ESR meter upgrades
This is a sticky topic.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #941
    Re: ESR meter upgrades
    I have uploaded the firmware from one on eevblog.
    Yes it has a menu where you can select the basic modes of operation, including only ESR.
    If anything's missing just compile your own
    • Dutch52
      Retired
      • Aug 2016
      • 9
      • Netherlands
      #942
      @STJ,
      Did you investigate the AY-AT firmware further? (See message 928)
        • 31305
        no.
        and that machine is sketchy as fuck - i think a harddrive is failing.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #944
          Hi i was going to arder AY-AT tester with case but seen a post where it says this one maybe a better choice and is newer https://www.aliexpress.com/item/M644...ceBeautifyAB=0
          can this tester be upgraded with later firmware etc if needed and has anyone found a case too fit them thanks
            • 31305
            ask here:
            http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/5025/
            it looks o.k. but a colour display would have been better.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #946
              Originally posted by stj
              ask here:
              Yes true no colour screen on these, so a ay-at it is then as aliexpress has a sale on and these can come with a case etc, too save me reading loads of pages in the eevblog thread lol, do you know what if any parts are recommend to swop out? before i update the firmware, i will also keep too a 9v battery as fits in case nice.
                • 31305
                only the voltage reference really, like last time - i think you have spares of the lm4040
                beware of the case, if it's the acrylic ones they crack.
                  • 31305
                  btw, i ordered one of these in the sale.
                  https://www.aliexpress.com/item/New-...814430302.html
                  i'm thinking with a mask on the end to reduce the aperature, i can check how hot chips are without using the "finger test"
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #949
                    yes got spares of the lm4040 so thats ok what crystal does the ay-at come with is it worth upgrading? and yes that looks like a good ir thermometer i will have a good look through there site whilst the sales on, i was going too make a post asking if anyone had spotted anygood bargains etc we all like too build our test equipment/parts stock up.
                      • 31305
                      upgrade to a 16MHz crystal too.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #951
                        GM328R firmware attached containing latest SVN version 798 of Karl-Heinz firmware.
                        This time 16Mhz and 20Mhz builds are included, I have tested both.
                        • Dutch52
                          Retired
                          • Aug 2016
                          • 9
                          • Netherlands
                          #952
                          @STJ
                          Is your old machine still sketchy ?
                            • 31305
                            worse,
                            drive is dead
                            i know why - the motor driver ic is shorted (ST smooth series) - i'm looking for a donor drive to get another chip.
                              • 31305
                              component testers
                              just did a fresh build
                              not tested yet.
                              GM328 - every option on, low bat @7.2v
                              AY-AT no BJT / PUT testing - i tried real hard but there is simply not enough flash.
                                • Jul 2011
                                • 6070
                                Re: component testers
                                Are you going to show any pictures of the unit that you are building
                                  • 31305
                                  i did, nothing has been added since.
                                  the way i see it, there is no point building one if it costs over twice as much in parts as buying one from china and upgrading the crystal.
                                  i will buy a new one when i see one with an atmega664 or 1284 and a colour display that i like.
                                  i wont buy or recomend any atmega328 based stuff now, they just dont have enough memory for all the features.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8716
                                    Anyone have a PUT or UJT to play with on these testers?
                                    SCS?
                                    I suppose DIACs are more available but testing such on these things are going to be tough?
                                      • 31305
                                      maybe a diac works - i dont have one to try.
                                      not even seen one for decades.
                                      in theory it may be detected as 2 diodes.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8716
                                        I have a few UJTs in my junk pile, but not PUTs or SCSs. Yeah probably should show up as two diodes or something to that extent. (Incidentally, how could SCS be tested? has more than 3 pins...)
                                        DIACs I have a couple and they're still being made/used, but I don't think they could be properly tested. They might detect as a funky high ohm resistor or something? Not sure. I don't have one of these testers to try.
                                          • 31305
                                          a diac would probably show as a pair of zeners.
                                          i think i may have one on an old switching psu for halogen lamps - maybe i will be able to test that theory.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
