Re: The Hall of Shame - Badcaps Photo Montage
2 Vented Rubycon MFZ 2700uF 6,3V and one starting to vent.
These were on an Xbox 360 Systemboard. It had one lifted yellow 820uF 4V Fujitsu Polymer as well. I replaced them all (13Pieces) with Samxon GA 3300uF caps and the polymers with Chemicon PS 820uF's however the Xbox still says the 0200 error code. Maybe the CPU/GPU is cooked by the excessive heat.
SAMXON capacitors on a power supply/inverter from a MAG lcd monitor.The two small capacitors in the inverter section are 50uf 25v samxon GK series.And the other two in the secondary of the smps are 470uf 25v samxon GF series.The failure of the two in the inverter section caused the Ic in the picture to become a toasty critter.The monitor was manufactured in mid 2005
. I changed them all be4 i realized to take a pic.
