Inverter tester using old CFL
This is a sticky topic.
  • SkOrPn
    • Oct 2017
    • 14
    Re: Inverter tester using old CFL
    Originally posted by momaka
    That's a very interesting idea SkOrPn. Technically... or as far as I know... those CCFLs have similar voltage and current requirements, so you might be able to use one to test a monitor inverter. I'm actually very curious if that will work, as there's a computer store near me selling an UV CCFL kit (2 lamps + inverter) for $4 total. Sounds like a good deal to me.
    Now, as far as replacing the CCFLs in a monitor with UV CCFLs - I don't know about that. Most likely the colors would be way off or not there at all, as you need a white backlight. And also, a CCFL like that probably won't fit inside a monitor.
    Haha, well I wasn't thinking of putting that UV in my monitor. I was just wondering if the Dells inverter would fire it up. I already have some CFL (twisted bulbs) to use, but that UV tube one already has proper wires attached.
    I know my video board needs caps, and my psu is probably still OK although should get news caps for the heck of it anyway, but I don't know if the inverter is OK or not. I don't even know how to remove the CCFL's. I was thinking about testing them on one of my Inverters I have for custom PC use, if that will work but I don't know. Either way I need to verify that the inverter and CCFL's are OK before I plan to fix anything else.
    Still in research mode for that task.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 957
      Hey Budm,
      I have a few of these lights, do you think I could use them without having to open them?
      They are sold at home depot for 4.97$
      Tks!
      • Agent24
        I see dead caps
        • Oct 2007
        • 5095
        • New Zealand
        #83
        You could use those directly, yes.
        Just bear in mind that they may not last as long as they would when used with the correct inverter, I think the monitor inverters drive a higher voltage as their CCFL tubes are longer, so the test lamps may fail faster. That's what I experienced anyway - although I was using scavenged tubes from CFL lamps which may have been near their end of life already...
        -David VanHorn
          Bad lamps and bad wiring.
            Bad lamps and bad wiring ii.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #86
              ^^ OH MY.... ^^
              How many thousands of LCD monitors have you fixed to collect all that?
              Gee. To think I already had second thoughts of doing a lamp replacement after I did my first, because I thought it was so "involved".
              My deepest respects and hat off to you sir! You have quite the patience and skill.
              • MATRIX COMPUTERS
                • Dec 2018
                • 11
                • tanta
                #87
                thanks a lot it is a useful idea....
                • kart24
                  • Dec 2018
                  • 4
                  • india
                  #88
                  Can I be able to use this technique in following picture, where there is only lead out from the master and slave as in the picture.
                  will there be any circuit or capacitors underneath?
                  this is a old 32 inch , lg 32lh60yr. backiight sometimes stays on varying intervals,sometimes just flashes just for a second. and want to determine inverter or lamps that is bust.
                  panel : lc320wud
                  inverter board : LG 6632L-0548A
                  thanks for the help
                  • kart24
                    • Dec 2018
                    • 4
                    • india
                    #89
                    panel : lc320wud
                    thanks for the help
                    with attachment this time
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #90
                      Can't say for sure. You would have to trace how the CCFLs inside the LCD are connected. Perhaps someone who've seen this might know better. But from what I can guess, there are two possibilities: either each CCFL inside the LCD is connected to ground (or perhaps another grounding circuit) -or- two CCFLs are in series and there is no connection to ground anywhere.
                      If it's the latter, I'm not sure if a regular CFL would be okay or not, as the voltage might be much higher. And if it's the former, then it becomes a question of where/what circuit the CFL should be grounded to.
                      Thus, I think you might need to make a new thread on this, open up the LCD screen so that you can trace how the CCFLs are connected inside, and post pictures there. That should allows for a more definitive answer, I think... of course, unless someone has seen this before and can tell you for sure.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5095
                        • New Zealand
                        #91
                        Perhaps if you trace out how the output windings of the transformers are connected it will give you some clues?
                        -David VanHorn
                        • Lapy
                          • Dec 2018
                          • 15
                          • algeria
                          #92
                          Many thanks
                          • alepol
                            • Mar 2020
                            • 8
                            • france
                            #93
                            Hello every body,
                            I m French so please excuse me for my not excellent english.
                            I have an LCD TV Samsung LE37B530 with BN44-00301 Power Board and i have an issue with Backligh.
                            The Bakligh always Blink, with or without connection to main board.
                            I read and read again the post here but nothing.
                            I try with a CFL and is lighting 5 second and stop but no Blinking
                            Thanks for you help and KEEP AT HOME .
                            Regards
                            • ekjdm14
                              • Apr 2020
                              • 5
                              • United Kingdom
                              #94
                              It could be that the CFL is drawing slightly less/more current than your backlight tubes would, hence it's still going into protection but taking slightly longer to do so? Just a guess but seems possible given the arrangement of the lamps in this set.
                              • bob2weed
                                • Jun 2021
                                • 1
                                • Brasil
                                #95
                                Can I test other LCD screens in the place of the original?
                                • eccerr0r
                                  inverter H tree driver imbalance in an AC inverter
                                  by eccerr0r
                                  My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                  11-16-2025, 12:34 PM
                                • Yanleb
                                  Sharp LC-60LE810UN Lamp Error
                                  by Yanleb
                                  I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                  I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                  Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                  I've tried all the key...
                                  08-24-2021, 11:48 PM
                                • vestaviascott
                                  Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                  by vestaviascott
                                  Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                  Here's what happens:
                                  1) Power on
                                  2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                  3) Blue status light flashes for appx 4 minutes...
                                  07-29-2020, 06:08 AM
                                • Gentian
                                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                  by Gentian
                                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                  03-06-2023, 07:07 AM
                                • valvashon
                                  Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                  by valvashon
                                  For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                  History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                  01-04-2024, 01:44 PM
