Help with blowing transistor NAD T752 receiver
  • rddube
    Aspiring Expert
    • Jun 2013
    • 957
    Re: Help with blowing transistor NAD T752 receiver
    Originally posted by eccerr0r
    H Is the relative position of the R522 potentiometer close to the position of the R545 potentiometer (don't touch either for now, just look at position). Perhaps R522 is turned all the way down for 1KΩ and hence the voltages are so close.
    Forgot to answer this question...yes the position of the the potentiometers is close as seen in the photo (the one on the right is R522).
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      Okay that is a clue that something's still wrong with the R522 channel unlike the R545 channel. Spread is too low.
      Next I'd be curious what the voltages are on R513, hopefully both are way negative... If they are, Q504 is probably bad. If they aren't, R513 is bad.
      ... but still not quite sure why this would cause final roasting... more data needed...
      • rddube
        Aspiring Expert
        • Jun 2013
        • 957
        Ok, so here are my measurements with 1K resistors from Base to Emitter on Q509 Q510 and Q521 and Q522:
        Q506 C to gnd +1.51V
        E to gnd -1.451V
        Q518 C to gnd +-4.41V
        E to gnd -7.92V
        Q530 C to gnd -3.97V
        E to gnd -7.44V
        Looking at board such as the photo I uploaded:
        R5143 from left to gnd -6.5V
        from right to gnd -5.82V
        R5146 from left to gnd -4.4V
        from right to gnd -3.2V
        R5143 from left to gnd -3.2V
        from right to gnd -3.1V
        Q504 B to gnd -6.2V
        I double checked again every measurement.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8711
          Check your component designators and signs again, you have R5143 listed twice and you have +-4.41V for Q518-C. Assuming you meant -4.41V, the C-E drops all look reasonable now though the "second" R5143 spread looks too close. Again something doesn't look right, when the spread is close the transistors should be safe from destruction.
          Now Q504-B is way too high, it should be -65+1.4 = about -63V, but the voltages downstream do not seem to correspond to Q504 being turned on...
          • rddube
            Aspiring Expert
            • Jun 2013
            • 957
            Hello Eccerr0r,
            Sorry was trying to go too fast, here are the corrections to my voltages that I checked again:
            E to gnd -1.451V
            Q518 C to gnd -4.41V
            E to gnd -7.92V
            E to gnd -7.44V
            R5149 from left to gnd -3.2V
            Q504 B to gnd -6.2V
            Q504B is -6.2V not -62V.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 957
              Hold on gentlemen, I removed the board and checked some components only to find that on the right channel, I have a partial short as the 1K resistors I installed measure .5K instead of 1K. I have to trace it down now.
              Don't spend too much time analyzing the left channel (Q510/Q509) as I have to get rid of this short.
              Will be back with new measurements once I find it. Sorry for the inconvenience.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 957
                Ok, so I think I finally found the problem in that the .5K measured on the 1K resistors seems to be ok - explanation: right channel was giving .5K on those resistors while the left channel was giving me 1K...searched everywhere only to find out that the .22K double resistor on the left channel R527 was open! Fortunately I had a spare one and replaced it and now both the right and left channel read .5K on the 1K resistors when installed.
                Everything seems to balance well, but now R520 and R544 measure 196 ohms, while R573 (the center and good channel) measures 217 ohms, not too sure why but is this normal with 1K resistors instead of finals?
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8711
                  Whenever you measure a resistor, it needs to be measured out of circuit. Too many side paths will affect your measurement. I kind of expected that emitter resistor to affect your reading and there was never a "short" on the right channel.
                  So it looks like the fried transistors fried the resistor too.
                  and yes, the skewed in-circuit measurement of the resistors with that hack added would affect reading, my calculation resulted in around 198Ω which matches up quite well within about 1% of 196Ω.
                  • petehall347
                    • Jan 2015
                    • 4450
                    • United Kingdom
                    #89
                    just so you know those double resistors also known as emitter resistors in this case are 0.22 ohms . the k is tolerance .
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 957
                      Oh sorry, my bad, you are right they are 0.22 ohms, and that is what I installed!
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 957
                        Ok, thank you for the explanation, I'm learning a lot while doing this thanks to you! So I think we are in business, will take measures again and report back - just got notice that the finals have arrived in Canada, so probably next week will be here. Thanks again!
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 957
                          So here are my latest measurements with the .22 ohm resistor changed and after having removed and checked Q506, Q507, Q508, Q562 and Q563 to be good:
                          Q506 C to gnd +0.465V
                          E to gnd +0.389V
                          Q518 C to gnd +1.7V
                          E to gnd -1.57V
                          Q530 C to gnd +1.785V
                          E to gnd -1.63V
                          R5143 from left to gnd +0.365V
                          from right to gnd +0.386V
                          R5146 from left to gnd -1.04V
                          from right to gnd -1.05V
                          R5149 from left to gnd -1.052V
                          from right to gnd -1.053V
                          Q504 B to gnd -62.7V
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 957
                            Eccer0r and Petehall347, do these readings look ok to you? The only one that is close to 600mv is the left channel (Q506), in fact it is below, but it is positive on C and on E, and also on each side of the resistor, whereas the other two channels have positive and negative on each side but are more in the 1.7V area. Not sure how to interpret this, is there something wrong with the negative side of the left channel? Many thanks for your input!
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8711
                              As in previous messages still would like to know the voltage at Q504-E (or voltage at R513) and what happens to the voltage across Q506 as you change R522. Yes the spread is wrong compared to the other channels, but I'm at a loss as why all the transistors are good except that it burns the finals. Again the closer the voltages are together on Q506, the safer for the downstream transistors, but it produces odd-order harmonics in your music when playing which may be unacceptable to your ears.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 957
                                Sorry Eccerr0r, had missed your question about this. So the voltage at R513 is -61.25 and at Q504-E it is -60.86V.
                                Will do measurements across Q506 as I change R522 and report back in a few minutes
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 957
                                  How weird can you get, as soon as I attach my probes across Q506 and try and start it, it gives me no voltage reading and goes immediately into protection mode (red light). If I detach my probes, it starts up with green light ??? I tried to take a reading across Q518 and got -3.35V and the amp started normally (green light)...what's going on?
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8711
                                    A good test meter should not cause going into protection mode. Maybe you have a flaky Q506 or shorted your probes to something again?
                                    Perhaps a broken R518 would also cause the device to go into protection.
                                    BTW that hole near C572/R528 looks very suspicious, if there is a screw there, is it shorting C572 with that jumper J48?
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 957
                                      My test meter is a Fluke 87V, so I think it is ok. Tried it with another one I have a Uni-T and it does the same thing - as soon as I connect both probes from the meter, it goes into protection mode. R518 measures 3.275K so I think it is ok.
                                      The hole near C572 is the hole to insert the screw that holds the transistors to the heat sink, it is a pass throught hole.
                                      So the only thing left, is a flaky Q506 because I didn't short my probes again. When I do the same type of reading on Q518 it doesn't do this - it gives a reading and stays on green light.
                                      So I guess I'll replace Q506 and try it again. Will report back later.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 957
                                        While I remove the board, I'll remove R518 and check it out of circuit just to make sure.
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8711
                                          mainly inspect for broken traces, as long as there is some conductance that works acceptably from C-B of Q506, it should be acceptable and not cause finals to fry.
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • wolf1976
                                            wireless receiver for 6 speeds fan control with remote control
                                            by wolf1976
                                            hi i have a receiver that is destroyed from the overvoltage i guess
                                            my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                            the motor fan has not label
                                            i have an other receiver operational
                                            In your opinion can i measure the voltage at the output ?
                                            what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                            thanks in advance...
                                            07-23-2025, 03:12 PM
                                          • CdDvdFlash
                                            DSE GE6878 possible TV receiver dying remote not working well
                                            by CdDvdFlash
                                            For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                            07-03-2024, 03:55 AM
                                          • sanalelevenstar
                                            Yamaha RX-V485 receiver. After encountering a "version error"
                                            by sanalelevenstar
                                            Hi everyone,
                                            I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                            After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                            I managed to find the service...
                                            09-10-2025, 01:54 AM
