Help with dead Commodore 1802
  • R_J
    • Jun 2012
    • 9578
    Re: Help with dead Commodore 1802
    At filter cap C803 there is no AC voltage. This is correct! IT IS DC VOLTAGE!!!!
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      #122
      Yes thats right. No voltage at filter cap. I am right measuring accros the 2 cap contacs (+and -).
      • R_J
        • Jun 2012
        • 9578
        What do you have in place of the resistor? if there is nothing there, You will not get any voltage across the capacitor because you are not getting any AC to the diodes.
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          #124
          I put this bulb ain place of the resistor maybe i need a bigger bulb? It measures 72.5 ohms.
            • 31131
            strange, you should see some voltage and some life from the lamp.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #126
              Well I just wired one of those ever ready bulbs to 240v mains and it doesnt light up. They all seem to be the same. They are nor open circuit and show a resistance but dont iluminate with 240v ac. I think these bulbs are what are fitted into ovens etc but surely they should light up. I will go andf buy some more of the bigger ceiling type bulbs tomorrow and have another go. No wonder we havent been getting anywhere.
                • 31131
                it's really strange that you see a resistance but no life - be interesting to do an autopsy and cut the metal cap open!
                • R_J
                  • Jun 2012
                  • 9578
                  I just checked a couple incandescent lamps, these are 120vac 60watt = 16Ω. (Christmas light) 120vac 7 watt = 189Ω, Appliance lamp 120vac 40watt = 27Ω
                  • roadrash
                    • Oct 2015
                    • 490
                    • U.K.
                    #129
                    You are not going to believe this but that length of 3 core flex i was using had a break in it and after i cut 6 inches of each end it now works. What are the chances of that.
                    I didnt think to check the cable as it looked like it was good. Anyway i now have the bulbs iluminating as they should. I will have another go at it later now to see if i can make any sense now over what we checked.
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      #130
                      I just checked a couple incandescent lamps, these are 120vac 60 watt = 16Ω. (Christmas light) 120vac 7 watt = 189Ω, Appliance lamp 120vac 40watt = 27Ω
                      Sorry for delay getting back to you both but was in hospital yesterday getting steroid injections into my spine and boy was I was I very sore today.
                      Right well got all the bulbs now working as they should and when powered on the only bulb illuminated is the one across where the resistor R801 was. The bulb where L803 was does not light up.
                      The voltages now are now as follows:
                      At filter cap C803 it fluctuates between 6.5v DC and 16v. Although when first powered on it reads 6.2v DC and slowly rises the longer its turned on.
                      On T801 at pin 2 the voltage fluctuates between 9.5v and 13v DC but If I set the meter to AC I get a steady 30v which makes me think its AC and not DC voltage there.
                      Pin 4 it again fluctuates using DC scale between 8.5 and 13v but if tested using the AC scale I get 30v.
                      At the pins 4 & 5 of the LOPT again the DC voltage fluctuates and its impossible to get a steady reading. If I measure it using AC scales Pin 4 still fluctuates a little buts around 13v and Pin 5 its the same slight fluctuating but up to 15v.
                      According to your schematic RJ I should be using the DC scale to measure these voltages. I am taking the DC ground/negative from the C803 Cap on the side of Q803 & R803 & Q805 which according to your schematic RJ is the the DC ground.
                      So it seems I am not getting rectified voltage or am I doing something wrong still?
                        • 31131
                        are you sure the rest of that cable is good?
                        you should see about 340v dc across the main filter cap
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #132
                          Yes that cable ok now because if t wasnt the bulb that is replacing that big resistor woulnt illuminate.
                          That is the resistor that kep popping if you remember and is what we were trying to diagnose..
                          What would cause a low voltage at that filter cap?
                          I just tested it again and I am getting 18v DC.
                          • R_J
                            • Jun 2012
                            • 9578
                            The bulb you are using has too high a resistance, and remember that 72.5Ω you measured is the DC resistance, it is going to increase even more when it lights.
                            The A/C voltage is being droped from 240vac to around 13vac to supply the diodes which then outputs 18vdc.
                            So you need to find a regular 60~100 watt Incandescent lamp
                            • roadrash
                              • Oct 2015
                              • 490
                              • U.K.
                              #134
                              Ive connected 60w bulbs to both places now and when i power it up i hear a clicking noise and one of the bulbs flickers which then changes to a buzzing sound. Voltage at filter cap is still only 15v
                              • R_J
                                • Jun 2012
                                • 9578
                                I would just use the 60watt lamp in place of the resistor R801.
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  #136
                                  Ok i put the smaller bulb on L805 and when i power it up i still get the ticking noise and the 60w lamp flickering.
                                    • 31131
                                    what AC voltage at L802 ??
                                    input AND output side?
                                    • R_J
                                      • Jun 2012
                                      • 9578
                                      Check if you have ANY voltage on C814 or C812, if the power supply is ticking, it is trying to start but can't, either due to a short in the secondary or the primary can't start properly. I would start by replacing C806 and C825 and see if it makes a difference.
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        #139
                                        I get 237v AC.
                                        • roadrash
                                          • Oct 2015
                                          • 490
                                          • U.K.
                                          #140
                                          C806 & C825 when tested give the following results:
                                          C806: c=233nf vloss=1.5% ESR=1.6 ohms
                                          C825 c=12.25uf vloss=0.7% ESR= 3.0 ohms.
                                          Will need to get some 10uf 160v if its no good as I only have 50v.ones.
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
