ESR meter upgrades
This is a sticky topic.
    • 31218
    Re: ESR meter upgrades
    i meant capacitors - most people only want the henry's of an inductor
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      ESR of inductors is important too Granted it shouldn't change...
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #1103
        Originally posted by stj
        it works a lot better if you use my firmware instead of the factory one.
        it's had the esr/inductor code re-written since the chinese compiled it.
        also, a 20MHz crystal increases the accuracy.
        (but you need to reprogram it to recognise the crystal)
        Yeah, I know really should do that, as you've suggested it to me many times now. I don't have a programmer, though... and I generally shy away from anything that has to do with programming firmware, as I never seem to do things right, thus always ending up struggling. (Programming and digital electronics have always been my weak side.)
        Also, I wonder if there's an updated version of the firmware, but for the stock 8 MHz crystal.
        Originally posted by eccerr0r
        I thought if I hook up any two wires to the tester, it will give me the expected reading; if I connect all three to the tester, it gives me two resistors...
        Hmm. Maybe because the autotransformer windings are a coupled inductor, that's making the TT confused?
        In any case, I still think it should be able to measure the inductance of the individual windings, one at a time. If not, then probably the inductance is too low.
        Inductors have ESR?
        I thought they only have inductance and resistance from the windings... and maybe a slight hint of stray capacitance when the windings are close to other objects in the circuit??
        But I guess at very high frequencies, the skin effect will make it appear as if the windings have overall higher resistance. Perhaps that's what you mean by ESR?
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Yes...well equivalent series resistance I'm considering things that you don't see at DC.
          Dunno. took an even "bigger" tapped inductor (one side of a transformer) and fed one side into transistortester and it gave me two resistors. Couldn't make heads or tails of it. Actually it's pretty funny what it did, not going to post results to add to suspense
          Warning: Don't go too big of an inductor, I think you might damage your transistortester, which would be the sole hint...
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            #1105
            The project is always evolving: You have two firmware branches:
            M-firmware by Markus (username Madires on the eevblog forum)
            K-firmware by Karl-Heinz Kübbeler (username kubi48 on the Mikrocontroller forum)
            These can be compiled with any options and crystals you choose.
            Both I and STJ have posted a couple precompiled here, but then where is the fun in that?
            Much better to go crazy and do it all yourself
              • 31218
              i do M builds for the TC1 with a rotary encoder and 20MHz if anybody wants it posted.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #1107
                Thanks!
                Bookmarked for when I feel confident enough to upgrade mine some day.
                Bricking it would be a major setback for me in terms of being able to check out e-caps.
                Erm.... no. I'll probably completely mess up everything.
                Digital circuits was never my specialty. And programing/firmware/compiling... I always screw up somewhere and spend hours trying to do something simple.
                So I'll probably just have a look at the links you mentioned and see if there is something pre-compiled there (and hopefully with hand-holding detailed step-by-step instructions for the software-challenged, like myself. )
                • mazenkataya
                  • Dec 2021
                  • 45
                  • lebanon
                  #1108
                  thank u
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I should figure out how to upgrade mine... build my own fw, etc. Too bad the one I have does not have the pins ported out on a 2x3 or 2x5 Atmel 0.1" header
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Curiosity... what's the word(and language) that the "U" comes from when the avrtransistortester displays voltage for Vf and Vbe? (It whimsically says Uf=0.700 or something for diodes, etc.)
                      I would have thought for an English port it should have V for Voltage. I guess this is a pet peeve that I need to change on my unit...
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #1111
                        Considering the title of the thread I didn't want Bop Parkers great ESR meter to feel left out!
                        So here it is with some nice new bright Lite-On LTS-5003AWC 7-segment LED's before and after
                        Original LED's:
                        Replacement LED's:
                        • Bob Parker
                          Technician
                          • Feb 2007
                          • 182
                          Originally posted by japlytic
                          There is one thing ESR meters should have, which is Kelvin sensing (4-wire measurement capability), which keeps measurement errors to a minimum.
                          The "Blue2" ESR meter has that.
                          It is a good shrubbery. I like the laurels particularly...
                          • Bob Parker
                            Technician
                            • Feb 2007
                            • 182
                            Original LED's:
                            Replacement LED's:
                            Thanks Per. It's amazing how much brighter even cheap Chinese displays are, compared to what was available back in 1995 when I designed the original meter! 👍
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              This is annoying:
                              I had a transistor that was shorted... stuck it in the avr transistortester...
                              Went into cal mode! What a pain...
                                • 31218
                                lol - it shouldnt go directly into cal,
                                it should show a message and wait for confirmation with the button.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #1116
                                  I compiled a new build of Karl-Heinz firmware from the new GIT repository a few days ago.
                                  It works well on my GM328R, this time I only included a 20Mhz build.
                                  I also replaced the encoder and that fixed the bad behavior I described earlier in the thread with Madires firmware.
                                  I made a small post on eevblog about it if you're curious:
                                  https://www.eevblog.com/forum/testge...41/#msg4259041
                                    • 31218
                                    was the encoder blue?
                                    i buy the light green ones - they seem better quality
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #1118
                                      You can see a photo of the top of the encoder in my original build photo way back in this thread: https://www.badcaps.net/forum/attach...6&d=1468518476
                                      Here is how the bottom looks, it is light green, this is what was delivered with the DIY kit...
                                        • 31218
                                        not seen those before,
                                        the ones i refered to are all one colour.
                                        i think the blue has splines on the shaft, the light green has the half-moon shaft type.
                                        i call it that anyway
                                        • jellytot
                                          • Mar 2015
                                          • 42
                                          • Ireland
                                          #1120
                                          Hi Stj. I'm interested in your TC1 project... can you provide more info please/
                                          Thank you.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
