ESR meter upgrades
This is a sticky topic.
    • 31144
    Re: ESR meter upgrades
    223 is 22nF
    you need 220nF (224)
    • sauna
      • Dec 2016
      • 3
      • Lithuania
      #1022
      Thank you, stj.I've tried everything.at the last stage, he does not measure anything.
      as if stuck tightly.
      • sauna
        • Dec 2016
        • 3
        • Lithuania
        #1023
        I will explain the test.what it should be.
        1. in the first stage, short circuit to 123
        2. the second stage I have a 2 mf capacitor
        3 .0.022 capacitor.this is 223j.this is 23nf
        or am I wrong?
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          How much calibration do these need anyway, these devices vary so much that we need 0.1% capacitors to calibrate them? Uhoh.
          2uF capacitor? (I've hated "mF" for uF even though they've done this in the past, grr. I don't like mmf for pf either. Make Money Fast!)
          0.022uF = 22nF = 22000pF = 22 x 10³ pF = code 223; 223j = 0.022uF±5%
          I don't think I have any accurate (i.e. not a ceramic) 0.22uF capacitor... needed for calibration?
            • 31144
            a copy/paste from my old txt
            after programming, you need to calibrate the unit. (preferably twice)
            you need something to short all 3 inputs,
            and an accurate capacitor between 100n and 1uf - i recommend a 220n polyester cap.
            you also need a good stable capacitor between 10 and 30nF to calibrate the new small inductor mode.
            if you dont have one, just ignore the cal message till it times-out
            • redwire
              • Dec 2010
              • 3912
              If the crystal does not match the MCU fuse setting, as well as the F/W- there are problems. Fast F/W with low crystal will read smaller C values I think.
              i.e. compiled F/W build is for 20MHz, crystal fuse 8MHz, C readings too low.
              TransistorTester with AVR microcontroller and a little more
              Version 1.13k Karl-Heinz Kubbeler
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Ah so the actual value doesn't matter and you don't need to "enter" the value in...? interesting. I guess with accurate "T" and "R" you can still find accurate "C".
                Will be interesting to compare this to the Sencore.
                  • 31144
                  you need firmware that matches the crystal speed because there are time-constants in the software.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    And how accurate is the crystal or is it using the on-chip oscillator, that thing really should be calibrated too...not sure if atmel^H^H^H^H^H^H microchip tunes those to 1ppm?
                      • 31144
                      it's 100% crystal.
                      that's one of the reasons why you do the cal procedure.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        How does one calibrate the crystal or is it dependent on the crystal being accurate? Can crystal errors be calibrated to some NIST traceable source?
                          • 31144
                          it's assumed you have a decent crystal and a good pcb track layout.
                          most crystals are 20ppm or better now, and variance in smd caps is very low.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            One would hope that they are, though for like microprocessors there's a reason most computers have a huge variance between them despite being the "same" frequency...
                            • clearchris
                              • Dec 2013
                              • 687
                              How essential is a rotary encoder to the software? I understood that it was pretty important to navigate the menus, and both meters with enough flash to support all the functions (hiland) and tc-1 have only a button.
                                • 31144
                                if it's a large button and not a 5mm one then a rotary fits the pads.
                                i'v put a rotary on a tc1
                                essential - no, but it's nice to have for extra modes.
                                tc1 has issues btw, you want to pull the 8pin mcu and replace it with a discrete 2 transistor circuit.
                                it controls the power - but has a habit of drawing current instead of sleeping - 100mA of current!
                                • clearchris
                                  • Dec 2013
                                  • 687
                                  Ha, how many different models do you have?
                                  I looked through some of this thread and some of the 277 page thread on eev and it seems that there's no perfect lcr at any price. I'm starting to thing having two might be the best option, I already have an lcr-t4, so maybe if I get a tc1 that can round out the collection.
                                  The other LCR that seems interesting is the Highland M644 which has some specfic hardware for frequency counting.
                                  From what I have read, you can reprogram the MCU on the TC1 so you don't have to replace it with 2 transistors. It's unfortunate that it comes with a case, but I can print a new one...
                                    • 31144
                                    you can reprogram the stc micro on a tc1 - it still crashes out of sleep mode though.
                                    • clearchris
                                      • Dec 2013
                                      • 687
                                      Hmm, I saw a reference to using the two transistors or reprogramming the u4. Maybe it was with the assumption that the reader does the programming. I have however seen .bin files for the u4 mcu though in that thread, I wonder what they do...
                                        • 31144
                                        the bin files arent a real fix.
                                        this is:
                                        • clearchris
                                          • Dec 2013
                                          • 687
                                          Damn, that's a lot to fit on a small pad. Are people soldering in small boards? At a point, I think it would be better to splice in an on/off switch on the line to the battery.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
