Dell Latitude 5520 Bios Password unlock
  • lequangthanhit
    • Feb 2015
    • 1
    • Việt Nam
    #101
    Re: Dell Latitude 5520 Bios Password unlock
    pls remove bios password
    thk
    • ymifdal
      • Jan 2022
      • 120
      • Morocco
      #102
      thk
      There is no file attached
      • HarryH
        • Feb 2017
        • 10
        • Poland
        #103
        Originally posted by hoaca388
        Check the chip soldering process, flash bios. Unlock operation is correct.
        I check everything and still have problem to start. Blinking 3 amber 6 white light and turn off.
        • Mazorca
          • Jan 2017
          • 463
          Are you using a clip? Do not rely on it. If not, your backup should always work, try flashing it back. If same symptoms, then check for moved or missing components nearby. Check voltages, start at leg/pad #8 of BIOS chip, should be 1.8v or very close for new laptops. Do not press on bios chip when soldering, it might "squirt" solder to nearby pads if it is too much. I reach the same identical file as hoaca388 when unlocking.
          • HarryH
            • Feb 2017
            • 10
            • Poland
            #105
            chip has 3.3v, is soldered good, I dont use clip, my file was from mrwab
            • Mazorca
              • Jan 2017
              • 463
              I checked it too, procedure is correct, I reach an identical file. Desolder and verify that the flashing was good? Try your backup, it should work always.
              • hpboy
                • Jan 2021
                • 53
                @Mazorca Please could you help unlock this BIOS Admin password on a Dell Vostro 3590 (E7A8) please? I would be very grateful..
                Thanks in advance
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12281
                  #108
                  Thanks in advance
                  https://beta.bios-pw.org/
                  ​https://www.badcaps.net/donate
                  • hpboy
                    • Jan 2021
                    • 53
                    Have tried bios-pw.org and the codes do not work
                    • hpboy
                      • Jan 2021
                      • 53
                      Thanks hoaca388 - tried bios-pw.org and the codes do not work. As this is E7A8, I believe bios-pw.org will not work on the admin password lock
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12281
                        #111
                        Note that the keyboard to enter the password must be Qwerty US layout (can use an external keyboard via USB 2.0 port). For uppercase letters, use the Capslock key.
                        • hpboy
                          • Jan 2021
                          • 53
                          I stand corrected Sir... Just tried with an external US keyboard and code worked perfectly. Thank you for your help, much appreciated.
                          • dimah77
                            • Sep 2016
                            • 147
                            • ALGERIA
                            #113
                            hi the team, Please unlock 5520 bios
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12281
                              #114
                              UNlocked
                              • dimah77
                                • Sep 2016
                                • 147
                                • ALGERIA
                                #115
                                UNlocked
                                All my gratitude sir
                                • darckreign1984
                                  • 260
                                  • Romania
                                  #116
                                  heloo.
                                  my dell latitude 5520 have a password (master password)
                                  can you help me with password please. Dell 8fc8
                                  Thanks in advance
                                  • darckreign1984
                                    • 260
                                    • Romania
                                    #117
                                    Originally posted by darckreign1984
                                    heloo.
                                    Thanks in advance
                                    i tried diferent file patched, using me region from my bios, did not work
                                    • miansh621
                                      Banned
                                      • May 2022
                                      • 133
                                      • pakistan
                                      #118
                                      heloo.
                                      My dell latitude 5520 have a password (master password)
                                      thanks in advance
                                      feedback
                                      • darckreign1984
                                        • 260
                                        • Romania
                                        #119
                                        Originally posted by miansh621
                                        feedback
                                        you do the magic.
                                        your file worked.
                                        thanks
                                        • Dellos854
                                          • Oct 2022
                                          • 2
                                          • France
                                          #120
                                          Hello I need help to unlock my laptop bios. Please I have Dell Latitude 5520 also. What should I send you ? And how to flash a file bios ?
                                          • Akhlz001
                                            Dell Pro 13 Plus PB13250 Bios Unlock
                                            by Akhlz001
                                            Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                            09-20-2025, 07:15 PM
                                          • gizaha
                                            Dell Latitude 5580 possible bios corruption
                                            by gizaha
                                            Dell latitude 5580, motherboard cdp 80 la-e151p
                                            3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
                                            (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
                                            I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
                                            Since ssd is replaced and had clean install windows, i've...
                                            02-13-2024, 07:18 AM
                                          • Jeff'sTech
                                            Dell Latitude 7420 BIOS Unlock Gone Wrong
                                            by Jeff'sTech
                                            Hello everyone.
                                            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                            11-08-2023, 03:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5520 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5520 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5520 boardview and 5520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5520...
                                            09-07-2024, 06:38 AM
