Does flux expire ?? Flux discussion.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Does flux expire ?? Flux discussion.
    Coliformia is the state made of colifony of course <BOOO! HISS!>
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #82
      Remember that can of polish flux ? The one I said I had no idea what it was called because the sticker was on the bottom ? Gave it a whirl today and it was....meh. I had to reflow some connections on a QFP and a USB mini-B connector. It went...mediocre at best: solder blobs everywhere and the flux seemed to dry rather quickly. The tip I used was the bevel one (slanted) and it seem to go worse than the T-IS (curved) one, so I ended up using that one instead and I kept adding flux and wicking around until I managed to get somewhat acceptable results, but it wasn't fast and not exactly professional....a pro tech would not be impressed with the time it took me to reflow those....
      The tips and temperature also seem to play a role. I ended up dialing down the temp from 420C to around 390C (on the display at least) on my Gordak because the tip was starting to get gray and looked burnt and charred, so solder wasn't sticking to it and was instead blobbing on my pins instead . Lowering the temperature allowed it to stay shiny a bit longer and I got somewhat more acceptable results, but STILL had to wick around more than I would like....or perhaps that's not a bad thing.
      Wattevah...
        • 31218
        i wouldnt go over 350 with flux of any type.
        it is pretty crap though, i only use mine for tinning old wires
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          #84
          The temperature on the display is probably considerably off compared to the actual temperature at the tip, so I prefer to keep it a bit higher, knowing the tip is going to be colder anyway. Besides, I mostly go by feel rather than numbers and I sometimes found that not enough heat can lead to poor/frustrating results just as well as TOO MUCH heat....
          Wattevah...
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #85
            Originally posted by diif
            Sure is. Mine is about 3 years old and has the same Lot# as half of those sold today. It's like a copy of a copy of a copy. A bit pot luck how good it is, some stays thick longer than others.
            Yup.
            Apparently, Kingbo is just another generic Chinese RMA flux, so the quality will vary. But from what I've seen myself and heard from others so far, it's anywhere from acceptably working to very decent. So it's not junk / terrible, typically.
            My jar is about 7 years old now. It used to be light tan when it was new. Now it's piss-yellow (the kind of yellow urine you get after not drinking enough water and eating salty shit all day.) It still works, though. Just seems to smoke a lot more and definitely smells worse. Also doesn't seem to stay active for as long at high temperatures / gunks up faster. But like I said, it still works okay, more or less.
            So I wouldn't say flux expires - especially rosin fluxes. But in the case of my Kingbo, it did drop down a bit of its stability at high temperature, it seems. And in the case of rosin fluxes... well, those could dry up due to the alcohol evaporating from them - but that's usually fixable by adding more alcohol.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #86
              ROFL ! I think I just spat my drink all over the laptop - liquid damage !
              Ok, so it wasn't the flux that was bad after all, it was just me who sucked on those QFNs back there
              I too noticed the kingbo flux I pictured below smokes a LOT - Mr G. let me use some once when I quickly needed to desolder something at his table and I dipped the wick in it to make it more absorbent and it smoked so much that I couldn't see what I was doing and choked on the smoke. Then again, he keeps his iron turned all the way up, so it was probably REALLY hot...
              Wattevah...
              • zhang
                • Jun 2017
                • 50
                • Indonesia
                #87
                Could it be hot air settings?
                if the "air" is too high, when the fluxes melted it will go everywhere but the "place you want to melt"
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #88
                  True, though I did turn it way down because of this reason. Not to mention, it also tends to blow away the part you're working on as well, plus other smaller ones around it, quickly turning a 5 minute repair job into a 1 hour nightmare....
                  Wattevah...
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #89
                    The air speed is too high if you're blowing away other parts.
                    • clearchris
                      • Dec 2013
                      • 687
                      Can confirm momaka's experience with kingbo. It has darkened, especially where I dip the tip in. When new, it was a light cream color. Still seems to work just fine. It does smoke a lot, I hold my breath when soldering anyway, helps to keep the hands steady. I used to seal it after using and it stayed the same color, but it has spent the past three years open on my bench.
                      The only way the residue will come off is with brake cleaner in my experience. Must be careful about that stuff, the cleaner must be completely gone before soldering.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        #91
                        Well, I keep mine closed and have never dipped my iron's tip in it, but it still went dark. I'm thinking it has more to do reaction to UV light. Although I keep my flux away from direct sunlight for the most part, I do have a ton of natural light (big North-facing bay window) on my workbench area, which is where the flux is.
                        And yes, I try to hold my breath too when using large amounts of Kingbo. Though, I usually apply very very little - about the size of a tiny beach sand grain (or two) per joint, which turns out to be just enough. Any less, and I get cold-looking joints. Any more, and I have to do more clean up. Speaking of which...
                        I use 99.9% IPA, and the Kingbo flux comes off fine. Only time I've had problems removing it is if I burned it onto the board to a crisp. But in that case, I just chip it off.
                        Oh man, I've seen a rookie tech do that before, and it was so funny! The smoke made him think the board must have caught fire or something, so he dropped the iron and the wick and jumped back. Made me laugh seeing it. Almost had a hard time convincing him this was actually normal... at least for the amount of flux he was using (which was too much!) If you have to flux wick, do it with a brush and apply little. Or use a tootpick and spread a rice grain -sized or smaller piece of flux.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I would guess the animal fat based fluxes could expire when they go rancid (but even then...). Now how about fully hydrogenated shortening instead...?
                          • chth96
                            Is it good to use chemistronic flux off es835b for flux remover?
                            by chth96
                            I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                            Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                            11-17-2023, 07:25 AM
                          • evilkitty
                            Flux causing high resistance short?
                            by evilkitty
                            Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                            Temp is on the left humidity is on the right
                            i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                            The pin out looking down from the top is (note this is common cathode)...
                            07-17-2024, 09:38 AM
                            Multifix 425-01 and 450-01 Rework Flux Datasheet
                            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                            - No Clean Formulations
                            - Low residue
                            - Range of activity to deal with different component solderability
                            - Halide free
                            - Suitable for dispensing
                            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                            Both products are supplied in syringes or cartridges for application by dispensing....
                            10-07-2024, 06:02 AM
                          • chth96
                            How can I remove flux with the smallest rubbing?
                            by chth96
                            I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                            Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                            Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                            Is there any way to remove flux with the smallest rubbing or without any rubbing?
                            Any reply would be appreciated.
                            11-24-2023, 05:22 PM
                          • tony359
                            Non darkening Flux?
                            by tony359
                            I was watching a video from NorthWest Repair (The guy there is just doing such incredible repairs) and while he was fixing a bunch of pads on a GPU PCB, I saw this
                            I've been trying to fix some broken traces on a PS3 CPU for a while but one major issue I'm seeing with my AMTECH flux is that it gets tacky and dark very quickly and then it's a pain to remove and replace.
                            In the video Tony (I think it's his name) seems to suggest that I am just using the wrong flux?
                            Any thoughts or ideas?
                            Full video is here: https://w...
                            02-03-2024, 08:25 AM
