the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • c_hegge
    • Sep 2009
    • 5219
    Re: the gutless, bloated, and fried power supply hall of shame
    This was shawly not a 500W like it claimed to be. Notice the heat damage on the output. The wires were melted near the PCB. The funny thing is that when I peeled off the label with the SHAW brand, there ws another label claiming it was a Ritmo. Any ideas who made it? Maybe TaiwanBreakDownComponents Company? The heatsinks were OK-ish, but the 5vsb transistor was a total joke - about the same size as the one on kc8's echo star 480.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5008
      • New Zealand
      #102
      I've got a some 300 Watt Hyenas (Deer) that look better than that thing.
      -David VanHorn
      • c_hegge
        • Sep 2009
        • 5219
        I got a good picture of the wires. I stuck the 12v ones out (which were melted together) so you could see how discoloured they were.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #104
          Linkworld
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            #105
            That looks absolutely horrible. Did the fan seize? If not, I wonder what caused the thermal runaway. It doesn't help either that they put big low-ohm loading resistors on the secondary.
            And, yes, you can tell the 5vsb transistor was undersized - note the burn marks on its spot on the PCB.
            Probably a daughter company of HongKongFlyApart
            • c_hegge
              • Sep 2009
              • 5219
              The fan did indeed quit on this PSU, which is probably why it got so hot.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5008
                • New Zealand
                #107
                You wonder why people don't notice their fans making hideous grinding noises.... A friend of mine had a 133Mhz Pentium and the PSU fan was in terrible condition.
                I did not know about capacitor problems at that time but luckily we just replaced the whole PSU.
                -David VanHorn
                • c_hegge
                  • Sep 2009
                  • 5219
                  They probably notice, but because the PC still appears to be working, they don't care.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #109
                    qft
                    Btw, here in Greece, I see many Linkworlds (LPQ, LPH or LPK) that use Sleeve Bearing Globe Fans and as they work at full speed all the time they fail quite often.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Sky 550 watt. It looks like TaiwanBreakDownComponents Company got the transformer right, for once as it's a real 35 size, but everything else is wrong. The transient input filtering is missing (other than only 2 Y-caps), the primary switchers claim to be 13009s, but they look too small. On the secondary, we have a 16A fast recovery on the 12v and 20A schottkys for the other two rails. All of the caps are BH. The primaries are 470uF. All of the rails have a pair of 1000uF caps on them, except for the -12, which has a single 470uF. The fan looks like an off-brand (HongGu). Probably could be re-built like my rexpower, but I'm not in any mood that at the moment, so it will probably just die a spectacular death on my load tester or get the sledge hammer treatment.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        correct me if i am wrong, but it appears that the grounding pin on the AC connector goes nowhere
                        i would desolder the transformer out of it and find a junk small one to put in before you fry... the tranny might be good for a unit with a small tranny but good everything else
                        500w mein ezel, das ist sehr schlecht! (english: 500w my ass, that (power suppy) ist very bad!)
                        complete donkey poo...
                        sigpic
                        (Insert witty quote here)
                        • c_hegge
                          • Sep 2009
                          • 5219
                          The ground wire does actually connect to the case. It's just not easy to see in the picture. But it is still a gutless wonder.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            It blew up at 277 watts on the load tester. Here's the carnaige
                            Last edited by c_hegge; 11-30-2010, 11:08 PM. Reason: Add some pics of the carnaige
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #114
                              Shame. It didn't look that bad actually. Definitely not 500W, but I would have expected it to do 250W continuous, maybe 300W for short durations.
                              At least you got spare parts now .
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Originally posted by momaka
                                ...It didn't look that bad actually...
                                Yes it did. It had no PI filter coils on the secondary and no way of adding them.
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  #116
                                  What blew in it?
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Not sure. The primary swithers looked OK, although I didn't test them and they had gotten so hot that the plastic rings around the screws had melted. A few of the nearby resistors looked burned out, though. The burn mark is actually almost invisible on the component side of the PCB. Unforunately, I can't get any more pics as after it blew up, I scavenged the transformer and wires and gave it the sledge hammer treatment.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Looks like the primary switchers blew out.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        Here's another shocker. Tiny transformer, miniscule heatsinks and half a PCB. The best part is, it's an FSP (more specifically, a Gigabyte "300W"). It did actually do 320W on the load tester, but the DMM wouldn't settle when I was reading the voltages.
                                        • goodpsusearch
                                          • Oct 2009
                                          • 2850
                                          • Greece
                                          #120
                                          lol
                                          It must be loud.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
