Asus Q502L does not boot up properly
  • emadarion
    • Jun 2017
    • 43
    • Cairo
    #121
    Re: Asus Q502L does not boot up properly
    Thank you for sharing, very detailed, to see more times to remember
    • tibimakai
      • Jan 2012
      • 3680
      Still not done with this laptop. I have purchased a used board from the bay, installed a brand new Samsung ssd, installed Windows 10 and all seemed fine for a few days. I have put it away for a few weeks.
      After awhile I have grabbed it, and it started acting up.
      What's in a while would not "see" the ssd and would boot into BIOS. If I rebooted, eventually would boot and work OK for a while.
      Now more often goes to BIOS, then in Windows.
      Replaced memory, HDD even the small daughter board for the HDD, still no change.
      Has the latest BIOS, all the updated, Windows 10 2004 and all.
      Any suggestion what should I do with it. Sometimes goes into blue screen as well.
      • tibimakai
        • Jan 2012
        • 3680
        Nobody has encountered a disappearing HD situation, what could be?
        • tibimakai
          • Jan 2012
          • 3680
          If I plug in a 2.5" HDD it shows the Sata port 0 as Empty.
          If I plug in an msata SSD, it shows Sata port 2 as Empty.
          If I don't plug in any HDD, shows all Sata ports Sata 0, #1, #2, #3, #4
          They all show Empty.
          What could be the problem here?
          What controls the Sata ports? The CPU, or there is a separate Sata controller?
          Any help would be greatly appreciated.
          • tibimakai
            • Jan 2012
            • 3680
            It stopped recognizing any HDDs.
            • Duranitron
              • Jul 2014
              • 544
              • Philippines
              #126
              if its not recognizing any ssd hdd try to clean the connectors. try to reinsert it.. try to boot using usb does it recognized the usb drive....do you happen to check the rtc battery maybe its way too low..
              Never stop LEARNING because life never stops TEACHING!
              • tibimakai
                • Jan 2012
                • 3680
                I have even replaced the hdd daughter board, so it is hard to believe that the connector is causing these issues.
                I will check the connector, just in case.
                It recognizes a USB stick. Starts installing Windows, but it won't find a hdd.
                I haven't checked the battery, but it holds the date.
                • tibimakai
                  • Jan 2012
                  • 3680
                  It's been a while since I have looked at this laptop, but I have just had a bulb turn on above my head.
                  The laptop hard drive, has to have a 12V supply as well, other than 3.3V and 5V supply?
                  I don't have it.
                  No matter what I try, HDD won't show in BIOS.
                  I would appreciate any help.
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    #129
                    No, 2.5" laptop HDD don't use 12V.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      What else could be, that no hdd shows up in the BIOS? 3.3V and 5V is there.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        There is only the ITE IC and the CPU on this board. What could cause this issue?
                        BGA solder issue at the CPU?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Nobody can help?
                          • FrozenHaxor
                            • Jun 2015
                            • 266
                            • Poland
                            #133
                            Most likely cause is the PCH part of the CPU is bad, it controls SATA I/O directly.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Can't be solder balls cracking?
                              Thank you, for your reply.
                              How "easy" is to replace the CPU?
                              • FrozenHaxor
                                • Jun 2015
                                • 266
                                • Poland
                                #135
                                I have a BGA machine with optical system and it takes lots of experience to do it right. Intel CPUs are notorious for doing a "banana" and warping on cooldown, I avoid replacing them like a plague. I usually condemn boards that need this repair as it's not worth it most of the time, and new CPU itself will cost more than complete used working board in this case. If you suspect cracked BGA soldering then you could do a reflow, but all of the glue needs to go before doing it, and you still need a BGA rework station to avoid warping, especially on cooldown. If the laptop wasn't dropped and there was no physical shock to the mainboard, it is most likely internal PCH fault and they are notorious for such problems, even Intel admitted so years ago.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Most likely I won't reball the CPU, just reflow it.
                                  What is interesting, that initially when I got the board from Ebay, it was working great, I have installed Windows, and it worked.
                                  After a while, it started to act up, sometimes it would not recognize the hdd, but a reboot took care of that. This started to become more frequent, until it would not recognize it at all.
                                  • FrozenHaxor
                                    • Jun 2015
                                    • 266
                                    • Poland
                                    #137
                                    Does your HDD connect directly to the mainboard via ribbon or is there a daughter board with connector that mates to the mainboard?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Daughter board. I have already purchased another one, and it is still the same issue.
                                      • FrozenHaxor
                                        • Jun 2015
                                        • 266
                                        • Poland
                                        #139
                                        Did you inspect the other part of the connector on the mainboard? Some Asus boards are prone to failures of them causing odd issues. If it's okay then it's a PCH problem.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          Yes, I have when over with the solder iron.
                                          • throwaway327
                                            Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                            by throwaway327
                                            ASUS ROG Ally X - (Handheld Gaming PC)
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                            I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                            06-18-2025, 05:52 PM
                                          • jrodefeld
                                            Asus laptop won't boot (no power) - possible bad caps?
                                            by jrodefeld
                                            I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                            The model:
                                            Asus Zenbook Pro Duo UX582L
                                            I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                            However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                            09-02-2024, 04:55 PM
                                          • acata
                                            Asus X450LC REV 2.2 can't boot to anything
                                            by acata
                                            I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                                            Power on normally. Boot to bios ok.
                                            But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                                            10-10-2023, 05:15 AM
                                          • lukkihapsi
                                            Asus Vivobook X515JA Weird Boot Issue
                                            by lukkihapsi
                                            Asus Vivobook X515JA Laptop
                                            Issue :
                                            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                            Tried :
                                            Cleaned inside for dust, applied fresh thermal paste. No Change!
                                            Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                            Removed Internal SSD. No Change!
                                            Updated BIOS to latest version. No Change!
                                            Removed battery and pressing power button for 1 minute. No Change!
                                            Weird Part :
                                            Upon turning laptop ON, screen lights up - stays black,
                                            I...
                                            07-07-2025, 12:07 PM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
