ESR meter upgrades
This is a sticky topic.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #821
    Re: ESR meter upgrades
    Have you tried the firmware linked in this post? https://www.badcaps.net/forum/showpo...&postcount=795
    Can you please post a picture of the grid pattern the meter shows for 2 seconds?
    About the warning of the fuses: You can change:
    Code:
    efuse:0xfc:m
    Into:
    Code:
    efuse:0x04:m
    And it should not give that warning any more.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #822
      per hansson is there any recent firmware available for our testers? as i have the same tester as you use i did update mine too 16mhz crystal etc.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #823
        I posted a build a few pages back:
        https://www.badcaps.net/forum/showpo...&postcount=767
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #824
          Thank you i missed that post somehow i will try it on my tester later.
          • TEDDIBEAR
            • Oct 2014
            • 45
            • england
            #825
            Thank you all for your time and help.would not have got this far without it.
            Update,
            I decided to bite the bullet after multiple writing and erasing the chip think I tried every avrdude file I could, I fitted a new atmega 328p au smd chip and eureka it took the first firmware download,and this is the result. so may have a playround upgrading now it is working, what does the 16mhz upgrade achieve?
            John
            • jondoe
              • Nov 2016
              • 547
              Congrats, nice solder work, used a hot air station I take it?
                Great Sage é½Šå¤©å¤§č–
                • 31144
                16MHz increases accuracy, allows testing of crystals upto about 10MHz and reduces your battery life
                • TEDDIBEAR
                  • Oct 2014
                  • 45
                  • england
                  #828
                  Yes you are spot on (hot air soldering) have been in the trade over 50 years so soldering is not a problem. Its programing I have problems with, but with help from all of you on this Forum I got a result, many thanks.
                  John
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #829
                    Great work TEDDIBEAR!
                    Glad you got it working
                    • TEDDIBEAR
                      • Oct 2014
                      • 45
                      • england
                      #830
                      Now that it is up and running what would I need to adapt this LCR T4 to work with a rotary encoder & 16mhz crystal, if it is possible with this model. if so what firmware would I need.
                      John
                      • turbochris
                        • Sep 2017
                        • 9
                        QUESTION!- I have a few lipo cells with protection circuits and some of these micro USB charge controllers with 9 volt boost converters built in. I have the newest AY-AT PCB based tester. I'm going to put the lipo and charge controller/boost converter on it. How can I run the vbat signal that goes to R1 directly to my battery so i can see battery actual battery voltage and not the converter output voltage? Would I need to add another transistor like T1 between the battery and sense circuit to keep the voltage divider on the sense circuit from killing the battery?
                          • 31144
                          just connect ubat to the battery.
                          btw, i recommend using 2 in series rather than a boost converter.
                          some people have had problems with noise from the booster getting into the cpu
                            • 31144
                            John
                            to do the crystal - just swap it.
                            the rotary encoder - search this thread from page1.
                            • pepe10000
                              • Nov 2016
                              • 2
                              • Spain
                              #834
                              John
                              Maybe you are interested also read this post:
                              https://www.eevblog.com/forum/testge...19/#msg1090619
                              A greeting.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #835
                                what capacitor values do i need too calibrate the unit?as just checking i have the correct values here.
                                • jondoe
                                  • Nov 2016
                                  • 547
                                  A polypropylene 220nf capacitor and something to jumper all three test points.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #837
                                    after joining the three leads its now asking for two values 100nf and a 1pf im just trying to find new ones.
                                    • jondoe
                                      • Nov 2016
                                      • 547
                                      I guess some models vary in requirement!
                                      Just checked mine, it asks for >100nf so I suppose 220nf is good enough.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #839
                                        All sorted i read it wrong, it was just 1 100nf capacitor for calibration so im using this firmware now on my 1 mhz tester and stj version on my 8 mhz tester
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #840
                                          John
                                          He needs to change the firmware too: If not it will read capacitance 2x out for example.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
