. can somebody help me??? thanks
                        • TheQuentincc
                          • Mar 2017
                          • 64
                          • France
                          #72
                          Here
                          Hi, thanks, but sadly it doesn't work, it tries to boot for like a sec then shutdown (can't see what's written since it only light up the borken screen and doesn't have time to display on HDMI), by flashing back my original bios it works like before...
                          • AAAC
                            • Jan 2020
                            • 458
                            • Mexico
                            #73
                            @TheQuentincc
                            I've deactivated the password and Computrace, the file seemed to have a Computrace account too. Let's see how the file works and hopefully it does not have MDM (DFCI) active too.
                            • TheQuentincc
                              • Mar 2017
                              • 64
                              • France
                              #74
                              @TheQuentincc
                              It worked, thanks you
                              How are you able to tell which option is enabled and also how to disable it ?
                              Sadly it just confirmed that the SSD is fried
                              • AAAC
                                • Jan 2020
                                • 458
                                • Mexico
                                #75
                                By looking at the UEFI system variables. Then by checking other "invalidated" variables I can use that to invalidate the password, Computrace or other system variables. It's relatively easy, just compare the 2 files, original vs patched files.
                                • SlaV77
                                  • Sep 2022
                                  • 2
                                  • Poland
                                  #76
                                  Someone will suggest which program to read the winbond 25R128JWPQ ?
                                  • ahmypc
                                    • Oct 2013
                                    • 79
                                    • Turkey
                                    #77
                                    On my Pro 7 device, the purple stripe appears at startup. Also, the charge level does not exceed 65%. Multitouch does not work. Could it be a bios issue?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12088
                                      #78
                                      Clean ME file
                                      • ahmypc
                                        • Oct 2013
                                        • 79
                                        • Turkey
                                        #79
                                        Clean ME file
                                        Unfortunately it's stuck in the logo.
                                        • ahmypc
                                          • Oct 2013
                                          • 79
                                          • Turkey
                                          #80
                                          Please help me.
