Lenovo Unlock Dxe Driver Bios Collection
This topic is closed.
    • 21441
    Re: Lenovo Unlock Dxe Driver Bios Collection
    Originally posted by Smartguru@24
    How to creat patch file sir?
    Info in another thread. https://www.badcaps.net/forum/showthread.php?t=87588
    This thread for patched versions only
    • volinakis
      • Jan 2021
      • 2798
      • N/A
      #102
      Worked just fine on T440p, thank you!
      My method: I took another 25Q32 chipset and wrote the patched file with CH341A programmer - I didn't "touch" the original chipset, read erase or write - I followed the steps described, after all was done I replaced the chipset with original one and restored factory settings in BIOS. No beeps, no errors except when I turned on 1st time with original chipset I had a checksum error fixed by updating bios with last version.
      Thank you again, great job!
      • kaskader
        • Apr 2021
        • 1
        • Poland
        #103
        Thanks very helpfull. I did for x250 but the file you uploaded didnt work for me.
        • Mazorca
          • Jan 2017
          • 463
          I like volinakis method if more than one need to be fixed. Bios chips are cheap compared to whole boards, plus it cuts down on the heat/reheat again cycles. Heck, I will order a few just to have them handy.
          • volinakis
            • Jan 2021
            • 2798
            • N/A
            #105
            I did it this way because I saw - reading messages on this forum - others had problems writing back the original file, I think because of the programmer reading with errors. I advice whose who use the original chipset to clean the terminals with technical alcohol, also the adapter.
              • 21441
              Originally posted by ednar88
              I need an unlocked BIOS file patch for lenovo T440s 25q64
              Please read post #101 ,this thread for patched versions only.
              • Lornet
                • Mar 2021
                • 27
                • France
                #107
                Originally posted by ggrn
                Im getting 2x 5 beeps and then shutdown too
                The patched bios for X250 works but I think that you'll have problem if the ME Firmware version of your original bios and the patched one aren't the same. I have had trouble too and resolved it by using Intel Easy Clean Me tool for the ME firmware version being equal for each bios.
                • alihomee
                  • Dec 2012
                  • 1580
                  • malaysia
                  #108
                  i tried patch file for x250 but does not work can get any help....ori file is attach
                    • 21441
                    This thread is for patched versions only, please read the first post. Some of the patches at post #1 require the ME region to be cleaned.They do work. The autopatcher works too, all you have to do is install python,then drag and drop, its not difficult.
                    • digitecelettronica
                      • Sep 2019
                      • 3
                      • Italia
                      #110
                      Looking for patched/Unlocked Lenovo P50 20EQ, can anybody help?
                        • 21441
                        • mylocky
                          • Jun 2014
                          • 18
                          • hungary
                          #112
                          Thank you!!!! You are awesome!
                          +1 working on my T440p, without modify MEC.
                          • HARAN963
                            • Mar 2021
                            • 45
                            • FRANCE
                            #113
                            Pls
                              • 21441
                              Originally posted by HARAN963
                              Pls
                              Read post #111 ,this thread is for patched versions ONLY !
                              • volinakis
                                • Jan 2021
                                • 2798
                                • N/A
                                #115
                                Patched file for X270 didn't work for me, failed after asked for key for hardware id. (invalid key) I took a patched file from https://www.badcaps.net/forum/showth...highlight=X270
                                and worked.
                                • sattaraq
                                  • Jan 2020
                                  • 5
                                  Hello Maxpower
                                  if you have a patch for thinkpad yoga x1 4th Generation
                                  regards
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1240
                                    • France
                                    #117
                                    Originally posted by sattaraq
                                    Hello Maxpower
                                    regards
                                    32mo Bios not patch for this model
                                    • rassystems
                                      • 4
                                      #118
                                      lenovo x1 carbon 2nt gen password reset.help
                                      thank you....
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1240
                                        • France
                                        #119
                                        thank you....
                                        look if 24rf08 or mec
                                          • 21441
                                          thank you....
                                          • macabook
                                            by macabook
                                            đź§© Initial Issue
                                            07-24-2025, 02:17 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • remizbushka
                                            Dell inspirion 5775 bios "Unlock Setup fail"
                                            by remizbushka
                                            Hi sirs. please help
                                            Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                            After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                            What I did:
                                            I read the bios dump.
                                            Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                            03-24-2025, 09:07 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
