LG LST5651SW stove: oven not heating properly
  • R_J
    • Jun 2012
    • 9580
    Re: LG LST5651SW stove: oven not heating properly
    Originally posted by Curious808
    Checked in place. Both it and the one above are 1.98. No signs of damage.
    Oh well it was worth a try.
    • petehall347
      • Jan 2015
      • 4433
      • United Kingdom
      #82
      could q205 be bad ? i know transistors generally short e to c but on the odd occasion its b to e short .
      • Curious808
        • May 2022
        • 39
        Thanks for all the help and hanging in there! It took a while, but I learned some basics. If I had to do it over, or next time, this would go way quicker.
        I'm pretty confident it's something on the main board. I'm not gonna start trying to replace components on the board. A replacement board is $300 -- not worth it.
        Cheers!
        • JayPoorJay
          A Central Air Heating Element, A PID and a Sauna
          by JayPoorJay
          What could go wrong...?
          I'm not sure if this is the right sub category or even the right forum but here goes,,,
          I'll just dive right in. I want to see if it's possible and what it would take to use a PID Controller (or 2) to run a central air conditioning heater element (the kind that goes into an air handler) and a small blower fan... The application is a DIY Sauna... Am I nuts? Mean, these components could be had for around 100 bucks.
          What do I need to be thinking?
          Of course I will go to Vevor and order one of their 200$ sauna heaters so I...
          01-10-2024, 02:48 PM
        • EasyGoing1
          The best way to drive a heating element?
          by EasyGoing1
          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
          This is the general setup that I have now.
          This is what the...
          01-25-2023, 11:29 AM
        • bohaboha
          Queen coffee CQ MN-2 Heating element
          by bohaboha
          How to test this queen coffee maker heating element...
          07-18-2022, 09:01 PM
        • flysky
          Gigabyte H610M S2H V2 help to identify the element.
          by flysky
          There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
          Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
          01-23-2025, 07:21 PM
        • CuriousJohn
          Burco boiler power problem
          by CuriousJohn
          Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
          Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
          This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
          12-22-2024, 10:25 AM
