HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #161
    Re: HP BIOS unlock tool
    Thanks for sharing!
    Using latest version of flashrom I have successfully read 256MB chips. MX25L25635F is in support list. Probably works fine with your chip.
    Those 2 not working laptops were probably just bad and not verified reads (always make sure to verify). Or maybe bad soldering. Find a dump with clean ME and VSS region.
    The one that you uploaded is quite unusual. It has 2 sections with that keyword and first one is quite empty. I have only seen dumps with one of those sections. So my unlocker only modifies the first section. Try this file:
    • slaine
      • Feb 2020
      • 21
      • germany
      #162
      Thank you RethoricalCheese - will try it and report.
      For the other 2 840G3 machines that are not working, i tried several dumps from other topics, cleared and non cleared - all show same symptoms (blackscreen, fan full speed, reboot or just powerOn-powerOff loop).
      I even tried the one with EC dump and MainBios dump (so that SerialNumber matches). No Luck, all show the same behavior.
      I also tried to lookup the VSS Area via UEFI-Tool and HxD. Could not find the usual $VSS region in anyone of these dumps. Did HP change their approach in locking the Passwords?
      Also if anyone have a clean dump, could someone provide me with a dump? It would be realy appreciated.
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #163
        Yes, 840G3 goes to the "new" category.
        Use uefitool NE alpha 56. There will be EfiSystemNvDataFvGuid under BIOS region. There you will find VSS2 store.
        Since 840G3 needs soldering to read/write, I still think there might have been a problem with your soldering.
        And when you use dumps from other people and there is no display right away, you need to wait 15 seconds or maybe up to a minute. Dirty ME region causes this wait time.
        • slaine
          • Feb 2020
          • 21
          • germany
          #164
          nice -got you. Found the vss2 - is it the region that states Admin PW / Power ON @ arround 09230 & 09400 that needs to be FF / 00´ed?
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #165
            Search for unicode UserCred.
            That section needs some specific 00/FF pattern.
            • slaine
              • Feb 2020
              • 21
              • germany
              #166
              Its working - no PW - only 2 broken left now ^^
              • allex74
                • Mar 2020
                • 3
                • Austria
                #167
                Hi, using a HP Elitebook x360 1030 G2 with Win10 Pro but do not know Bios Administrator password -> Bios Update via HP Support Assistant is not possible...
                also tried to get into ESC-F10 Bios Setup but after 3 attempts no error code displayed.
                Also backup of current Bios is not possible without Admin password.
                Is there an easy, clear and understandable assistance available for my case as I am confused what to do exactly...?
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #168
                  You do not need admin password for backup. You need an SPI programmer and maybe some other tools for that.
                  For that model you need soldering tools and skills. If you do not have them, find somebody who has all that and pay for the service. It will be cheaper than buying all the tools.
                  • allex74
                    • Mar 2020
                    • 3
                    • Austria
                    #169
                    So no other possibility than soldering or exchange of the mainboard? What about these smc.bin files which were supported by HP a year ago, doesn‘t exist any Software tools...?
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #170
                      They were from HP. I can create them but I can't sign them. Only HP can and HP will not do it.
                      So in other words, SMC.bin is dead. To unlock, you need tools.
                      • mr.Data
                        • Sep 2018
                        • 78
                        • Netherlands
                        #171
                        I did verify and everthing seems to work without a problem. When I program the locked bios the laptop works but when I try unlocked, it dont work anymore.
                        Tried twice but with the same result
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          #172
                          And why don't you upload your files?
                          • mr.Data
                            • Sep 2018
                            • 78
                            • Netherlands
                            #173
                            I did
                            Originally posted by mr.Data
                            Unlocked file isn't working. Please have a look
                            • Timbo01
                              • Mar 2020
                              • 7
                              Is there any way to get a dump from a WSON 8x6 chip without soldering / hot air station?
                              • dycc
                                Vision
                                • Nov 2011
                                • 625
                                • Côte d'Ivoire
                                #175
                                840 G6
                                it recover password by itself
                                use uefitool NE A57 to clean still the same
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #176
                                  Looks like newest generation has something different. Got to get myself one to try some thing out.
                                  • slaine
                                    • Feb 2020
                                    • 21
                                    • germany
                                    #177
                                    zbook15g5 got an MX25L25673 32mb eeprom - cant read that with pi nor with the tl866cs - ordered the tl866 ii plus
                                    Hey RethoricalCheese -want to report back
                                    With the 866iiPlus i could dump the BIOS, your unlocker has worked with all three of the zbook 15G5
                                    The HotAir soldering from this WSON is one of a kind, i burned the first eeprom, had to buy a spare one. After 3-4 tries I kinda got a feeling for the WSONs. Soldering Paste and a steady hand lead to success. Thank you again for the unlocker tool
                                    • quidep
                                      • Apr 2020
                                      • 19
                                      Hello all,
                                      I'm new to this forum. Before I've registered I've read many instructions how to recover the BIOS password on my HP EliteBook 840 G2. I bought a CH341A programmer, connected it to my PC and set up the SW. I was also able to back up the HP BIOS (I hope at least so) and to run the HP remover tool from the top post. But after I flashed it back the password still remains. I'm not sure, which step fails, maybe you could have a look at the attached files or provide me a password free version.
                                      Thank you in advance!
                                      • peste
                                        • Dec 2016
                                        • 13920
                                        • ROMANIA
                                        #179
                                        Originally posted by quidep
                                        Hello all,
                                        the copy you posted is not ok ... do you still have the original? you need to extract the bios chip from the motherboard, read it with the programmer, make a copy and check it with the hex program.
                                        • quidep
                                          • Apr 2020
                                          • 19
                                          I do not have any other copy. But the HP still works, so maybe this is only an issue with the programmer? How do you recognize, whether a copy is OK?
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                            by Citymin
                                            My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                            The charging red LED lights up, but the charging screen doesn't show any indication.
                                            When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                            (I've tried removing the battery and resetting the device, but the issue persists.)
                                            NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                            PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
