ESR meter upgrades
This is a sticky topic.
    • 31129
    Re: ESR meter upgrades
    the mcu can push/pull 30mA, the limit is caused by the resistors.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      So far at least for capacitors that have wire leads, transistortester doing a good job for them IMHO, at least in one test it shows more information about the capacitor that I'd need multiple instruments to do.
      transistortester just seems to be doing a not so good job with thyristors that can be plugged into it.
      I'm also somewhat surprised it can test inductors...well, dismayed that microhenry inductors don't do so well but millihenry inductors read fine.
        • 31129
        the newer software and a faster crystal can improve that, or go all out and add this:
          • 31129
          got bored,
          made a quick build for GM328's - the real ones with a monochrome display, not the black clones of an "AY-AT".
          20MHz only - because you should be too.
          rotary encoder helps
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            More interesting things to measure.
            Tried measuring a 0.047F supercap.
            It reported 21.xx mF with ~9% loss and ~8Ω ESR.
            Hmm... not sure what to make of this. Bad EDLC or confused meter...
              • 31129
              if you run it with nothing what does it say?
              biggest problem i'v had with these units is leaky or shorted protection diodes
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I think the meter's fine, reports "no or unsupported device" with nothing plugged in, and remains in capacitor mode when the supercap is removed - but whether it detects supercaps correctly is the question... 9% loss is pretty huge, and 21mF vs 0.047F is about half, though I'd expect leakage to increase apparent capacitance instead of decrease.
                Then using jumpers testing a 10000uF/16V, 4700uF/35V, and a 4400uF/50V standard capacitors and they came up pretty close to expected readings... just the supercap might be bad?
                  • 31129
                  i tried supercaps long ago when these things first came out and they where identified as a "cell" so it thought it was charging a battery!!
                  i dont know if that has improved since.
                  actually i think i have one - i'll report back.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    The 0.047uF supercap is rated at 5.5V. Checking its voltage when charged up, yes this thing seems to leak fast when charged to 3.6V so it may be bad, but it settles down to 3.2v and stops leaking down as quickly... Not sure what to make of it.
                    A capacitor of sufficient capacity may well be called a "cell"... does it actually detect batteries? Seems like a dangerous thing to hook up for the longevity of the device...
                      • 31129
                      o.k. i tried a couple of .47 at 5v ones.
                      dont work
                      both gave different readings so they could be fucked - but i dont think so.
                      they do have limited charge/discharge cycles though.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        I charged up this supercap to 3.6V for a couple seconds, well it indeed can light an LED with a 1K resistor for quite a while. After discharging it for several seconds through that LED (disconnected before it was flat - it was 2.4V), it was still able to light a 1W LED through a joule thief for a bit more than half a second before it went flat. So this supercap sort of works...
                        What kind of readings did you get?
                        Oh, after a charge/discharge cycle transistortester read 23mF... a bit higher but still lower than expected.
                          • 31129
                          one gave me 84uf, the other just gave a resistance!
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            lol yeah that's not very good... ever tried regular capacitors that big? I haven't tried anything beyond this 0.047F yet... need to see what it does with 0.22F and 0.3F that I think I have...
                            Just tried 0.22F - it gave up, no or unsupported device.
                            BTW seems that having big caps inserted on power up really slows down the power on auto self-cal it seems haha.
                              • 31129
                              largest cap i have tried was 22,000 uf - it read just fine.
                              i doubt i'll ever find anything bigger than that.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Start paralleling them up
                                hmm... need to see some others between 0.22F and 0.047F. 0.01F worked just fine too.
                                Tried 0.04F/50V capacitor - reads as 52mF 0.13Ω ESR 1.9% loss... I guess that's acceptable and within 25%...
                                Added a 0.015F capacitor in parallel to the 0.04F... read 71.66mF -- 31% error.
                                Added a 0.0165F capacitor in parallel to the 0.15F and 0.04F... read 92mF, that's a 29% error.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Just wondering... Ever since I got this AVRTransistorTester it's pretty much stayed in my "toy" pile and have yet to actually find a bad transistor or other device that I already knew of its status of good or bad from other tools or debugging techniques... Has anyone felt the same way? Or perhaps my source of parts that need testing past basic debug techniques is low... Plus the false positives (like the thyristors that can't be triggered)...
                                  Granted this thing does tell me a lot more of any device I stick into it than any other tool that I've used for any particular device that it supports.
                                  Yes this sorta sounds like parade raining but just wonder how other people feel... do they use it a lot? Has it saved you effort? How so?
                                  • jondoe
                                    • Nov 2016
                                    • 547
                                    I used mine the other day to confirm a suspicion that the mains filter caps on a device weren't performing as they should. Sure enough the test showed they were 50% of their rated value, I swapped them out, all was good after that.
                                      • 31129
                                      i use it a lot to check transistors for shit my multimeter diode check would miss,
                                      like bad hfe or an internal diode
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Perhaps my issue is that I don't remove things until I'm sure something's dead... But once I find components are dead in circuit I don't need to test it again out of circuit. I guess that's why I'm not finding it as helpful as some people are.
                                          • 31129
                                          your not working on digital stuff then.
                                          i recently pulled 16 transistors that powered solenoids,
                                          didnt know the spec so just compared them to find the odd one(s) out.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
