LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
  • hoaca388
    Badcaps
    • Jan 2022
    • 12516
    #1201
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by Saile2752
    Hi, I have same issue for a Thinkpad X1 Yoga 3rd gen.
    Size of the bios was 16MB
    Laptop produced a 2 X 5 Bips sound, then nothing !
    only charging light .
    After, even if i update again the bios with patched one or the original one, nothing is produced by the laptop...
    Bios ship is W25Q128JVSQ.
    i used W25Q128JV and the CH431 for the update. i downloaded the programe in the forum and patched the bios.
    You should post your original bios .bin file here.
    • 999Alibaba
      • Jan 2022
      • 2
      • United Kingdom
      #1202
      Hi, I have a issue for a Thinkpad W540 after pach of my dump bios to remove password
      the laptop make a 2 X 5 Bips sound, then nothing! After a reflash again with dump bios working but askme to put password. Please I need a good pached bios. Any help would be appreciated, thank you.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12516
        #1203
        Originally posted by 999alibaba
        hi, i have a issue for a thinkpad w540 after pach of my dump bios to remove password
        the laptop make a 2 x 5 bips sound, then nothing! After a reflash again with dump bios working but askme to put password. Please i need a good pached bios. Any help would be appreciated, thank you.
        • mattj7
          • Jan 2022
          • 2
          Hi everyone, I am new around here.
          2 things.
          1. I just used this tool for a supervisor password on an L480 I bought used (seller did NOT disclose this issue!). It fixed the problem just fine, worked easily and without an issue.
          2. Would this script/method work on a Thinkpad T14 Gen1?
          • hoaca388
            Badcaps
            • Jan 2022
            • 12516
            #1205
            2 things.
            Why don't you try it if you own a Thinkpad t14 Gen 1.
            • Saile2752
              • Dec 2021
              • 5
              • France
              #1206
              Here is my bios file.
              Could some one test it and patch it please ?
              I have made a verify after copying the bios from my laptop Thinkpad X1 Yoga 3rd gen.
              Thanks.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12516
                #1207
                Originally posted by saile2752
                hi,
                here is my bios file.
                I have made a verify after copying the bios from my laptop thinkpad x1 yoga 3rd gen.
                Thanks.
                Code:
                253794
                • Saile2752
                  • Dec 2021
                  • 5
                  • France
                  #1208
                  Code:
                  253794
                  Thank you very much.
                  I will try again friday and back to the forum to update with results.
                  • SHADYERK
                    • Jan 2022
                    • 4
                    • Mexico
                    #1209
                    Hi, this is my second post in the forum, and my situation is the following:
                    I have a Lenovo Laptop with this features...
                    Lenovo Thinkpad T460P (Late 2015 ) intel Gen 6th
                    Motherboard model : BT463-NM-A611-Rev -1.0
                    BIOS CHIP:
                    Winbond
                    25Q128FVSQ-1549
                    The BIOS has a supervisor password and it is locked. I tried to make a backup with the CH341A using a programmer clamp, apparently it was not done correctly and the .bin file is corrupt (The patch found errors). My question is the following, I hope you can clarify and help me... Can I download a clean/patch .BIN file without passwords for any T460p and flash the IC? Or is it that I necessarily need the original of my BIOS? I await your responses, thank you! Greetings!
                    NOTE: I have the complete information like UEFI BIOS version, System Unit and board serial number, UUID, MAC adress, OA3ID, etc.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #1210
                      BIOS CHIP:
                      Winbond
                      25Q128FVSQ-1549
                      What makes you think that if you haven't read it successfully, you will program it correctly?
                      The first rule when you start playing with the bios chip is to make a good verified dump of the original bios.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • SHADYERK
                        • Jan 2022
                        • 4
                        • Mexico
                        #1211
                        Yes, I understand that I had some fault for not taking precautions before deleting, but I made two backups of my original BIOS, both with an identical size of 16,384 KB and at the time of making them they had no errors, the errors were given to me during the patching: "xxx. bin is corrupted or does not contain a valid dump. There was an error... Aborting."
                        Honestly, I thought I could put any patched BIOS on it, I think I made a rookie mistake...
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #1212
                          You can, but how do you plan to complete step 8?
                          Apparently you haven't read the procedure carefully.
                          Do I understand that you have already managed to delete the original BIOS without having a good dump from it? If so, you've really made a rookie mistake.
                          Originally posted by Knucklegrumble
                          [ HOW TO USE THE PATCH ]
                          STEP 1: Flash and replace current BIOS with the generated patch file
                          STEP 2: Boot the machine
                          STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                          STEP 4: Enter any character when asked for Supervisor Password
                          STEP 5: Press enter when it shows Hardware ID
                          STEP 6: Press space bar 2x when asked
                          STEP 7: Turn off machine
                          STEP 8: Restore original BIOS
                          STEP 9: Reset BIOS settings to factory default
                          • rttre3ee
                            ROMA
                            • Dec 2018
                            • 4
                            • Ukraina
                            #1213
                            patch me please this dump T480
                              • 22415
                              Have you even tried the Autopatcher at post #1
                              • rttre3ee
                                ROMA
                                • Dec 2018
                                • 4
                                • Ukraina
                                #1215
                                with computrace activateed,
                                i mtrying with lenovo autopatcher 0.2 without succes(biping blackscreen)
                                thx in advance
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #1216
                                  with computrace activateed...
                                  https://www.badcaps.net/forum/showpo...postcount=1191
                                  • rttre3ee
                                    ROMA
                                    • Dec 2018
                                    • 4
                                    • Ukraina
                                    #1217
                                    After flash this dump laptop dont bootup, only sound signal and black screen
                                    • SHADYERK
                                      • Jan 2022
                                      • 4
                                      • Mexico
                                      #1218
                                      So as you understood hehe I only have those two corrupted backups and the chip of my BIOS erased I tried to flash with a .bin (downloaded from the forum) that was for the same type of board and chip, with AsProgrammer 1.4.1, but after booting and showing the logo, it shows me : "Boot error: 0183 Bad CRC Security Settings in EFI variable" and shuts down. Then I think I'll have to get a new board, I feel bad, it was my first attempt at this BIOS, but it helps me a lot of experience. Thanks!
                                      • Linux200
                                        • Sep 2020
                                        • 12
                                        • Algeria
                                        #1219
                                        Hi, I have a issue for a Thinkpad L390 after patching original bios to remove password
                                        the laptop make a Bips sound, then nothing! blackscreen After a reflash with original bios it work but still password . Please I need a good patched bios. Any help would be appreciated, thank you.
                                        • Markus1741
                                          • Sep 2020
                                          • 994
                                          • N/A
                                          #1220
                                          Is it possible that the Intel ME region on the original bios is defective.
                                          Lenovo boot screen starts slowly.
                                          I had the problem once too.
                                          https://www.youtube.com/watch?v=aHSP...nnel=SureCanDo
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                                            by cr4zychriss
                                            I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                                            I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                                            • Barebone / Chassis: TongFang GK7MRFR
                                            • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product Name: Razer Blade 15 (2022)
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            BIOS Versions I work with: 2.02 & 2.06
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                            I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                            The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
