ESR meter upgrades
This is a sticky topic.
    • 31256
    Re: ESR meter upgrades
    that looks like aT3,
    it should work on it.
    put a 16MHz crystal on it - that will give it a good upgrade.
    • bc989
      • Oct 2015
      • 21
      • Asia
      #142
      Its pretty hard to ID them, most T3 google images show the battery cables under the LCD, but there are still a couple of differences to mess it all up.
      Anyhow, great! I'll likely test with the 8MHz first. And while waiting for the rotary encoder, can I go ahead and flash the test file first? Will basic functions still work with the std button?
        • 31256
        test file is o.k. but dont go into the menu - you will get stuck.
        • bc989
          • Oct 2015
          • 21
          • Asia
          #144
          Just in case, I need to revert or reflash back to recover... are there any dump of the original factory default software/firmware that came with these T3/T4?
            • 31256
            there is this, but i dont think it's original
            https://yadi.sk/d/yW8xa5NJgUo5z/LCR-T4(T3)
            • GoNz0
              • Sep 2012
              • 28
              • United Kingdom
              #146
              Hi all, is this one any good to get ? gm328rhttp://www.ebay.co.uk/itm/2016-EZM32...sAAOSwtJZXU~VA
              or should I get the gm328a? http://www.ebay.co.uk/itm/2015-versi...kAAOSwHnFV2EJw
              Thanks.
                • 31256
                the 2016 328R looks good.
                rotary encoder etc already fittted.
                if they had put a programming header on it, it would have been perfect!
                another good option is the banggood unit that has an optional case.
                http://www.banggood.com/DIY-M12864-G...-p-997023.html
                or the case may fit the ebay model.
                i hope you notice they are both KITS you need to build.
                • GoNz0
                  • Sep 2012
                  • 28
                  • United Kingdom
                  #148
                  Yep so long as they come with destructions I am fine with soldering & would rather save the fiver along with an excuse to get the solder station out
                  Can either have a header fitted for programming should I need it later down the line?
                  initial use will be testing caps on my broken UPS.
                  Thanks for helping.
                    • 31256
                    you can put a header on with jump wires - unfortunatly they didnt route the tracks to any pads for one.
                    i'v said this to people before, but put a good 16MHz crystal on it.
                    you will increase the accuracy, and enable the crystal/resonator tester.
                    (needs a software upgrade.)
                    on that subject - if you dont have a programmer yet.
                    http://www.ebay.co.uk/itm/272041588746
                    • GoNz0
                      • Sep 2012
                      • 28
                      • United Kingdom
                      #150
                      So the bangood DIY M12864
                      USB Programmer
                      And what 16mhz crystal do you suggest -/+10ppm I saw a few pages back?
                      Thanks.
                        • 31256
                        yep, and not a full 49' type, a low profile one.
                        you can probably salvage one from some junk
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          How difficult would the build be for an electronics amateur like myself ? (AKA how good are the instructions, if there are any)
                            • 31256
                            how should i know - i dont know your skills or equipment.
                            so what iron and experience do you have?
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              Soldering not the concern, rather assembly of components to PCB, what goes where
                              No need to respond further, found one of the reviewers had posted assembly video
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #155
                                can you link the video? as i may look into this upgrade too many thanks.
                                • bc989
                                  • Oct 2015
                                  • 21
                                  • Asia
                                  #156
                                  Before I reprogram my T3, I traced the programming pad and found the RESET pad is not connected to the atmega328 reset pin. Instead it goes to pin 30 (rxd/pcint16/pd0) see attached pic.
                                  Shouldn't the programming pad RESET be connected to pin 29 (RESET)?
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    https://www.youtube.com/watch?v=rSLW...ature=youtu.be
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #158
                                      thanks theres some good videos on his page.
                                        • 31256
                                        can you double-check those pads, they use that to program them after assembly.
                                          • 31256
                                          about that video - NEVER BEND THE FUCKING WIRES OVER.
                                          it makes stuff much harder to remove again without damaging the pads.
                                          damn i hate these amateur video's teaching people bad stuff.
                                          and make sure you use 99% IPA to remove all the flux afterwards.
                                          it may not seem important usually, but on something like this, it can effect the readings!
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
