the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • bluto
    • Oct 2007
    • 560
    #81
    Re: the gutless, bloated, and fried power supply hall of shame
    Nice. Its sad to think that someone sits there and removes parts until the thing stops working. Then they just put the very last part back and ship it! I didn't notice the lack of a bridge rectifier until you pointed it out. I guess they ran out of them that day! And I just noticed that like yours, the primary filter caps on mine are rated for only 200v. So much for being able to use the high side of the 120v/230v selector switch! They could have left that off and saved another 2 cents. I guess I'll tuck this one away for possible repair in the future just in case.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      The two primary caps are in series, so they can handle 400V total, but only 165uf of capacitance combined. (almost all non-APFC designs use this. APFC designs use a single 400-450V cap to save room for the APFC circuitry.)
      • bluto
        • Oct 2007
        • 560
        #83
        That makes sense. I guess even for an el-cheapo PSU, purposely over-volting the primary filter caps would be taking it too far.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          #84
          Originally posted by bluto
          The large IC (SBL304OPT)- i think is the schottky diode, is showing a short across the two outer pins.
          That's normal since the two outer pins connect to the transformer, and SMPS transformers have too few winding on the output side so they always read short circuit between pins.
          Instead, try measuring resistance between middle and outside pins. On this one you shouldn't get a short circuit.
          Also, you only have 330uF capacitors on the primary, so don't expect more than 200-250 watts from this thing.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Yeah I just noticed the "win250" silkscreened on the bottom.
            • c_hegge
              • Sep 2009
              • 5219
              Another Excel. It's rated for 400W - ROFLMHO.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5000
                • New Zealand
                #87
                I've got a 250 Watt Novia which looks exactly the same...
                -David VanHorn
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  not as bad as the 480 watt echo star with the dummy weights, but still disappointing. the secondary is tiny, ant the primary has 4 diodes. total junk
                  sigpic
                  (Insert witty quote here)
                  • japlytic
                    • Oct 2005
                    • 2086
                    The blown Sanyo TT2144 primary transistors were only rated for 250W power supplies:
                    A possible substitute for the TT2144 is the TT2194 (500VCBo, 400VCEo, 12A, 50W).
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #90
                      Disappointing indeed, but not that horrible at all. It does have X/Y caps, a coil, and also OVP and UVP. The heatsinks are tiny, though, and there aren't enough caps on the secondary. Note the small transformer marked with a fake size 35 label, too.
                      That's actually not that much of a problem. Line voltage in Australia is 230v so even if these diodes are rated for 1.5A each, the PSU can still pull 345 watts theoretically (if it can withstand that much ).
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5000
                        • New Zealand
                        #91
                        That's actually not that much of a problem. Line voltage in Australia is 230v so even if these diodes are rated for 1.5A each, the PSU can still pull 345 watts theoretically.
                        I agree, what is wrong with using diodes vs a bridge?
                        Most PSU problems I've seen are stuffed transistors or secondary-side recitifers or leaking capacitors.
                        Hardly ever see a problem with the primary side components. (unless caused by a fool who flipped the voltage switch or a power surge etc)
                        -David VanHorn
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #92
                          Agent24; it is difficult to get airflow down to the diodes
                          A bridge rectifier is high up so it gets some airflow, plus if the manufacturer wants he can install a heatsink on it aswell
                          The diode treatment is the cheapo way out, cheaper than using a bridge rectifier...
                          But it's a more sensible cost savings approach than removing all primary side filtering components like some manufacturers do!
                          • bluto
                            • Oct 2007
                            • 560
                            #93
                            I started messing with this one, harvesting parts from other busted PSUs and such. I have a question about the transformer behind YC1 & YC2. What would one call that piece in order to find a similar unit on Digikey? I pulled on off another PSU, but unfortunately it was a little too big (pins didn't line up with the holes). And what kind of capacitors should I be looking for to populate YC1-YC4?
                            and that's what the primary side filtering is supposed to look like..
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5000
                              • New Zealand
                              #94
                              I think it's a line filter rather than a transformer.
                              If the holes don't line up exactly you can probably enlarge them or drill new ones. The pads should be large enough to allow for this.
                              -David VanHorn
                              • etnietering
                                • Apr 2009
                                • 379
                                On Digikey, look under "Common Mode Chokes" in the "Filters" category. There's a couple thousand to choose from.
                                For the Y capacitors, search for "Y1" or "Y2", and then look in the Ceramic or Film Capacitor categories. Most important thing to worry about here is the lead spacing too.
                                • bluto
                                  • Oct 2007
                                  • 560
                                  #96
                                  I am in the ballpark for the coil. I found ones that are somewhat similar looking. But for ~$5, I might look around for some more old PSUs. I guess I can see why they would leave them off to increase the bottom line.
                                  Here is one that I am thinking might work: http://search.digikey.com/scripts/Dk...ame=PLK1324-ND
                                  As for the capacitors there are about 32 different choices that fall under the category 250V/High Voltage/Safety. The pF rating goes from 15pF to 4700pF. Is there any value that I should shoot for here?
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    #97
                                    Not sure, but from what I noticed most PSUs will use 1nF to 3.3nF (1000pF to 3300pF).
                                    As for the choke - you're probably better off finding some old junk PSUs like you said. They'll likely have the safety X/Y caps too.
                                    • pegdizzler
                                      • Aug 2010
                                      • 19
                                      #98
                                      Anyone want to see the guts of these?
                                      And maybe a Tagan ITZ 700W (1 of 4 that I'm willing to open, seen in blue box on left side of picture) and a monster DPS-750 (220v) out of an 8-way PIII Xeon server for dessert!
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        holy cow uve got lotsa psus
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          only the bad ones, this is not build quality pictorial, this is the hall of shame. server power supplies that are not blown up do not count (they are very nice actually)
                                          in pic #1, i'd try the black one and column 1 2nd from the top. the latter has thin wire (it has to be gutless!) and the black one looks like a gamer wannabe unit...
                                          i see a hipro built one, it has a blue "void if broken" sticker, those are very well built.
                                          sigpic
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
