LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • alexxis
    • May 2020
    • 8
    • Russia
    #81
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    [QUOTE=Knucklegrumble;984697][ HOW TO USE THE PATCH ]
    STEP 1: Flash and replace current BIOS with the generated patch file
    STEP 2: Boot the machine
    [B][COLOR="Red"]STEP 3: Press ENTER/F1/etc. to enter BIOS settings
    After Step 2: I cannot enter BIOS by pressing Enter/F1/etc. The machine does not respond to key presses at all. And I do not see the string with a prompt to enter the BIOS. I see only one string as I wrote: "Press Enter to interrupt a normal boot order".
    • alexxis
      • May 2020
      • 8
      • Russia
      #82
      It seems my BIOS dump is corrupted (see a screenshot). Correct?
      But after reflash machine by original (corrupted?) BIOS I get machine with normally booting Win10.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1332
        • France
        #83
        Originally posted by Sagittarius75
        Thanks Maxpower,
        -No changes of SN, HWid, MacIds, (only changed OA2 String. What is this?)
        -Enjoy your Thinkpad.
        OA (OEM Activation) is used to Activate Windows using OEM keys that is provided by the manufacturer. OA 2 was used for Windows Vista and OA 3 is used in Windows 10 for activation.
        • Knucklegrumble
          • Jun 2020
          • 78
          • US
          #84
          I can't tell by the screenshot if it's corrupted.
          What model is it? Can you post your original bios dump?
          • alexxis
            • May 2020
            • 8
            • Russia
            #85
            Lenovo x1 Carbon 2nd Gen.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1332
              • France
              #86
              there is a 24rf08 on it no?
              the patch does not work on it
              edit:X1 Carbon gen1 (génération 2 et 3 utilisent MEC1633L )
              • alexxis
                • May 2020
                • 8
                • Russia
                #87
                No, there isn't. My machine has mx25l12873f scheme: https://www.macronix.com/en-us/produ...?p=MX25L12873F
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1332
                  • France
                  #88
                  test
                  • alexxis
                    • May 2020
                    • 8
                    • Russia
                    #89
                    test
                    Test did not passed. I see the same thing. After power on I hear 5 bips and 5 bips, then a black background with the Lenovo logo and the line: "To interrupt normal startup, press Enter".
                    If I press Enter, nothing changes.
                    • Knucklegrumble
                      • Jun 2020
                      • 78
                      • US
                      #90
                      Did you hold down the anti tamper switch and removed your hard drive?
                      • alexxis
                        • May 2020
                        • 8
                        • Russia
                        #91
                        No, I didn't. I'm so sorry! I was hoping that without him everything would works. And during the flashing I completely forgot about it. And I don't know how to do "hold down the anti tamper switch". Could you help me with this? Where can I find this switch?
                        • alexxis
                          • May 2020
                          • 8
                          • Russia
                          #92
                          Thank you very much for help to my dear friends Knucklegrumble and Maxpower3!
                          It seems all works properly now. But I did not find anti-tamper switch at my machine.
                          • Dr.Brown
                            • Aug 2020
                            • 3
                            I tried to patch a T450 but it does not work.
                            After reboot I can hear 5 beeps two times. After that I see the message "Press Enter to interrupt a normal boot". After I hit enter and pressed F1 to enter BIOS, a black screen appears and the system hangs.
                            There is no harddisk in the system and I also tried with pressed tamper switch.
                            This is the output from patching the BIOS:
                            Code:
                            Using UEFIReplace to inject 2 DXE drivers...
                            [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                            [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                            Looking for volumes to patch...
                            [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                               Not found... Skipping.
                            Done.
                            PATCH FILE: t450-bios-orig-1_PATCHED.bin
                            Good luck.
                            Attached you can find the original BIOS dump.
                            Do you have an idea, what's wrong?
                            • Knucklegrumble
                              • Jun 2020
                              • 78
                              • US
                              #94
                              Some models might not have it.
                              • Knucklegrumble
                                • Jun 2020
                                • 78
                                • US
                                #95
                                Code:
                                Done.
                                Good luck.
                                Are you sure you have supervisor password enabled?
                                • Dr.Brown
                                  • Aug 2020
                                  • 3
                                  See the attached picture. I think this is the Supervisor password!?
                                  • Knucklegrumble
                                    • Jun 2020
                                    • 78
                                    • US
                                    #97
                                    Hard to tell some times with lenovo's... They have the same icons for boot and supervisor password... Can you boot into your os with original bios? Can you enter bios settings? If you can send a picture of the security section in bios
                                    • Sagittarius75
                                      • Aug 2020
                                      • 2
                                      • Turkey
                                      #98
                                      Dear Maxpower,
                                      I think mine power on time to show boot logo is appear long. May be bug or no? Do you know any uefi bios strings for check the first initialization time? (i wanna explain: after power button on, keyboard checking ok with her lights up and down. Then i have very long waiting time for backlight of screen. )
                                      Best Regards;
                                      Fatih
                                      • Dr.Brown
                                        • Aug 2020
                                        • 3
                                        Your're right, it was not the supervisor password.
                                        Sorry for wasting your time. Thank you very much :-)
                                        • Knucklegrumble
                                          • Jun 2020
                                          • 78
                                          • US
                                          #100
                                          No worries. Glad I could help.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
